Alex MayA
Alex May
@Alex May
  • Lumenier RID & M10Q GPS Module compatibility
    Alex MayA Alex May
    @Eric-Katzfey I don't believe we have a scope available for at least a few more days. But I do have other M10 GPS units I could try.
    Alex MayA Alex May
    @Eric-Katzfey
    _| / / |_/
    px4 starting.
    INFO [parameters] Starting param sync THREAD
    INFO [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
    AIRFRAME: MULTICOPTER
    GPS: AUTODETECT
    RC: CRSF_RAW
    ESC: VOXL_ESC
    POWER MANAGER: VOXLPM
    AIRSPEED SENSOR: NONE
    DISTANCE SENSOR: NONE
    OSD: DISABLE
    ARTIFACT_MODE: DISABLE
    EXTRA STEPS:
    INFO [muorb] [parameters] Starting param sync THREAD
    Running on M0104
    INFO [muorb] [qshell] before starting the qshell_entry task
    INFO [muorb] [tasks] Creating pthread qshell
    INFO [muorb] [qshell] qshell entry.....
    INFO [muorb] [tasks] Successfully created px4 task PX4_qshell with tid 2097652
    INFO [muorb] [qshell] Init app map initialized
    INFO [muorb] [qshell] after starting the qshell_entry task
    INFO [param] selected parameter default file /data/px4/param/parameters
    INFO [muorb] [uORB] Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
    INFO [uORB] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
    INFO [muorb] [uORB] Advertising remote topic parameter_update
    INFO [muorb] [uORB] Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_t
    INFO [uORB] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
    INFO [muorb] [uORB] Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_t
    INFO [uORB] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
    INFO [parameters] BSON document size 3260 bytes, decoded 3260 bytes (INT32:49, FLOAT:104)
    Starting IMU driver with rotation 12
    INFO [qshell] Send cmd: 'icm42688p start -s -R 12'
    INFO [muorb] [uORB] Marking DeviceNode(qshell_req) as advertised in process_remote_topic
    INFO [muorb] [qshell] qshell gotten: icm42688p start -s -R 12
    INFO [muorb] [qshell] arg0 = 'icm42688p'
    INFO [muorb] [qshell] arg1 = 'start'
    INFO [muorb] [qshell] arg2 = '-s'
    INFO [muorb] [qshell] arg3 = '-R'
    INFO [muorb] [qshell] arg4 = '12'
    INFO [muorb] [drivers__device] *** SPI Device ID 0x26000a 2490378
    INFO [uORB] Advertising remote topic sensor_accel
    INFO [uORB] Advertising remote topic sensor_gyro
    INFO [muorb] [icm42688p] ICM42688P::probe successful!
    INFO [muorb] [drivers__device] on SPI bus 1
    INFO [muorb] icm42688p #0 on SPI bus 1
    INFO [muorb] [icm42688p] >>> ICM42688P this: b2601298
    INFO [muorb] rotation 12
    INFO [muorb]
    INFO [muorb] [qshell] Ok executing command: icm42688p start -s -R 12
    INFO [uORB] Advertising remote topic qshell_retval
    INFO [qshell] qshell return value timestamp: 211374557, local time: 211377002
    INFO [muorb] [drivers__device] Register interrupt b214ec48 e61ebf5c b2601298
    INFO [uORB] Advertising remote topic sensor_gyro_fifo
    INFO [uORB] Advertising remote topic sensor_accel_fifo
    INFO [uORB] Advertising remote topic imu_server
    INFO [qshell] Send cmd: 'icp101xx start -I -b 5'
    INFO [muorb] [qshell] qshell gotten: icp101xx start -I -b 5
    INFO [muorb] [qshell] arg0 = 'icp101xx'
    INFO [muorb] [qshell] arg2 = '-I'
    INFO [muorb] [qshell] arg3 = '-b'
    INFO [muorb] [qshell] arg4 = '5'
    INFO [muorb] [drivers__device] *** I2C Device ID 0xb76329 12018473
    INFO [muorb] [drivers__device] Set up I2C bus mutex for bus 5
    INFO [muorb] icp101xx #0 on I2C bus 5
    INFO [muorb] address 0x63
    INFO [muorb]
    INFO [muorb] [qshell] Ok executing command: icp101xx start -I -b 5
    INFO [qshell] qshell return value timestamp: 211427777, local time: 211431619
    INFO [qshell] Send cmd: 'temperature_compensation start'
    INFO [muorb] [qshell] qshell gotten: temperature_compensation start
