  2. VOXL SDK and Software
  3. Camera calibration fails
voxl-sdk
3 Posts 2 Posters 544 Views 1 Watching
  • A Offline
    akirahrkw
    I'm currently trying to calibrate camera on starling 2 Max, but it seems failing.
    Environment
    Product: Starling 2 Max
    system-image: 1.8.04-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Mon Mar 24 22:31:58 UTC 2025 4.19.125
    hw platform:  M0054
    mach.var:     1.0.1
    voxl-suite:   1.5.1
    I follow the information on the page below,
    https://docs.modalai.com/calibrate-cameras/
    and use the chessboard 6x9 (A3 print)
    https://raw.githubusercontent.com/opencv/opencv/4.x/doc/pattern.png
    and
    voxl2:/$ voxl-calibrate-camera tracking_front -f -s 6x9 -l 0.033
    Waiting for valid pipe...
    Please open voxl-portal in a web browser to view the camera calibrator overlay stream
    I can see the overlay on the portal, but end up with the either following case.
    1. nothing happens (no output/log on the console)
    2. voxl-camera-server freeze (voxl-portal stop showing live feed)
    As I'm not sure if I was calibrating camera properly, I'd like to check if there is a way to do it.
    Thank you.
    Akira
    • A akirahrkw
      Environment
      hw platform:  M0054
      mach.var:     1.0.1
      voxl-suite:   1.5.1
      and
      Thank you.
      Akira
      @akirahrkw ,
      Even if the checkerboard is detected, it needs to fill the majority of the non-shaded region. In order to progress to the next step, you need to bring the camera / pattern closer together and then the procedure will accept it. I know this is not obvious when you do it for the first time.
      Regarding voxl-camera-server freeze, what if you run voxl-inspect-cam <camera_stream> on voxl2, does it still show images coming in?
      Try setting your voxl into perf mode (voxl-set-cpu-mode perf) which will speed up the calibration pattern detection. I see that the calibration is only running at 2.8FPS at 1280x800 resolution.
      During calibraiton, you may also want to stop other services that might be doing image processing, so that VOLX2 has more cpu cycles for the calibration app.
      A 1 Reply Last reply
        @akirahrkw ,
        akirahrkw
        wrote on last edited by akirahrkw
        @Alex-Kushleyev
        Thank you for the information and support!
        the calibration worked well after stopping other services.
        Akira
