  3. using wifi 5ghz instead of 2.4ghz
flight-deck
3 Posts 2 Posters 728 Views 2 Watching
  • Zeev MindaliZ Offline
    Zeev Mindali
    Dear all,
    i saw on the wifi antennas that they can operate in 2.4 and 5 ghz.
    i tried to connect to 5ghz wifi with no success.
    does the flight deck support 5ghz and if yes, how can activate it?
    zeev
      If you are in station mode, just connect to a 5GHz access point
      If you are in host mode, I think you would modify /data/misc/wifi/hostapd.conf with the appropriate channel
        Zeev Mindali
        too much setting with ads shell.
        I started to wrote entire web application, so I can change the values like every normal device have (such as routers)
        too many parameters to work with in add shell.
