    Open-VINS Mask File Location
    GPS-denied Navigation (VIO)
    • J
      jakkkkobo
      Re: open-vins mask file location
      Dear All,
      Regarding the previous post of @Jeremy-Frederick I'm still being unable to find the Open-VINS mask file location to apply different masks to each camera.
      Can you comment on that?
      Thank you in advance.
      Best Regards,
      Jacob
      zauberflote1Z 1 Reply Last reply Reply Quote 1
      • zauberflote1Z
        zauberflote1 ModalAI Team @jakkkkobo
        @jakkkkobo
        We currently do not ship any mask files with our airframes, as they are normally not required. In addition, you should be able to use a mask with minor modifications on the server side, namely VoxlCam directory inside voxl-open-vins-server repo. (The mono camera case should be a good starting point, as we already have the masking logic for occluded cams during takeoff.)
        Furthermore, as we use a custom interface/backend for OV, loading the mask as done in the traditional OV-ROS format won’t work as intended, i.e., via Yaml.
        All the best,
        ZBFT
        • J
          jakkkkobo @zauberflote1
          @zauberflote1 ok, thank you!
          I will try to implement the mask as in VoxlCam.
          Regards,
          Jacob
          • zauberflote1Z zauberflote1 referenced this topic