    INFO [muorb] [qshell] arg0 = 'temperature_compensation'
    INFO [uORB] Advertising remote topic sensor_correction
    INFO [muorb] [qshell] Ok executing command: temperature_compensation start
    INFO [qshell] qshell return value timestamp: 211467706, local time: 211471033
    Looking for qmc5883l magnetometer
    INFO [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'
    INFO [muorb] [qshell] qshell gotten: qmc5883l start -R 10 -X -b 1
    INFO [muorb] [qshell] arg0 = 'qmc5883l'
    INFO [muorb] [qshell] arg2 = '-R'
    INFO [muorb] [qshell] arg3 = '10'
    INFO [muorb] [qshell] arg4 = '-X'
    INFO [muorb] [qshell] arg5 = '-b'
    INFO [muorb] [qshell] arg6 = '1'
    INFO [muorb] [drivers__device] *** I2C Device ID 0x80d09 527625
    INFO [muorb] [drivers__device] Set up I2C bus mutex for bus 1
    INFO [muorb] qmc5883l #0 on I2C bus 1
    INFO [muorb] (external)
    INFO [muorb] address 0xD
    INFO [muorb] rotation 10
    INFO [muorb]
    INFO [muorb] [qshell] Ok executing command: qmc5883l start -R 10 -X -b 1
    INFO [qshell] qshell return value timestamp: 211508749, local time: 211510033
    Looking for ist8310 magnetometer
    INFO [muorb] [qshell] qshell gotten: ist8310 start -R 10 -X -b 1
    INFO [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
    INFO [muorb] [qshell] arg0 = 'ist8310'
    INFO [muorb] [drivers__device] *** I2C Device ID 0x60e09 396809
    ERROR [muorb] [drivers__device] i2c probe failed
    INFO [muorb] [SPI_I2C] PX4_qshell: no instance started (no device on bus?)
    ERROR [muorb] [qshell] Failed to execute command: ist8310 start -R 10 -X -b 1
    INFO [qshell] cmd returned with: -1
    INFO [qshell] qshell return value timestamp: 211536822, local time: 211541301
    ERROR [qshell] Command failed
    Looking for ist8308 magnetometer
    INFO [qshell] Send cmd: 'ist8308 start -R 12 -X -b 1'
    INFO [muorb] [qshell] qshell gotten: ist8308 start -R 12 -X -b 1
    INFO [muorb] [qshell] arg0 = 'ist8308'
    INFO [muorb] [qshell] arg3 = '12'
    INFO [muorb] [drivers__device] *** I2C Device ID 0xb0c09 723977
    ERROR [muorb] [qshell] Failed to execute command: ist8308 start -R 12 -X -b 1
    INFO [qshell] qshell return value timestamp: 211592767, local time: 211594905
    INFO [qshell] Send cmd: 'gps start'
    INFO [muorb] [qshell] qshell gotten: gps start
    INFO [muorb] [qshell] arg0 = 'gps'
    INFO [muorb] [tasks] Creating pthread gps
    INFO [muorb] [tasks] Successfully created px4 task PX4_gps with tid 2097647
    INFO [muorb] [qshell] Ok executing command: gps start
    INFO [qshell] qshell return value timestamp: 211620958, local time: 211622253
    Looking for ncp5623c RGB LED
    INFO [uORB] Advertising remote topic sensor_mag
    INFO [muorb] [gps] GPS UART baudrate set to 115200
    INFO [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
    INFO [muorb] [qshell] qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    INFO [muorb] [qshell] arg0 = 'rgbled_ncp5623c'
    INFO [muorb] [qshell] arg2 = '-X'
    INFO [muorb] [qshell] arg4 = '1'
    INFO [muorb] [qshell] arg5 = '-f'
    INFO [muorb] [qshell] arg6 = '400'
    INFO [uORB] Advertising remote topic sensor_baro
    INFO [muorb] [qshell] arg7 = '-a'
    INFO [muorb] [qshell] arg8 = '56'
    INFO [muorb] [drivers__device] *** I2C Device ID 0x7b3809 8075273
    INFO [muorb] [drivers__device] Set i2c address 0x38, fd 4
    ERROR [muorb] [qshell] Failed to execute command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    INFO [qshell] qshell return value timestamp: 211659904, local time: 211662135
    Starting VOXL ESC driver
    INFO [qshell] Send cmd: 'voxl_esc start'
    INFO [muorb] [qshell] qshell gotten: voxl_esc start
    INFO [muorb] [qshell] arg0 = 'voxl_esc'
    INFO [uORB] Advertising remote topic actuator_outputs
    INFO [muorb] [voxl_esc] Starting VOXL ESC driver
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_CONFIG: 1
