  2. VOXL SDK and Software
  3. Hadron ov64b snapshots have a vertical image artifact
camera
34 Posts 3 Posters 15.0k Views 2 Watching
    @cguzikowski ,
    I am testing OV64b now. I confirmed that snapshot of size 9216x6944 is not possible (i think i can enable it), but 9248x6944 works.
    Also, please see this post, there was a bug that broke snapshot in recent releases, which i just fixed. perhaps that was an issue for you when you switched to latest camera server : https://forum.modalai.com/topic/5166/snapshot-crashes-voxl-camera-server
    I am going to see if i can get MISP running together with ISP snapshot, right now it only runs when preview and misp are disabled and i have small_video and snapshot streams enabled and snapshot resolution set to 9248x6944 and small_video resolution to something smaller.
    OK, some updates..
    • the reason why the resolution 9216x6944 was not accepted for snapshot is that the camera pipeline has a list of allowed resolutions and that resolution was not one of them. I could add the resolution 9216x6944 to the list, but actually another resolution (9216x6912) was already supported, so i updated the ov64b driver to include that. The latest driver is available here : https://storage.googleapis.com/modalai_public/temp/ov64b/20260417/ov64b_20260417.zip
      • this driver has the following resolutions : 9248x6944, 9216x6944 9216x6912 and the other lower resolutions. You can use 9216x6912 since it's compatible with misp and isp snapshot.
    • I also added 9216x6912 resolution to the supported misp resolutions in camera server (dev branch) as well as allowed using misp with snapshot (previously it would throw an error since we thought that previously they were not compatible).
    • Actually, snapshot does work with raw_preview + misp, but here is a warning that gets printed continuously:
    WARNING: preview buffer pool for Cam(hires), Frame(30) has 0 free, skipping request
    we can work around this warning by adding the following line to the voxl-camera-server.conf for the ov64b camera. this limits the number of buffers that are queued up for the streams and resolves the warning.
    "max_request_queue_depth": 6,
    So with these changes, you should be able to use two configurations
    • preview + raw_preview + misp + snapshot
    • small_video + snapshot
    Please use the latest camera server from dev branch.
    Right now, if you enable misp + small+video + snapshot, it does not work properly, but i will try it figure it out. Here is an example set up for small video + snapshot, but you can easily change it to use misp by disabling small_video and enabling preview + misp (and set auto exposure to "auto" from "isp" (auto will use misp auto exposure)).
    Please try it out. I do agree that the ISP output has better overall image quality than MISP, also related to pretty significant lens shading of this small lens on ov64b. We will work on improvements of misp image processing.
    For now, you just need to decide whether you need both RAW bayer and ISP JPG, in which case you cannot use small_video for streaming (until i resolve the issue). This means slightly worse image quality for live streaming. But if you are ok with ISP jpg, you can disable misp and use small_video stream for streaming.
    By the way, i did not see any artifacts in the jpeg from ISP. Can you please let me know if the artifact is in every frame and where exactly it is located? or is the occurrence and location random?
