  3. Multiple m0138 ESCs connected to a computer.
esc
2 Posts 2 Posters 1.4k Views 1 Watching
  • S Offline
    S Offline
    sjt277
    Hi
    I was checking on if it is possible to connect multiple m0138 escs to a computer for bench testing? If yes how would you approach it as a plug and play method would lead to id collisions between the ESCs.
    • S sjt277
      Hi
      @sjt277 ,
      The simplest approach is to use a separate USB-to-serial adapter for each ESC.
      You can set up udev rules to map and distinguish the specific usb-to-serial adapters (using their unique serial numbers) to aliases in /dev/, such as /dev/esc0, /dev/esc1, etc.
      Then run your testing using different USB devices to access each ESC (i am assuming you are using voxl-esc tools?).
      For example, here is some relevant information: https://askubuntu.com/questions/49910/how-to-distinguish-between-identical-usb-to-serial-adapters
      Does that help?
