VOXL streaming has at least 2-3s delay for default 640x480 using hires
Hi team,
The voxl-streaming via wifi connection has a noticeable video delay (2-3s), and I am using the default hires setup with just 640x480.I am wondering how to speed up the voxl-streaming for a real-time video transmission like an FPV mode?
Is it due to a wifi connection? Or if changing to an LTE connection, voxl-streaming could easily speed up to achieve a real-time performance?
What are you using to view the stream? We generally find that if you're streaming via voxl-portal or ros the stream will be almost real-time, but if you're using vlc there will be a significant delay
Hi @yu-zhang i might have the answer about use ros to view stream here.
On voxlyocto:~$ roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launchOn pc
rqt_image_viewThen select the img topic you interested.
And remember to make sure that the ip config on both side is correct.voxl's ros ip is in my_ros_env.sh and for pc edit in .bashrc.
detail in https://docs.modalai.com/setup-ros-on-voxl/
Hope that will help you
