  3. ToF sensor
ToF sensor
rostof
29 Posts 4 Posters 9.5k Views 6 Watching
  • G Offline
    G Offline
    gauravshukla914
    Hi, we purchased the ToF camera and are having a problem running the ToF launch file. We are getting this error - Camera Width: 224, Height: 1557, Format: 33 not supported!
    Here are the topics that we are getting
    /rosout
    /rosout_agg
    /tf_static
    I'm also attaching the screenshot here.
    ![alt text](tof_error.png image url)
    And we have replaced the stereo camera with the ToF on J3.
    On camera configuration, we have selected the Option 5 (ToF + Tracking.)
    Please let us know what we are doing wrong. Looking forward to your reply.
      Will look into it, thanks.
      • H Offline
        H Offline
        hitendra
        That error happens when we dont set up TOF_CAM_ID environment variable or it is setup incorrectly. The environment variable is set by running the voxl-configure-cameras script. If you havent run the script, could you please try running it. To verify it quickly you can try to directly modify the TOF_CAM_ID environment variable.
        On the voxl run:
        export TOF_CAM_ID=0
        and try running the app again.
        G 1 Reply Last reply
        • H hitendra
          On the voxl run:
          export TOF_CAM_ID=0
          G Offline
          G Offline
          gauravshukla914
          @hitendra Hi. Thanks for your reply.
          We did select the option 5 and we did an echo $TOF_CAM_ID, and we got result as 0.
          We also tried option 6 and we got the result as 1. SO it confirms that the variable TOF_CAM_ID was setting properly to 0 and 1 wrt to the configuration parametrs 5 and 6.
          We are still facing the same issue.
          • G Offline
            G Offline
            gauravshukla914
            Hello. A quick update. We resolved that issue by change the image width and height to 640 and 480 respectively in the hello_hal3_camera_main.cpp file on line 68 and line 69. We are now able to see the list of the topics, but these topics are not publishing anything. Assuming, it could be an error of a missing file mentioned below.
            /data/misc/camera/irs10x0c_lens.cal
            We looked into this directory but could not find this file. I'm attaching a screenshot of the same.Screenshot from 2021-01-11 16-57-42.png
            • G Offline
              G Offline
              gauravshukla914
              wrote on last edited by gauravshukla914
              how can I get this file? irs10x0c_lens.cal
              I purchased this tof addon :
              https://www.modalai.com/pages/tof-add-on
              Do I have to calibrate it?
              None of the topics are publishing anying.
              There is no image data.
                @gauravshukla914 ,
                I'm not aware of any calibration required for ToF.... This procedure should work out the box so I'm confused: https://gitlab.com/voxl-public/ros/voxl-hal3-tof-cam-ros#visualization
                I'm sure you have this correct, but where have you attached the camera? It should be connected to J3 here: https://docs.modalai.com/camera-connections/#camera-ports
                • modaltbM modaltb
                  @gauravshukla914 ,
                  G Offline
                  G Offline
                  gauravshukla914
                  @modaltb Yes I have attached it properly to J3 and we followed the same process but when I launch the file it says the file /data/misc/camera/irs10x0c_lens.cal is missing. I looked into the directory as well there is not such file exist.
                  I tried this and I do get frames out of it. So that means it is attached properly
                  https://gitlab.com/voxl-public/other/apps-proc-examples/-/tree/dev/hellotof
                  • H Offline
                    H Offline
                    hitendra
                    Hi:
                    Could you please list the content of your /data/misc/camera directory? I am wondering if the process of generating that file was interrupted and now it doesn't attempt to generate it anymore.
                    If there is anything in the /data/misc/camera directory I would move it to another temp directory - say /data/misc/camera/temp and try running the app again.
                    Also as a quick experiment, I would put in just the TOF camera, remove other cameras and run the app again to see if it helps.
                    • H hitendra
                      Hi:
                      G Offline
                      G Offline
                      gauravshukla914
                      #10
                      @hitendra Thanks for the suggestions.