                            "type":                 "ov64b",
                            "name":                 "hires",
                            "enabled":              true,
                            "camera_id":            1,
                            "fps":                  30,
                            "en_preview":           false,
                            "en_misp":              false,
                            "preview_width":        9216,
                            "preview_height":       6912,
                            "en_raw_preview":       true,
                            "en_small_video":       true,
                            "en_large_video":       false,
                            "en_snapshot":          true,
                            "ae_mode":              "isp",
                            "gain_min":             100,
                            "gain_max":             1600,
                            "misp_width":           1600,
                            "misp_height":          1200,
                            "misp_venc_enable":     false,
                            "misp_venc_mode":       "h265",
                            "misp_venc_br_ctrl":    "cqp",
                            "misp_venc_Qfixed":     38,
                            "misp_venc_Qmin":       15,
                            "misp_venc_Qmax":       50,
                            "misp_venc_nPframes":   29,
                            "misp_venc_mbps":       30,
                            "misp_venc_osd":        false,
                            "misp_awb":             "auto",
                            "misp_gamma":           1,
                            "misp_zoom":            1,
                            "ae_desired_msv":       110,
                            "exposure_min_us":      20,
                            "exposure_max_us":      33000,
                            "exposure_soft_min_us": 5000,
                            "ae_filter_alpha":      0.6,
                            "ae_ignore_fraction":   0.2,
                            "ae_slope":     0.05,
                            "ae_exposure_period":   1,
                            "ae_gain_period":       1,
                            "small_video_width":    1600,
                            "small_video_height":   1200,
                            "small_venc_mode":      "h264",
                            "small_venc_br_ctrl":   "cqp",
                            "small_venc_Qfixed":    30,
                            "small_venc_Qmin":      15,
                            "small_venc_Qmax":      40,
                            "small_venc_nPframes":  9,
                            "small_venc_mbps":      2,
                            "en_snapshot_width":    9216,
                            "en_snapshot_height":   6912,
                            "exif_focal_length":    3.1,
                            "exif_focal_length_in_35mm_format":     17,
                            "exif_fnumber": 1.24,
                            "snapshot_jpeg_quality":        75
      OK, some updates..
                              "type":                 "ov64b",
                              "name":                 "hires",
                              "enabled":              true,
                              "camera_id":            1,
                              "fps":                  30,
                              "en_misp":              false,
                              "ae_mode":              "isp",
                              "gain_min":             100,
                              "gain_max":             1600,
                              "misp_width":           1600,
                              "misp_awb":             "auto",
                              "misp_gamma":           1,
                              "misp_zoom":            1,
                              "ae_slope":     0.05,
      @cguzikowski ,
      Can you please clarify what you meant by the following statement in your previous post:
      "Also as a side note, the metadata seems to not be recording when using voxl-record-raw-image -j"
        @cguzikowski ,
        FYI the voxl-mpa-tools updates have been merged to dev (including the jpeg saving option and option to save timestamp, exposure, gain in the filename -- i think that is what you were referring to). One small change, the timestamp in the filename changed from milliseconds to microseconds.
        https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-tools/-/tree/dev
        C 1 Reply Last reply
          C Offline
          C Offline
          cguzikowski
          @Alex-Kushleyev I have been doing some tests and the updates to the camera server and mpa tools seem to work great, thank you! What I meant about the metadata not recording is this data only shows up when using the snapshot command, and does not show up when using the jpeg flag in the voxl-record-raw-image command:
          Also noticed the auto exposure doesn't seem to settle unless the camera's feed is opened on the voxl-portal. Here are two images I took - voxl-camera-server was running for a considerable time before taking either one.
          Before looking at the live stream in the portal:
          After looking at the stream in the portal for a few seconds (I could see the exposure settle down)
          Didn't mess with voxl-camera-server at all in between taking the two images.
          • C cguzikowski
            @cguzikowski ,
            We can add the jpeg meta to the jpeg file saved from voxl-record-raw-image. which fields specifically are good to have?
            Also, regarding the exposure settling - can you please provide the exact configuration you are running? specifically, which are enabled (misp, small_video, snapshot) and is auto exposure set to "isp" or not -- maybe provide a camera server config? When using MISP, i believe there is a case that if none of the streams are being used, the AE won't run, but we can fix this for the case of enabled snapshot.
              @cguzikowski ,
              C Offline
              C Offline
              cguzikowski
              @Alex-Kushleyev Our application doesn't specifically need the metadata, just figured I should point it out in case it was intended to be there. It may be useful to have shutter speed, ISO, aperture, and date/time though.