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_MODE: 0
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_BAUD: 250000
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_FUNC1: 104
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_FUNC2: 101
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_FUNC3: 103
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_FUNC4: 102
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_SDIR1: 1
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_SDIR2: 1
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_SDIR3: 1
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_SDIR4: 1
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_RPM_MIN: 1500
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_RPM_MAX: 12000
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_PERC: 90
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_DEAD: 20
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_EXPO: 35
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_MINF: 0.150000
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_COSP: 0.990000
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_VLOG: 1
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_PUB_BST: 1
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_WARN: 0
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_OVER: 0
    INFO [muorb] [voxl_esc] Params: GPIO_CTL_CH: 0
    INFO [muorb] [qshell] Ok executing command: voxl_esc start
    INFO [muorb] [voxl_esc] Opening UART ESC device 2, baud rate 250000
    INFO [muorb] [voxl_esc] Successfully opened UART ESC device
    INFO [muorb] [voxl_esc] Detecting ESCs...
    INFO [muorb] [voxl_esc] ESC ID : 0
    INFO [muorb] [voxl_esc] Board Type : 42: ModalAi 4-in-1 ESC (M0138-1)
    INFO [muorb] [voxl_esc] Unique ID : 0x2030303355465715004A0021
    INFO [qshell] qshell return value timestamp: 211799981, local time: 211806814
    INFO [muorb] [voxl_esc] Firmware : version 39, hash e4f576a0
    INFO [muorb] [voxl_esc] Bootloader : version 184, hash e1c038de
    INFO [muorb] [voxl_esc] Reply time : 2538us
    INFO [muorb] [voxl_esc] VOXL_ESC:
    INFO [muorb] [voxl_esc] ESC ID : 1
    INFO [muorb] [voxl_esc] Unique ID : 0x2030303355465715003B001E
    INFO [muorb] [voxl_esc] Reply time : 3147us
    INFO [muorb] [voxl_esc] ESC ID : 2
    Starting CRSF RC driver
    INFO [muorb] [voxl_esc] Unique ID : 0x20303033554657150048001F
    INFO [muorb] [voxl_esc] Reply time : 3800us
    INFO [muorb] [voxl_esc] ESC ID : 3
    INFO [muorb] [voxl_esc] Unique ID : 0x2030303355465715002E0020
    INFO [muorb] [voxl_esc] Reply time : 3141us
    INFO [muorb] [voxl_esc] Use extened rpm packet : 1
    INFO [muorb] [voxl_esc] All ESCs successfully detected
    INFO [qshell] Send cmd: 'crsf_rc start -d 7'
    INFO [muorb] [qshell] qshell gotten: crsf_rc start -d 7
    INFO [muorb] [qshell] arg0 = 'crsf_rc'
    INFO [muorb] [qshell] arg2 = '-d'
    INFO [muorb] [qshell] arg3 = '7'
    INFO [muorb] [qshell] Ok executing command: crsf_rc start -d 7
    INFO [muorb] [crsf_rc] Crsf serial opened sucessfully
    INFO [muorb] [crsf_rc] Crsf serial is single wire. Telemetry disabled
    INFO [uORB] Advertising remote topic input_rc
    INFO [qshell] qshell return value timestamp: 211853575, local time: 211856609
    INFO [uORB] Advertising remote topic actuator_outputs_debug
    INFO [uORB] Advertising remote topic esc_status
    INFO [qshell] Send cmd: 'voxlpm start -X -b 2'
    INFO [muorb] [qshell] qshell gotten: voxlpm start -X -b 2
    INFO [muorb] [qshell] arg0 = 'voxlpm'
    INFO [muorb] [qshell] arg4 = '2'
    INFO [muorb] [drivers__device] *** I2C Device ID 0xd24411 13779985
    INFO [muorb] [drivers__device] Set up I2C bus mutex for bus 2
    INFO [muorb] [drivers__device] Set i2c address 0x6a, fd 5
    INFO [muorb] [drivers__device] Set i2c address 0x44, fd 5
