  3. Roll failure detected once I have the visio for local position
voxl-cam
5 Posts 2 Posters 1.2k Views 2 Watching
  • M Offline
    M Offline
    marian
    I calibrated the accelerometer using ROTATION_NONE as per https://docs.modalai.com/px4-calibrate-sensors/
    And I use the ekf2 params setup as per https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/helpers/rb5/ekf2_indoor_vio.params
    I have a roll failure detected once I have the local position via the voxl cam system. And the flight controller shows a 90 degrees roll rotation.
    Any help will be great!
      The relevant PX4 parameters for VOXL CAM are found in the 'Seeker' directory here: https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/tree/master/helpers/seeker
      • M Offline
        M Offline
        marian
        Thanks! I will take a look and verify all the params from the location above.
        • M Offline
          M Offline
          marian
          wrote on last edited by marian
          @Chad-Sweet Hi Chad, I took a look at the parameters you send me, but there is nothing about the Rotation of the board. These params are installed on my board, but the results are the same:
          • whenever I use it for indoor I have a roll failure detected once I have the visio for local position
          • whenever I use it for outdoor, so I added a M8N u-bloz GPS with compass, I can't calibrate de comapss because the position indicated on the QGC is different as the position of the drone if ROTATION-NONE is selected. And by the modal ai doc, it the Ratoation-None that it should be used.
          Is that correct? or do I need to select another ROATION of the board for calibration?
          • M Offline
            M Offline
            marian
            No answer from Chad, so I put the problem again here hoping someone can advice me how to advance with this topic.
            I took a look at the parameters send over, but there is nothing about the rotation of the board. These params are installed on my board, but the results are the same:
            • whenever I use it for indoor, I do the accel & gyro calibration with ROTATION-NONE, but I have a roll failure detected once I try to arm and I got the visio for local position
            • whenever I use it for outdoor, I add a M8N GPS with compass, I can't calibrate de compass because the position indicated on the QGC is different as the position of the drone if ROTATION-NONE is selected.
            By the modalai doc. is ROTATION-NONE that it should be used. Did I get it correctly, or do I need to select another ROTATION value of the board for calibration?