              Ah yes that seems to be the issue, we are using MISP, preview, and snapshot. It would be useful to have the AE run without us viewing the stream. Here is the conf file:
              	"version":	0.1,
              	"fsync_en":	false,
              	"fsync_gpio":	109,
              	"cameras":	[{
              			"type":	"boson",
              			"name":	"boson",
              			"enabled":	true,
              			"camera_id":	0,
              			"fps":	30,
              			"en_preview":	true,
              			"en_misp":	true,
              			"preview_width":	640,
              			"preview_height":	512,
              			"en_small_video":	false,
              			"ae_mode":	"off",
              			"en_rotate":	false,
              			"misp_width":	512,
              			"misp_height":	640,
              			"misp_venc_enable":	true,
              			"misp_venc_mode":	"h264",
              			"misp_venc_Qfixed":	30,
              			"misp_venc_mbps":	2,
              			"misp_awb":	"off",
              			"misp_gamma":	1,
              			"misp_zoom":	1,
              			"gain_min":	100,
              			"gain_max":	100
              			"type":	"ov64b",
              			"name":	"hires",
              			"enabled":	true,
              			"camera_id":	1,
              			"fps":	30,
              			"en_preview":	true,
              			"en_misp":	true,
              			"ae_mode":	"isp",
              			"gain_min":	100,
              			"gain_max":	100,
              			"misp_width":	9216,
              			"misp_height":	6912,
              			"misp_awb":	"auto",
              			"misp_gamma":	1,
              			"misp_zoom":	1,
              			"ae_desired_msv":	75,
              			"exposure_min_us":	1000,
              			"exposure_max_us":	1001,
              			"ae_slope":	0.1,
              			"snapshot_jpeg_quality":	90
              • C cguzikowski
                	"version":	0.1,
                	"fsync_en":	false,
                	"fsync_gpio":	109,
                	"cameras":	[{
                			"type":	"boson",
                			"name":	"boson",
                			"enabled":	true,
                			"camera_id":	0,
                			"fps":	30,
                			"en_preview":	true,
                			"en_misp":	true,
                			"ae_mode":	"off",
                			"en_rotate":	false,
                			"misp_width":	512,
                			"misp_height":	640,
                			"misp_awb":	"off",
                			"misp_gamma":	1,
                			"misp_zoom":	1,
                			"gain_min":	100,
                			"gain_max":	100
                			"type":	"ov64b",
                			"name":	"hires",
                			"enabled":	true,
                			"camera_id":	1,
                			"fps":	30,
                			"en_preview":	true,
                			"en_misp":	true,
                			"ae_mode":	"isp",
                			"gain_min":	100,
                			"gain_max":	100,
                			"misp_width":	9216,
                			"misp_awb":	"auto",
                			"misp_gamma":	1,
                			"misp_zoom":	1,
                			"ae_slope":	0.1,
                @cguzikowski , got it, thanks for the clarification. I will add a camera server config param that would force the auto exposure to run all the time, regardless of whether the streams are used or not. this should be simple.
                Also, i was wondering if you decided that the ISP snapshot is good enough for you or you want to explore saving the RAW bayer and processing offline? We have been experimenting with some approaches for offline processing and I can share some scripts, which have some flexibility on how much to de-noise , sharpen, etc. I am also going to add the LSC (lens shading correction) for the offline processing (and later into real-time misp pipeline) to correct for those artifacts that you saw where the colors change across the image.
                C 2 Replies Last reply
                  C Offline
                  C Offline
                  cguzikowski
                  wrote on last edited by cguzikowski
                  #28
                  @Alex-Kushleyev Sorry for the delayed response, but I believe the ISP snapshots are good enough quality for us, but could I still get the scripts to mess around and test with?
                  Also is the most recent camera server here the version with the auto-auto exposure? If so, what is the parameter to use to activate that?
                    C Offline
                    C Offline
                    cguzikowski
                    @Alex-Kushleyev Also just noticed the vertical artifact again. The artifact is only present in the snapshots and not the raw images saved as jpeg - will definitely need those post processing scripts now.
                    Here is the raw image:
                    And here is the snapshot:
                    • C cguzikowski
                      @cguzikowski , thanks for following up.
                      I don't know why the ISP is outputting the jpeg with the issue - that is outside of our area of expertise. It could be a bug in the ISP or JPEG encoder.
                      I will get together some scripts i have been using for testing. I need add the LSC (lens shading correction) otherwise the colors look wrong and also image gets darker towards the edges. In order to apply LSC correction, we need a map (either look-up table or a poly fit) of each channel's response as a function of pixel coordinate (or radius) -- this needs to be calibrated (not for each camera module, but for each camera type + lens type). So after the calibration, my results should apply to your camera as well.