    ERROR [muorb] [qshell] Failed to execute command: voxlpm start -X -b 2
    INFO [qshell] qshell return value timestamp: 211911245, local time: 211914428
    INFO [qshell] Send cmd: 'sensors start'
    INFO [muorb] [qshell] qshell gotten: sensors start
    INFO [muorb] [qshell] arg0 = 'sensors'
    INFO [uORB] Advertising remote topic sensor_selection
    INFO [uORB] Advertising remote topic sensors_status_imu
    INFO [uORB] Advertising remote topic vehicle_acceleration
    INFO [uORB] Advertising remote topic vehicle_angular_velocity
    INFO [uORB] Advertising remote topic sensor_combined
    INFO [uORB] Advertising remote topic battery_status
    INFO [uORB] Advertising remote topic vehicle_air_data
    INFO [uORB] Advertising remote topic vehicle_gps_position
    INFO [uORB] Advertising remote topic vehicle_magnetometer
    INFO [uORB] Advertising remote topic sensor_preflight_mag
    INFO [uORB] Advertising remote topic sensors_status_mag
    INFO [uORB] Advertising remote topic vehicle_imu
    INFO [uORB] Advertising remote topic vehicle_imu_status
    INFO [muorb] [qshell] Ok executing command: sensors start
    INFO [qshell] qshell return value timestamp: 212095544, local time: 212100016
    INFO [uORB] Advertising remote topic sensors_status_baro
    INFO [qshell] Send cmd: 'ekf2 start'
    INFO [muorb] [qshell] qshell gotten: ekf2 start
    INFO [muorb] [qshell] arg0 = 'ekf2'
    INFO [uORB] Advertising remote topic vehicle_attitude
    INFO [uORB] Advertising remote topic vehicle_local_position
    INFO [uORB] Advertising remote topic estimator_event_flags
    INFO [uORB] Advertising remote topic estimator_innovation_test_ratios
    INFO [uORB] Advertising remote topic estimator_innovation_variances
    INFO [uORB] Advertising remote topic estimator_innovations
    INFO [uORB] Advertising remote topic estimator_sensor_bias
    INFO [uORB] Advertising remote topic estimator_states
    INFO [uORB] Advertising remote topic estimator_status_flags
    INFO [muorb] [qshell] Ok executing command: ekf2 start
    INFO [uORB] Advertising remote topic ekf2_timestamps
    INFO [uORB] Advertising remote topic vehicle_odometry
    INFO [uORB] Advertising remote topic estimator_aid_src_fake_pos
    INFO [uORB] Advertising remote topic estimator_aid_src_fake_hgt
    INFO [uORB] Advertising remote topic estimator_aid_src_mag_heading
    INFO [uORB] Advertising remote topic estimator_aid_src_gravity
    INFO [qshell] qshell return value timestamp: 212264482, local time: 212270715
    INFO [qshell] Send cmd: 'mc_pos_control start'
    INFO [muorb] [qshell] qshell gotten: mc_pos_control start
    INFO [muorb] [qshell] arg0 = 'mc_pos_control'
    INFO [uORB] Advertising remote topic takeoff_status
    INFO [muorb] [qshell] Ok executing command: mc_pos_control start
    INFO [qshell] qshell return value timestamp: 212351878, local time: 212353666
    INFO [qshell] Send cmd: 'mc_att_control start'
    INFO [muorb] [qshell] qshell gotten: mc_att_control start
    INFO [muorb] [qshell] arg0 = 'mc_att_control'
    INFO [uORB] Advertising remote topic estimator_aid_src_baro_hgt
    INFO [muorb] [qshell] Ok executing command: mc_att_control start
    INFO [qshell] qshell return value timestamp: 212387868, local time: 212389654
    INFO [qshell] Send cmd: 'mc_rate_control start'
    INFO [muorb] [qshell] qshell gotten: mc_rate_control start
    INFO [muorb] [qshell] arg0 = 'mc_rate_control'
    INFO [uORB] Advertising remote topic rate_ctrl_status
    INFO [muorb] [qshell] Ok executing command: mc_rate_control start
    INFO [qshell] qshell return value timestamp: 212448566, local time: 212452284
    INFO [qshell] Send cmd: 'mc_hover_thrust_estimator start'
    INFO [muorb] [qshell] qshell gotten: mc_hover_thrust_estimator start
    INFO [muorb] [qshell] arg0 = 'mc_hover_thrust_estimator'
    INFO [muorb] [qshell] Ok executing command: mc_hover_thrust_estimator start
