    Overriding in-use UART ports
    • G
      gus
      Hi, I would like to use more than 4 UART ports on my Flight Core. Is it possible to override the non-default (GPS1, tel1-3) ports to enable additional serial port usage? For instance, could I use port J6 as an additional TEL4 port, by adding TEL4:/dev/ttyS3 below the TEL3 line?
      I am not using this port for battery messages (instead using dshot telemetry) so I could do this if the port configuration is viable, but I'm worried that making this change will screw something up on the FC, so I don't want to try it without asking here first.
      Is this possible on this port or any other ports? 5 UART ports would be extremely useful to me.
      Gus
      • modaltbM
        modaltb ModalAI Team
        Hi @gus ,
        We haven't tried this on all setups, so there might be some gotchas, but it should work. Likely some customization of course, but underneath it is just a UART and you can tweak things.
        A (pre released) example of me using this for a UART ESC is in this branch:
        https://github.com/modalai/px4-firmware/tree/modalai-1.11
        Check out this commit:
        https://github.com/modalai/px4-firmware/commit/1dfa9feba729a243d60bbaa8fa9f8fcb226404ac
        Here I use /dev/ttyS1 (telem3, USART2, J4) for an interface to our UART ESC.
        Lot's of the code in that commit is obviously not applicable, but here's where I'm opening the port:
        https://github.com/modalai/px4-firmware/commit/1dfa9feba729a243d60bbaa8fa9f8fcb226404ac#diff-fe5217d5827b686586f293d2c0d790a79d798e206d9932b1d47cd1749280e2d8R56
        And where I start things up:
        https://github.com/modalai/px4-firmware/commit/1dfa9feba729a243d60bbaa8fa9f8fcb226404ac#diff-54ee1de5bd31b9863085c67e1dc867182fa176b992549ba6e25e9f5d57e5625dR9
        Holler if you have any questions, I wrote that some time back but I don't remember any gotchas.
        Travis
        G 1 Reply Last reply Reply Quote 0
        • G
          gus @modaltb
          @modaltb Great, I will check this out, thanks so much.
          • Sem AndewegS
            Sem Andeweg
            @gus and @modaltb did this work?
            In our setup we are two UART short.
            We would like to use 2 UART ports for:
            1. TELEM3 (DJI FPV)
            2. Dshot telemetry
            The UART ports that we don't use are:
            1. J2 Debug
            2. J4 UART ESC
            How could we use these existing UART ports the way we would like to?
            • modaltbM
              @Sem-Andeweg I haven't personally tried, but:
              J4 on Flight Core is by default a TELEM3 so should be OK to just use (3.3V TTL) https://docs.modalai.com/flight-core-datasheets-connectors/#j4---uart-esc-uart2telem3
              J2 by default is the nuttx shell interface. I have always left this as I use it for debug.... but I believe you could remap it.
              There are some limitations on number of MAVLink instances in PX4, but both your use cases above sound like "not MAVLink", so it would be a matter of messing around with the source code a bit.