                      I will follow up early next week.
                        @cguzikowski , quick question for you. For your application, does it matter how much time (reasonable) it takes to debayer the image? some of my offline processing scripts are not optimized for real-time operation, but are very flexible to use and the full resolution image from ov64b is huge and it may take a few seconds to process without optimizations.
                        We also have opencl code that runs offline pretty quick on an nvidia GPU, but it does not have as many tuning knobs.
                        I guess it all depends on whether you are using the images right on the voxl2 or just collecting and analyzing offline at a later time.
                          C Offline
                          C Offline
                          cguzikowski
                          @Alex-Kushleyev Thanks for the follow up and working towards the calibration map. For us the real time processing speed doesn't matter too much, but the image file size does as we need to send the unprocessed images over radio in real time. We were hoping to use voxl-record-raw -j -q 90 as this doesn't show the vertical artifact and results in reasonable file sizes.
                            C Offline
                            C Offline
                            cguzikowski
                            @Alex-Kushleyev Hi Alex, just following up to see if it would be possible to get those image processing scripts. Also we have been trying to get the Hadron working on another voxl2 and have followed the same steps you gave before and we are using the same camera server. The boson seems to be working, but the hires camera does not. When both are enabled the camera server starts up and then immediately says "aborted". With the boson disabled I see the following output from voxl-camera-server:
                            MISP channels enabled in defaults : 0
                            MISP channels enabled in config file: 0
                            Setting MISP AWB to Auto
                            max request queue depth: 6
                            configuration for 2 cameras:
                            cam #0
                                type:                boson
                                bayer_type:          0
                                enabled:             0
                                camera_id:           0
                                camera_id_second:    -1
                                fps:                 30
                                en_rotate:           0
                                en_rotate2:          0
                                en_preview:          1
                                en_raw_preview:      1
                                preview_width:       640
                                preview_height:      512
                                en_misp:             1
                                misp_width:          512
                                misp_height:         640
                                en_small_video:      0
                                small_video_width:   640
                                small_video_height:  480
                                en_large_video:      0
                                large_video_width:   -1
                                large_video_height:  -1
                                en_snapshot:         0
                                snap_width:          -1
                                snap_height:         -1
                                exif_focal_length:   0.000000
                                exif_focal_len_35mm_format:0
                                exif_fnumber:        0.000000
                                ae_mode:             off
                                msv_exposure_min_us: 20
                                msv_exposure_max_us: 33000
                                gain_min           : 100
                                gain_max           : 100
                                standby_enabled:     0
                                decimator:           1
                                independent_exposure:0
                            cam #1
                                type:                ov64b
                                bayer_type:          1
                                enabled:             1
                                camera_id:           1
                                fps:                 30
                                en_rotate:           0
                                en_rotate2:          0
                                en_preview:          1
                                en_raw_preview:      1
                                preview_width:       9216
                                preview_height:      6944
                                en_misp:             1
                                misp_width:          9216
                                misp_height:         6944
                                en_small_video:      0
                                small_video_width:   1024
                                small_video_height:  768
                                en_large_video:      0
                                large_video_width:   3840
                                large_video_height:  2160
                                en_snapshot:         0
                                snap_width:          3840
                                snap_height:         2160
                                exif_focal_length:   3.100000
                                exif_focal_len_35mm_format:17
                                exif_fnumber:        1.240000
