  2. VOXL SDK and Software
  3. Using libvoxl_io.so from Docker
3 Posts 2 Posters 843 Views 1 Watching
  • A Offline
    amitga
    I understand that currently using libvoxl_io.so from Docker is not supported.
    I wanted to know if it's on your road map, and if so, when can we expect Docker support for this?
    If not, I would like to know what it would take to port it to Docker ?
      It is not currently on the roadmap. You could create a shim by exposing a libmodal_pipe to the docker from the Yocto layer. What specifically are you trying to achieve?
      A 1 Reply Last reply
      • Chad SweetC Chad Sweet
        amitga
        wrote on last edited by amitga
        @Chad-Sweet
        I'm trying to read some sensor data using UART/I2C, from within a Docker container.
        I will look into libmodal_pipe , thanks.
