황인호황
황인호
@황인호
  • Are MCBL-00068 cables any different from regular cables?
    황인호황 황인호
    Cable 4-pin JST USB to Doodle Labs Helix Smart Radio (MCBL-00068)
  • How to access information of the external flight controller at VOXL2?
    황인호황 황인호
    Thank you for your prompt response.
    I have an additional question.
    I have set up the system as you instructed and successfully established a UDP connection for telemetry information using QGC and Mesh (DoodleLab).
    In this state, is it possible to install a separate application on VOXL2 to read telemetry information?
    The reason is that I would also like to store GPS and IMU information within VOXL2 additionally.
    황인호황 황인호
    I have successfully connected an external flight controller that utilizes Ardupilot to VOXL2 via UART.
    Could you please guide me on how to access information (such as GPS and IMU Data) of the external flight controller at VOXL2?
    I apologize if these questions seem basic; I am still a novice developer.
  • How can I use both Doodle and Quectel together?
    황인호황 황인호
    I'm trying to configure the modem of VOXL2.
    After configuring Doodle, when I try to configure Quectel, the IP settings of Doodle get erased.
    Similarly, if I configure Quectel first and then Doodle, the IP settings of Quectel get erased.
    As a result, I'm unable to configure both of them.
  • Connecting FLIR Hadron 640R Camera Module
    황인호황 황인호
    I try to connect FLIR Hadron 640R Camera Module to VOXL2.
    ( FLIR Hadron 640R : https://www.flir.com/products/hadron-640r/ )
    I wonder this is possible.
    If this is possible, is it possible to save a captured image of the camera as VOXL2 without additional programming?
  • HDMI-CSI bridge driver on VOXL2
    황인호황 황인호
    @Chad-Sweet
    I found this. The 5G modem board also has a USB 3 port.
    Then, all I need is this cable.
    https://www.modalai.com/collections/cables-1/products/mcbl-00022
    황인호황 황인호
    @Chad-Sweet
    Thank you for reply.
    But, If I use this USB 3 adapter, 5G modem board is not useable. Right?
    황인호황 황인호
    @Chad-Sweet
    Where can I connect 'HDMI to USB 3 adapter' to VOXL2 board?