                                ae_mode:             isp
                                gain_min           : 100
                                gain_max           : 800
                                standby_enabled:     0
                                decimator:           1
                            fsync_en:            0
                            fsync_gpio:          109
                            thread is locked to cores: 4 5 6 7
                            connected to mavlink pipe
                            Connected to cpu-monitor
                            Skipping Camera: boson, configuration marked disabled
                            Starting Camera: hires (id #1)
                            ModalExposureMSV: initializing for camera name  type
                            Estimated imu dt = 0.000976s
                            MISP Initializing for camera hires
                             Detected 1 platform(s)
                             Detected 1 GPU device(s)
                            ERROR in json_from_yaml, failed to open file
                            MISP: Loading intrinsics cal file hires_intrinsics.yml for camera hires, ret -1
                            WARNING: Lens calibration for camera hires is missing (hires_intrinsics.yml). Using defaults:
                            ------ voxl-camera-server: Started 1 of 2 cameras
                            ERROR:   Received "Result" error from camera: hires, frame number 0
                            ERROR:   Received "Buffer" error from camera: hires, frame number 0
                            WARNING: Pushed buffers back to pools for frame: 0
                            ERROR:   Received "Result" error from camera: hires, frame number 1
                            ERROR:   Received "Buffer" error from camera: hires, frame number 1
                            WARNING: Pushed buffers back to pools for frame: 1
                            ERROR:   Received "Result" error from camera: hires, frame number 2
                            ERROR:   Received "Buffer" error from camera: hires, frame number 2
                            WARNING: Pushed buffers back to pools for frame: 2
                            ERROR:   Received "Result" error from camera: hires, frame number 3
                            ERROR:   Received "Buffer" error from camera: hires, frame number 3
                            WARNING: Pushed buffers back to pools for frame: 3
                            ERROR:   Received "Result" error from camera: hires, frame number 4
                            ERROR:   Received "Buffer" error from camera: hires, frame number 4
                            WARNING: Pushed buffers back to pools for frame: 4
                            ERROR:   Received "Request" error from camera: hires, frame number 5
                            WARNING: Pushed buffers back to pools for frame: 5
                            ^C
                            received SIGINT Ctrl-C
                            ------ voxl-camera-server: Camera server is now stopping
                            Stats For Camera hires:
                            	 Received Frame Count: 12
                            	 Request  Error Count: 1
                            	 Buffer   Error Count: 5
                            	 Result   Error Count: 5
                            ------ voxl-camera-server: Camera server exited gracefully, returning 0
                            Here is the output of voxl-version on the non-working voxl:
                            system-image: 1.8.06-M0054-14.1a-perf
                            kernel:       #1 SMP PREEMPT Wed Oct 22 03:21:50 UTC 2025 4.19.125
                            hw platform:  M0054
                            mach.var:     1.0.0
                            SKU:          MCCA-M0054-C11-T0-M0-X0
                            voxl-suite:   1.6.3
                            Packages:
                            Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.6/binary-arm64/
                            Last Updated: 2023-03-02 13:58:13
                            List:
                            libfc-sensor                   1.0.9
                            libmodal-cv                    0.6.0
                            libmodal-exposure              0.1.4
                            libmodal-flow                  1.0.3
                            libmodal-journal               0.2.7
                            libmodal-json                  0.4.8
                            libmodal-pipe                  2.14.11
                            libqrb5165-io                  0.6.3
                            libvoxl-cci-direct             0.3.3
                            libvoxl-codec                  0.0.2
                            libvoxl-cutils                 0.1.6
                            modalai-slpi                   1.2.2
                            mv-voxl                        0.1-r0
                            qrb5165-bind                   0.1-r0
                            qrb5165-dfs-server             0.2.0
                            qrb5165-mini-tof-server        0.2.2
                            qrb5165-rangefinder-server     0.1.6
                            qrb5165-slpi-test-sig          01-r0
                            qrb5165-tflite                 2.17.2
                            voxl-bind-spektrum             0.1.1
                            voxl-camera-calibration        0.6.1
                            voxl-camera-server             2.2.23-202604170806
                            voxl-ceres-solver              2:2.0.0-2
                            voxl-configurator              1.1.5
