Hyunsoo Kim 0H
Hyunsoo Kim 0
@Hyunsoo Kim 0
  • VOXL2 flash error
    Hyunsoo Kim 0H Hyunsoo Kim 0
    I figured this out.. instead of flashing by sdk 1.2, first tried with 1.1.3. and then updated to sdk 1.2.
    I hope this helps you
  • flashing VOXL2 errors
    @Wei-Cui
    How did you wipe the /data?
  • VOXL2 flash error
    While flashing the voxl2 I am getting this error. Do you guys have any recommendation?
    [WARNING] This system image flash is intended only for the following
              platform: VOXL2 (m0054)
              Make sure that the device that will be flashed is correct.
              Flashing a device with an incorrect system image will lead
              the device to be stuck in fastboot.
    Would you like to continue with the VOXL2 (m0054) system image flash?
    1) Yes
    2) No
    #? 1
    [INFO] checking partition system::0xD3B5D7000
    [INFO] {system::0xD3B5D7000} partition returned size {0x1A435F3000}, expected {0xD3B5D7000}
    [WARNING] Partition layout was found to be incorrect, this requires
              flashing the full partition table. Flashing the partition
              table will also flash every partition causing all data on
              the device to be lost.
    When doing a full flash, make sure to backup any important files
    Would you like to continue with the full wipe/flash now?
    1) Yes
    2) No
    #? 1
    [INFO] Found all required files
    Flashing: modalai_conf | m0054-conf-fs.ext4
    [--------------------------------------------------------        ]( 88%)
    [ERROR] Failed to flash partition: modalai_conf
    target reported max download size of 805306368 bytes
    sending 'modalai_conf' (5176 KB)...
    FAILED (remote: Error: Last flash failed : Volume Full)
    finished. total time: 0.000s
  • ADB devices not found
    @tom Thank you so much!
    I was having the exact same problem with @marian.
    I could connect to the voxl via ssh but could not via adb shell.
    But could solve it after removing the /etc/udev/rules.d/51-android.rules.
    Try to remove the file, who are facing the same problem with me.