    INFO [qshell] qshell return value timestamp: 212509852, local time: 212513050
    INFO [qshell] Send cmd: 'mc_autotune_attitude_control start'
    INFO [muorb] [qshell] qshell gotten: mc_autotune_attitude_control start
    INFO [muorb] [qshell] arg0 = 'mc_autotune_attitude_control'
    INFO [uORB] Advertising remote topic autotune_attitude_control_status
    INFO [muorb] [qshell] Ok executing command: mc_autotune_attitude_control start
    INFO [qshell] qshell return value timestamp: 212547374, local time: 212549706
    INFO [qshell] Send cmd: 'land_detector start multicopter'
    INFO [muorb] [qshell] qshell gotten: land_detector start multicopter
    INFO [muorb] [qshell] arg0 = 'land_detector'
    INFO [muorb] [qshell] arg2 = 'multicopter'
    INFO [muorb] [qshell] Ok executing command: land_detector start multicopter
    INFO [qshell] qshell return value timestamp: 212585335, local time: 212585998
    INFO [uORB] Advertising remote topic vehicle_land_detected
    INFO [qshell] Send cmd: 'manual_control start'
    INFO [muorb] [qshell] qshell gotten: manual_control start
    INFO [muorb] [qshell] arg0 = 'manual_control'
    INFO [muorb] [qshell] Ok executing command: manual_control start
    INFO [uORB] Advertising remote topic manual_control_setpoint
    INFO [qshell] qshell return value timestamp: 212623416, local time: 212626408
    INFO [qshell] Send cmd: 'control_allocator start'
    INFO [muorb] [qshell] qshell gotten: control_allocator start
    INFO [muorb] [qshell] arg0 = 'control_allocator'
    INFO [uORB] Advertising remote topic control_allocator_status
    INFO [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
    INFO [uORB] Advertising remote topic actuator_motors
    INFO [uORB] Advertising remote topic actuator_servos
    INFO [uORB] Advertising remote topic actuator_servos_trim
    INFO [muorb] [qshell] Ok executing command: control_allocator start
    INFO [qshell] qshell return value timestamp: 212776930, local time: 212779497
    INFO [qshell] Send cmd: 'load_mon start'
    INFO [muorb] [qshell] qshell gotten: load_mon start
    INFO [muorb] [qshell] arg0 = 'load_mon'
    INFO [muorb] [qshell] Ok executing command: load_mon start
    INFO [uORB] Advertising remote topic cpuload
    INFO [qshell] qshell return value timestamp: 212826033, local time: 212827740
    INFO [qshell] Send cmd: 'rc_update start'
    INFO [muorb] [qshell] qshell gotten: rc_update start
    INFO [muorb] [qshell] arg0 = 'rc_update'
    INFO [muorb] [qshell] Ok executing command: rc_update start
    INFO [uORB] Advertising remote topic rc_channels
    INFO [qshell] qshell return value timestamp: 212954650, local time: 212958731
    INFO [qshell] Send cmd: 'commander start'
    INFO [muorb] [ekf2] resetQuatStateYaw called: -0.968698 (0.090000)
    INFO [muorb] [qshell] qshell gotten: commander start
    INFO [muorb] [qshell] arg0 = 'commander'
    INFO [muorb] [tasks] Creating pthread commander
    INFO [muorb] [tasks] Successfully created px4 task PX4_commander with tid 2097640
    INFO [uORB] Advertising remote topic led_control
    INFO [muorb] [commander] LED: open /dev/led0 failed (22)
    INFO [muorb] [qshell] Ok executing command: commander start
    INFO [uORB] Advertising remote topic tune_control
    INFO [qshell] qshell return value timestamp: 213091743, local time: 213094449
    INFO [uORB] Advertising remote topic event
    INFO [uORB] Advertising remote topic health_report
    INFO [uORB] Advertising remote topic failsafe_flags
    INFO [uORB] Advertising remote topic actuator_armed
    INFO [uORB] Advertising remote topic vehicle_control_mode
    INFO [uORB] Advertising remote topic vehicle_status
    INFO [uORB] Advertising remote topic failure_detector_status
    INFO [uORB] Advertising remote topic vehicle_thrust_setpoint
    INFO [uORB] Advertising remote topic vehicle_torque_setpoint
    INFO [uORB] Advertising remote topic vehicle_attitude_setpoint