                            voxl-cpu-monitor               0.7.7
                            voxl-docker-support            1.3.1
                            voxl-elrs                      1.1.0
                            voxl-esc                       1.5.7
                            voxl-esptool                   0.2.0
                            voxl-feature-tracker           0.5.2
                            voxl-flow-server               0.3.6
                            voxl-gphoto2-server            0.0.10
                            voxl-imu-server                2.0.1
                            voxl-io-server                 0.0.8
                            voxl-jpeg-turbo                2.1.3-7
                            voxl-lepton-server             1.3.3
                            voxl-lepton-tracker            0.0.4
                            voxl-libgeographic             1.0.0
                            voxl-libgphoto2                0.0.4
                            voxl-libuvc                    1.0.7
                            voxl-logger                    0.6.1
                            voxl-mavcam-manager            0.6.0
                            voxl-mavlink                   0.1.6
                            voxl-mavlink-server            1.4.14
                            voxl-modem                     1.2.3
                            voxl-mongoose                  7.19.0
                            voxl-mpa-to-ros                0.3.9
                            voxl-mpa-tools                 1.5.8
                            voxl-nano-tracker              0.1.7
                            voxl-open-vins-server          0.6.0
                            voxl-opencv                    4.5.5-3
                            voxl-osd                       0.3.8
                            voxl-portal                    0.8.7
                            voxl-px4                       1.14.0-2.0.133
                            voxl-px4-params                0.9.0
                            voxl-qvio-server               1.2.3
                            voxl-remote-id                 0.0.9
                            voxl-reset-slpi                0.0.1
                            voxl-state-estimator           0.0.6
                            voxl-streamer                  0.8.0
                            voxl-suite                     1.6.3
                            voxl-tag-detector              0.1.0
                            voxl-tflite-server             0.5.1
                            voxl-utils                     2.0.2
                            voxl-uvc-server                0.1.7
                            voxl-vision-hub                1.9.21
                            voxl-vtx                       2.0.2
                            voxl-wavemux                   0.0.3
                            voxl2-io                       0.0.3
                            voxl2-security-hardening-utls  1.0-r0
                            voxl2-system-image             1.8.06-r0
                            voxl2-wlan                     1.0-r0
                            And here are the versions for the working voxl:
                            kernel:       #1 SMP PREEMPT Wed Oct 22 04:13:18 UTC 2025 4.19.125
                            hw platform:  M0054
                            mach.var:     1.0.1
                            SKU:          TF-M0054-4-V1-C11
                            voxl-suite:   1.6.3
                            Packages:
                            Last Updated: 2026-05-07 16:00:59
                            List:
                            libfc-sensor                   1.0.9
                            libmodal-cv                    0.6.0
                            libmodal-flow                  1.0.3
                            libmodal-json                  0.4.8
                            libqrb5165-io                  0.6.3
                            libvoxl-codec                  0.0.2
                            modalai-slpi                   1.2.2
                            mv-voxl                        0.1-r0
                            qrb5165-bind                   0.1-r0
                            voxl-ardupilot                 4.8.0-8ed7441c
                            voxl-elrs                      1.1.0
                            voxl-esc                       1.5.7
                            voxl-esptool                   0.2.0
                            voxl-libuvc                    1.0.7
                            voxl-logger                    0.6.1
                            voxl-mavlink                   0.1.6
                            voxl-microdds-agent            3.0.0-0
                            voxl-modem                     1.2.3
                            voxl-mpa-to-ros2               0.0.7
                            voxl-opencv                    4.5.5-3
                            voxl-osd                       0.3.8
                            voxl-portal                    0.8.7
                            voxl-ros2-foxy                 0.0.1
                            voxl-streamer                  0.8.0
                            voxl-suite                     1.6.3
                            voxl-utils                     2.0.2
                            voxl-vtx                       2.0.2
                            voxl-wavemux                   0.0.3
                            voxl2-io                       0.0.3
                            voxl2-wlan                     1.0-r0
                            The versions look to be the same for the most part, which is confusing us.
