  3. IMX412 not detecting
image-sensor
2 Posts 2 Posters 874 Views 1 Watching
  • F Offline
    F Offline
    fhaltmayer
    wrote on last edited by fhaltmayer
    Trying to run the IMX412 with the VOXL2 and have followed many of the threads regarding getting it to work. Ive gotten close but am running into a main problem. The camera is being noticed when running voxl-camera-server -l but it isnt being counted as a valid one. What am I missing here?
    voxl2:/usr/lib/camera$ voxl-camera-server -l
    DEBUG:   ----------- Number of cameras: 0
    DEBUG:   cci-direct: using voxl_platform_mod config 0 layout
    DEBUG:   trying to open idx  0 /dev/v4l-subdev8
    DEBUG:   trying to open idx  1 /dev/v4l-subdev9
    DEBUG:   trying to open idx  2 /dev/v4l-subdev11
    Cam idx: 0, Cam slot: 2, Slave Address: 0x0034, Sensor Id: 0x0577
    DEBUG:   trying to open idx  3 /dev/v4l-subdev12
    DEBUG:   trying to open idx  4 /dev/v4l-subdev10
    DEBUG:   trying to open idx  5 /dev/v4l-subdev13
    DEBUG:   Note: This list comes from the HAL module and may not be indicative
    DEBUG:   	of configurations that have full pipelines
    DEBUG:   Number of cameras: 0
    The server-config:
    voxl2:/usr/lib/camera$ cat /etc/modalai/voxl-camera-server.conf
     * voxl-camera-server Configuration File
     * Each camera has configurations for up to 4 HAL3 streams:
     *    - `preview` stream for raw unprocessed images from CV cameras
     *    - `small_video` 720p (ish) h264/h265 compressed for fpv video streaming
     *    - `large_video` 4k (ish) h264/h265 for onboard video recording to disk
     *    - `snapshot` ISP-processed JPG snapshots that get saved to disk
     * on QRB5165 platforms (VOXL2 and VOXL2 mini) you can only have 3 of the 4 enabled
     * This file is generated from default values by voxl-configure-cameras.
     * Do not expect arbitrary resolutions to work, the ISP and video compression
     * pipelines only support very specific resolutions.
     * The default video compression mode is cqp or Constant Quantization Parameter
    	"version":	0.1,
    	"fsync_en":	false,
    	"fsync_gpio":	109,
    	"cameras":	[{
    			"type":	"imx412",
    			"name":	"imx412",
    			"enabled":	true,
    			"camera_id":	0,
    			"fps":	30,
    			"en_rotate":	false,
    			"en_preview":	false,
    			"preview_width":	640,
    			"preview_height":	480,
    			"en_raw_preview":	false,
    			"en_small_video":	true,
    			"small_video_width":	1024,
    			"small_video_height":	768,
    			"small_venc_mode":	"h264",
    			"small_venc_br_ctrl":	"cqp",
    			"small_venc_Qfixed":	30,
    			"small_venc_Qmin":	15,
    			"small_venc_Qmax":	40,
    			"small_venc_nPframes":	9,
    			"small_venc_mbps":	2,
    			"en_large_video":	true,
    			"large_video_width":	4056,
    			"large_video_height":	3040,
    			"large_venc_mode":	"h264",
    			"large_venc_br_ctrl":	"cqp",
    			"large_venc_Qfixed":	40,
    			"large_venc_Qmin":	15,
    			"large_venc_Qmax":	50,
    			"large_venc_nPframes":	29,
    			"large_venc_mbps":	40,
    			"en_snapshot":	true,
    			"en_snapshot_width":	4056,
    			"en_snapshot_height":	3040,
    			"exif_focal_length":	3.1,
    			"exif_focal_length_in_35mm_format":	17,
    			"exif_fnumber":	1.24,
    			"snapshot_jpeg_quality":	75,
    			"ae_mode":	"isp",
    			"gain_min":	54,
    			"gain_max":	8000
    • F fhaltmayer
      The server-config:
      	"version":	0.1,
      	"fsync_en":	false,
      	"fsync_gpio":	109,
      	"cameras":	[{
      			"type":	"imx412",
      			"name":	"imx412",
      			"enabled":	true,
      			"camera_id":	0,
      			"fps":	30,
      			"en_rotate":	false,
      			"ae_mode":	"isp",
      			"gain_min":	54,
      			"gain_max":	8000
      @fhaltmayer , it looks like there maybe something missing from /usr/lib/camera/, as the camera is detected by the i2c probe but not accepted by the system.
      Can you please let me know how exactly the camera is connected (to camera slot/id 2, it seems) and also list all the contents of /usr/lib/camera/.