                      Here is the list of file present in data/misc/camera directory
                      each of these files are just have these of 0 bytes each
                      default installed voxl_hal3_tof package gives error as resolution not supported. And changing the resolution from the source as we did mentioned earlier does run the package but than stops at irs10x0c_lens.cal file being missing
                      after changing the resolution and compiling again
                      and hence topics are created but they don't publish any data
                        That lens cal file is created the first time the driver is launched, it does take about 20 seconds to generate. Changing the resolution in the code probably is just covering up the fact the TOF camera isn't launching.
                        The CAM_ID changes based on which sensors are plugged in due to a quirk in the Qualcomm camera subsystem. It's most likely the wrong CAM_ID is being assigned to TOF in the config. Maybe a camera is/was unplugged?
                        • G Offline
                          G Offline
                          gauravshukla914
                          yocto:/# voxl-configure-cameras
                          Which camera configuration are you using?
                          1 Tracking + Stereo (default)
                          2 Tracking Only
                          3 Hires + Stereo + Tracking
                          4 Hires + Tracking
                          5 TOF + Tracking
                          6 Hires + TOF + Tracking
                          7 TOF + Stereo + Tracking (not currently supported)
                          8 None
                          attempting to use camera configuration 5
                          adding override_cam_id value=1 to /etc/snav/camera.downward.xml
                          adding override_cam_id value=-1 to /etc/snav/camera.stereo.xml
                          yocto:/# echo $TOF_CAM_ID
                          yocto:/# roslaunch /opt/ros/indigo/share/voxl_hal3_tof_cam_ros/launch/tof.launch
                          ... logging to /home/root/.ros/log/34d08072-55bb-11eb-aee3-ec5c68cd1745/roslaunch-apq8096-3324.log
                          Checking log directory for disk usage. This may take awhile.
                          Press Ctrl-C to interrupt
                          started roslaunch server http://192.168.100.96:36814/
                          SUMMARY
                          PARAMETERS
                           * /rosdistro: indigo
                           * /rosversion: 1.11.21
                           * /tof/voxl_hal3_tof_cam_ros_node/auto_exposure: 0
                           * /tof/voxl_hal3_tof_cam_ros_node/camera_id: 0
                           * /tof/voxl_hal3_tof_cam_ros_node/exposure_time: 800
                           * /tof/voxl_hal3_tof_cam_ros_node/flip_image: True
                           * /tof/voxl_hal3_tof_cam_ros_node/frame_rate: 30
                           * /tof/voxl_hal3_tof_cam_ros_node/ir_image_mode: False
                           * /tof/voxl_hal3_tof_cam_ros_node/laser_scan_line: 86
                           * /tof/voxl_hal3_tof_cam_ros_node/publish_depth_image: True
                           * /tof/voxl_hal3_tof_cam_ros_node/publish_ir_image: True
                           * /tof/voxl_hal3_tof_cam_ros_node/publish_laser_scan: True
                           * /tof/voxl_hal3_tof_cam_ros_node/publish_point_cloud: True
                           * /tof/voxl_hal3_tof_cam_ros_node/scan_width_degrees: 96
                          NODES
                            /tof/
                              voxl_hal3_tof_cam_ros_node (voxl_hal3_tof_cam_ros/voxl_hal3_tof_cam_ros_node)
                              base_link_laser_scan (tf2_ros/static_transform_publisher)
                              base_link_tof_cam (tf2_ros/static_transform_publisher)
                          auto-starting new master
                          process[master]: started with pid [3343]
                          ROS_MASTER_URI=http://localhost:11311/
                          setting /run_id to 34d08072-55bb-11eb-aee3-ec5c68cd1745
                          process[rosout-1]: started with pid [3356]
                          process[base_link_tof_cam-2]: started with pid [3371]
                          process[base_link_laser_scan-3]: started with pid [3378]
                          process[tof/voxl_hal3_tof_cam_ros_node-4]: started with pid [3386]
                          	DEPTH_IMAGE
                          	IR: 1 ..... Cloud: 1 ..... Laser: 1
                          Camera id: 0
                          Image width: 224
                          Image height: 1557
                          Number of frames to dump: 0
                          Camera mode: preview
                          SUCCESS: Camera module opened
                          Camera Id: 0 Facing: 1
                          ERROR: Libcamera sending post-processed TOF data. App does NOT get RAW16 TOF camera data
                          [tof/voxl_hal3_tof_cam_ros_node-4] process has finished cleanly
                          log file: /home/root/.ros/log/34d08072-55bb-11eb-aee3-ec5c68cd1745/tof-voxl_hal3_tof_cam_ros_node-4*.log
                          ^C[base_link_laser_scan-3] killing on exit
                          [base_link_tof_cam-2] killing on exit
                          [rosout-1] killing on exit
                          [master] killing on exit
                          shutting down processing monitor...
