aryan yadavA
aryan yadav
@aryan yadav
  • Missing C27 config file for Starling 2 Image Sensor Micro-coax Front-end Adapter (MDK-M0173) in voxl 2.
    aryan yadavA aryan yadav
    @tom I've bought the pre flashed voxl 2 devkit, so I didn't run any install.sh script, I directly plugged the board with camera board i.e. starling 2 front end and directly performed adb shell using my host device. Do I need to reflash the image and build the kernel or can the kernel be updated/reconfigured without flashing?
    @Jetson-Nano said in Missing C27 config file for Starling 2 Image Sensor Micro-coax Front-end Adapter (MDK-M0173) in voxl 2.:
    u using and are you getting any options for c27 config while runnin
    Hi @Jetson-Nano I'm running 1.3.5 and No I'm not getting option 27 that is basically for c27 camera configuration.
    When running voxl-configure-sku in voxl 2 there is no config file for c27 configuration, how to setup for c27 camera configuration for Starling 2 Image Sensor Micro-coax Front-end Adapter MDK-M0173-1-02.