                            • C cguzikowski
                              cam #0
                                  type:                boson
                                  bayer_type:          0
                                  enabled:             0
                                  camera_id:           0
                                  fps:                 30
                                  en_rotate:           0
                                  en_rotate2:          0
                                  en_preview:          1
                                  en_raw_preview:      1
                                  preview_width:       640
                                  preview_height:      512
                                  en_misp:             1
                                  misp_width:          512
                                  misp_height:         640
                                  en_small_video:      0
                                  en_large_video:      0
                                  en_snapshot:         0
                                  snap_width:          -1
                                  snap_height:         -1
                                  ae_mode:             off
                                  gain_min           : 100
                                  gain_max           : 100
                                  standby_enabled:     0
                                  decimator:           1
                              cam #1
                                  type:                ov64b
                                  bayer_type:          1
                                  enabled:             1
                                  camera_id:           1
                                  fps:                 30
                                  en_rotate:           0
                                  en_rotate2:          0
                                  en_preview:          1
                                  en_raw_preview:      1
                                  preview_width:       9216
                                  en_misp:             1
                                  misp_width:          9216
                                  misp_height:         6944
                                  en_small_video:      0
                                  en_large_video:      0
                                  en_snapshot:         0
                                  snap_width:          3840
                                  snap_height:         2160
                                  ae_mode:             isp
                                  gain_min           : 100
                                  gain_max           : 800
                                  standby_enabled:     0
                                  decimator:           1
                              fsync_en:            0
                              fsync_gpio:          109
                              ^C
                              hw platform:  M0054
                              mach.var:     1.0.0
                              voxl-suite:   1.6.3
                              Packages:
                              List:
                              libfc-sensor                   1.0.9
                              libmodal-cv                    0.6.0
                              libmodal-flow                  1.0.3
                              libmodal-json                  0.4.8
                              libqrb5165-io                  0.6.3
                              libvoxl-codec                  0.0.2
                              modalai-slpi                   1.2.2
                              mv-voxl                        0.1-r0
                              qrb5165-bind                   0.1-r0
                              voxl-elrs                      1.1.0
                              voxl-esc                       1.5.7
                              voxl-esptool                   0.2.0
                              voxl-libuvc                    1.0.7
                              voxl-logger                    0.6.1
                              voxl-mavlink                   0.1.6
                              voxl-modem                     1.2.3
                              voxl-opencv                    4.5.5-3
                              voxl-osd                       0.3.8
                              voxl-portal                    0.8.7
                              voxl-streamer                  0.8.0
                              voxl-suite                     1.6.3
                              voxl-utils                     2.0.2
                              voxl-vtx                       2.0.2
                              voxl-wavemux                   0.0.3
                              voxl2-io                       0.0.3
                              voxl2-wlan                     1.0-r0
                              hw platform:  M0054
                              mach.var:     1.0.1
                              voxl-suite:   1.6.3
                              Packages:
                              List:
                              libfc-sensor                   1.0.9
                              libmodal-cv                    0.6.0
                              libmodal-flow                  1.0.3
                              libmodal-json                  0.4.8
                              libqrb5165-io                  0.6.3
                              libvoxl-codec                  0.0.2
                              modalai-slpi                   1.2.2
                              mv-voxl                        0.1-r0
                              qrb5165-bind                   0.1-r0
                              voxl-elrs                      1.1.0
                              voxl-esc                       1.5.7
                              voxl-esptool                   0.2.0
                              voxl-libuvc                    1.0.7
                              voxl-logger                    0.6.1
                              voxl-mavlink                   0.1.6
                              voxl-modem                     1.2.3
                              voxl-opencv                    4.5.5-3
                              voxl-osd                       0.3.8
                              voxl-portal                    0.8.7
                              voxl-streamer                  0.8.0
                              voxl-suite                     1.6.3
                              voxl-utils                     2.0.2
                              voxl-vtx                       2.0.2
                              voxl-wavemux                   0.0.3
                              voxl2-io                       0.0.3
                              voxl2-wlan                     1.0-r0
                              @cguzikowski ,
                              Sorry for the delay.
                              Regarding the new HW not working, since you have two identical setups, i would recommend swapping components to identify what exactly is not working. This is the most efficient way to diagnose it. From the logs you provided, the ov64b camera is detected and initialized, it seems, but no frames come in, which could be a cabling or interposer issue.
                              I will get back to you with an update on the lens shading tomorrow.
