    M0188
    VOXL 2 IO
    • L
      leandro
      I bought an M0188 VOXL 2 Mini Sparrow Imager Adapter (I received a M0188-2-00). I was going to use the J01 to connect two M0189 making use of the MCBL-00128-1 (Dual TOF pill). None of the 4 connectors on the Sparrow came mounted. How do I use/connect the dual TOF pill?
      • ModeratorM
        Moderator ModalAI Team @leandro
        @leandro The M0188-1 includes the connectors for the TOF range finders. We have not offered that board before though. Where did you find that information?
        What was your order number? We can send you a M0188-1, but it may not be available for small orders in the future
        L 1 Reply Last reply Reply Quote 0
        • L
          leandro @Moderator
          @Moderator The description to MCBL-00128 (https://docs.modalai.com/cable-datasheets/#mcbl-00128), the TOF for the Voxl 2 Mini says it's supported with M0188 (https://docs.modalai.com/M0189/) without specifying any sub P/N (-1 or -2), even in the documentation of the M0188 doesn't say anything about P/N -1 or -2 (https://docs.modalai.com/M0188/).
