  3. VOXL streaming has at least 2-3s delay for default 640x480 using hires
m500
5 Posts 3 Posters 1.2k Views
  • yu zhangY Offline
    yu zhangY Offline
    yu zhang
    Hi team,
    The voxl-streaming via wifi connection has a noticeable video delay (2-3s), and I am using the default hires setup with just 640x480.
    I am wondering how to speed up the voxl-streaming for a real-time video transmission like an FPV mode?
    Is it due to a wifi connection? Or if changing to an LTE connection, voxl-streaming could easily speed up to achieve a real-time performance?
    • ? Offline
      What are you using to view the stream? We generally find that if you're streaming via voxl-portal or ros the stream will be almost real-time, but if you're using vlc there will be a significant delay
      yu zhangY 1 Reply Last reply
      • ? A Former User
        yu zhangY Offline
        yu zhangY Offline
        yu zhang
        Hi @Alex-Gardner Yes, I am using vlc and the delay is quite strong.
        voxl-portal is a good option and I will have a look at it.
        I am also wondering how to use ros to view the stream? Can you please introduce a bit about it? Thanks.
        • 張為超張 Offline
          張為超張 Offline
          張為超
          Hi @yu-zhang i might have the answer about use ros to view stream here.
          On voxl
          yocto:~$ roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
          On pc
          rqt_image_view
          Then select the img topic you interested.
          And remember to make sure that the ip config on both side is correct.voxl's ros ip is in my_ros_env.sh and for pc edit in .bashrc.
          detail in https://docs.modalai.com/setup-ros-on-voxl/
          Hope that will help you 🙂
          • 張為超張 張為超
            On voxl
            On pc
            rqt_image_view
            yu zhangY Offline
            yu zhangY Offline
            yu zhang
            Hi @張為超 All right, thanks so much for that, and I will then have a look at it 😉
