  3. Robust way of setting static IP
2 Posts 2 Posters 361 Views 1 Watching
  • J Offline
    jon
    Right now I'm using this bash script to set a static ip:
    ETHERNET_IP=192.168.1.100
    eth_dongle_interface=eth0
    while true
    do
       if [[ -e "/sys/class/net/$eth_dongle_interface" ]]; then
             eth_dongle_ip=$(ip -4 addr show $eth_dongle_interface | grep -oP '(?<=inet\s)\d+(\.\d+){3}' | head -1)
       else
             eth_dongle_ip=""
       fi
       if [[ "$eth_dongle_ip" != *"$ETHERNET_IP"* &&  -e "/sys/class/net/$eth_dongle_interface" ]]; then
                    echo "setting IP address to: $ETHERNET_IP"
                    ip addr flush dev $eth_dongle_interface
                    sleep 1
                    ip link set dev $eth_dongle_interface up
                    sleep 1
                    ip addr add $ETHERNET_IP/255.255.255.0 dev $eth_dongle_interface
        fi
        sleep 1
    done
    It's pretty reliable, but we have seen it fail and the default 169.254.4.1 address takes over the eth0 interface. I believe this the Qualcomm DHCP manager? Is there any way to edit the network manager directly? We have tried deleting it but it seems to regenerate on boot.
    • J jon
      while true
      do
         else
               eth_dongle_ip=""
         fi
                      sleep 1
                      sleep 1
          fi
          sleep 1
      done
      @jonathankampia ,
      Here is something i tried, you can try as well. You are right, there is a background service that may be taking over, I think i found how to disable it:
      systemctl disable QCMAP_ConnectionManagerd
      systemctl disable qti_pppd
      systemctl disable qtid
      rm /lib/systemd/system/multi-user.target.wants/QCMAP_ConnectionManagerd.service
      rm /lib/systemd/system/multi-user.target.wants/qti_pppd.service
      rm /lib/systemd/system/multi-user.target.wants/qtid.service
      #edit: instead of disabling the above 3 services and removing the entries from `multi-user.target.wants`, it seems you can do the following:
      systemctl mask QCMAP_ConnectionManagerd
      systemctl mask qti_pppd
      systemctl mask qtid
      # you may want to disable dhcpcd as well, but i dont think that is strictly necessary:
      systemctl disable dhcpcd
      Now, set up static connection:
      #create a new network interface file
      vi /etc/systemd/network/10-eth0.network
      [Match]
      Name=eth0
      [Network]
      Address=192.168.xx.xx/24
      Gateway=192.168.xx.1
      DNS=8.8.8.8 1.1.1.1
      enable networkd
      systemctl enable systemd-networkd
      Then reboot voxl2...
      I think if dhcpcd is enabled, it may first take over the interface, but then networkd takes it back.. For example, here is the log from networkd when dhcpcd is enabled:
      Dec 10 06:01:00 m0054 systemd-networkd[1126]: dummy0: Gained carrier
      Dec 10 06:01:00 m0054 systemd-networkd[1126]: dummy0: Gained IPv6LL
      Dec 10 06:01:11 m0054 systemd-networkd[1126]: eth0: Gained carrier
      Dec 10 06:02:13 m0054 systemd-networkd[1126]: eth0: Gained IPv6LL
      Dec 10 06:02:13 m0054 systemd-networkd[1126]: eth0: Configured
      Dec 10 06:02:13 m0054 systemd-networkd[1126]: docker0: Link UP
      Dec 10 06:02:21 m0054 systemd-networkd[1126]: eth0: Lost carrier
      Dec 10 06:02:36 m0054 systemd-networkd[1126]: eth0: Gained carrier
      Dec 10 06:02:38 m0054 systemd-networkd[1126]: eth0: Gained IPv6LL
      Dec 10 06:02:38 m0054 systemd-networkd[1126]: eth0: Configured
      and the log with dhcpcd disabled:
      Dec 10 06:02:13 m0054 systemd-networkd[1126]: bond0: Link is not managed by us
      Dec 10 06:02:13 m0054 systemd-networkd[1126]: sit0: Link is not managed by us
      Dec 10 06:02:14 m0054 systemd-networkd[1126]: eth0: Link UP
      Dec 10 06:02:38 m0054 systemd-networkd[1126]: eth0: Gained carrier
      Dec 10 06:09:56 m0054 systemd-networkd[1126]: eth0: Gained IPv6LL
      Dec 10 06:09:56 m0054 systemd-networkd[1126]: eth0: Configured
      Dec 10 06:09:56 m0054 systemd-networkd[1126]: docker0: Link UP
      Can you try and see if that solves your issue?