    INFO [uORB] Advertising remote topic vehicle_rates_setpoint
    INFO [qshell] Send cmd: 'flight_mode_manager start'
    INFO [muorb] [qshell] qshell gotten: flight_mode_manager start
    INFO [muorb] [qshell] arg0 = 'flight_mode_manager'
    INFO [uORB] Advertising remote topic vehicle_command
    INFO [muorb] [qshell] Ok executing command: flight_mode_manager start
    INFO [qshell] qshell return value timestamp: 213156797, local time: 213159088
    INFO [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
    INFO [muorb] [uORB] Advertising remote topic transponder_report
    INFO [muorb] [uORB] Advertising remote topic rtl_time_estimate
    INFO [muorb] [uORB] Advertising remote topic position_setpoint_triplet
    INFO [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
    INFO [muorb] [uORB] Advertising remote topic telemetry_status
    INFO [mavlink] partner IP: 127.0.0.1
    INFO [muorb] [uORB] Advertising remote topic offboard_control_mode
    INFO [muorb] [uORB] Advertising remote topic obstacle_distance
    INFO [muorb] [uORB] Advertising remote topic timesync_status
    INFO [uORB] Advertising remote topic actuator_controls_status_0
    INFO [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
    INFO [muorb] [uORB] Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
    INFO [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
    INFO [px4] Startup script returned successfully
    pxh> INFO [logger] logger started (mode=all)
    INFO [muorb] [gps] GPS UART baudrate set to 9600
    INFO [muorb] [gps] GPS UART baudrate set to 38400
    INFO [muorb] [uORB] Advertising remote topic ping
    INFO [muorb] [gps] GPS UART baudrate set to 57600
    INFO [muorb] [gps] GPS UART baudrate set to 230400
    INFO [muorb] [gps] GPS UART baudrate set to 460800
    INFO [muorb] [gps] GPS UART baudrate set to 921600
    ERROR [muorb] [gps] GPS: failed to set baud rate 19200 on serial port
    INFO [uORB] Advertising remote topic mavlink_log
    INFO [muorb] [health_and_arming_checks] Preflight Fail: Strong magnetic interference
    INFO [muorb] [health_and_arming_checks] Preflight Fail: Yaw estimate error
    INFO [muorb] [gps] No COM port detected
    Alex MayA Alex May
    @Eric-Katzfey Thanks for the information on the magnetometer. We have integrated a different magnetometer and it seems to work. We will work on building the original mag into the image.
    For the GPS, I just did what you suggested and here is the output.
    Alex MayA Alex May
    @Eric-Katzfey the magnetometer is LIS3MDL. When I type "px4-listener sensor_gps" into the command prompt, I get the response "never published".
    Alex MayA Alex May
    Hello, I am trying to hook up a Lumenier RemoteID module which has an integrated M10Q U-blox GPS module and magnetometer to my VOXL 2 Mini and have been unable to get it to be recognized by PX4. Has anyone else tried to connect a similar GPS module to their VOXL 2 or have any recommendations on what to look for? On Lumenier's documentation it claims compatibility with PX4 1.14.0 and above.
    I have verified that the RX and TX cables and I2C cables are all correctly plugged in. The GPS module is blinking green which supposedly means it has a GPS lock according to the documentation I've read.
  • Waterproofing M0166 Camera Lens
    Alex MayA Alex May
    Does anyone have any recommendations for waterproofing the M0166 camera lens for light rain (not submersion) or dew? Or does the lens come with an internal gasket that causes that to be unnecessary?
    We are wanting to use our drone in a field which may have tall grasses that could contain dew. It also may start raining and we want to waterproof the drone good enough to handle a couple minutes of light rain before we are able to get it to safety. Does anyone have any recommendations on that primarily for the camera optics part?