                          yocto:/# ls /data/misc/camera/
                          cam_socket2  cam_socket3  cam_socket4  temp
                          yocto:/#
                          I don't know what else I am missing
                            You're selecting TOF+Tracking, but there is no tracking sensor installed. So the TOF_CAM_ID is probably coming out incorrect.
                            Do you have a tracking camera? If so, please power off and install
                            If not, can you please try export TOF_CAM_ID=1 ?
                            thanks!
                            • Chad SweetC Chad Sweet
                              thanks!
                              G Offline
                              G Offline
                              gauravshukla914
                              @Chad-Sweet
                              we installed tracking camera and reconfigured voxl using voxl-configure-camera
                              and tracking camera is working
                              than we tried to run tof package again but still the problem persist. we even tried to change the TOF_CAM_ID but still no change.
                              yocto:/# roslaunch voxl_hal3_tof_cam_ros tof.launch
                              ... logging to /home/root/.ros/log/3f833ac4-55c4-11eb-a699-ec5c68cd1745/roslaunch-apq8096-4079.log
                              started roslaunch server http://192.168.100.96:55989/
                              SUMMARY
                              PARAMETERS
                              NODES
                                /tof/
                              process[master]: started with pid [4098]
                              setting /run_id to 3f833ac4-55c4-11eb-a699-ec5c68cd1745
                              process[rosout-1]: started with pid [4111]
                              process[base_link_tof_cam-2]: started with pid [4124]
                              process[base_link_laser_scan-3]: started with pid [4129]
                              process[tof/voxl_hal3_tof_cam_ros_node-4]: started with pid [4141]
                              	DEPTH_IMAGE
                              Camera id: 0
                              Image width: 224
                              Image height: 1557
                              Camera Id: 1 Facing: 1
                              log file: /home/root/.ros/log/3f833ac4-55c4-11eb-a699-ec5c68cd1745/tof-voxl_hal3_tof_cam_ros_node-4*.log
                              ... shutting down processing monitor complete
                              done
                              yocto:/#
                                OK, good the tracking sensor is working. Sorry about this, the tof setup is still in beta. We clearly need to document the setup way better.
                                Can you please print which version of system image you are using (voxl-version)? The error implies an older system image which does not support that hal3_tof_cam_ros.
                                The error above implies an older version of libcamera which would use tof_cam_ros instead
                                Just FYI, the TOF_CAM_ID needs to match what is in the launch file. This message shows what is in the launch file:
                                  G Offline
                                  G Offline
                                  gauravshukla914
                                  @Chad-Sweet
                                  system-image:    ModalAI 3.1.0 BUILDER: ekatzfey BUILD_TIME: 2020-12-23_19:41
                                  kernel:          #1 SMP PREEMPT Wed Dec 23 19:50:23 UTC 2020 3.18.71-perf
                                  architecture:    aarch64
                                  processor:       apq8096
                                  os:              GNU/Linux
                                  voxl-suite:
                                  Package: voxl-suite
                                  Version: 0.2.0
                                  Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
                                  Section: base
                                  Architecture: armv7a
                                  Maintainer: james@modalai.com
                                  MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
                                  Filename: voxl-suite_0.2.0.ipk
                                  Description: meta-package to install all of the voxl-suite
                                  Installed-Time: 3126
                                  according to git repository launch file is taking tof cam id from environment variable and we select option 5 from voxl-configure-camera which sets accordingly
                                    #17
                                    that all looks good. Will investigate further
                                    • G Offline
                                      G Offline
                                      gauravshukla914
                                      Okay. Looking forward to your solution asap!
                                        Can you please type and report the output?
                                        opkg list-installed | grep royal
                                          Assuming the ipk is installed, can you please then run this command and then try the ROS node again?
                                          setprop persist.camera.modalai.tof 1
