  3. Voxl2 Mini PX4 Issue
4 Posts 2 Posters 658 Views 1 Watching
  • O Offline
    O Offline
    owf226
    The setup that I am currently using involves a Voxl2 Mini and the Voxl ESC mini 4 in 1. The ESC is calibrated, and when all motors are spun using voxl-esc tools, the RPM values are accurate across all thrusters. This is also true when the motor test is performed in QGC, the reported RPM is equal across all thrusters.
    The issue occurs when trying to fly the drone. When armed, not all of the motors spin at the same speed. Using the RC controller to arm the drone, and putting all control inputs to zero causes vibration issues as some of the motors spin significantly slower than the rest. I re-calibrated the sensors in QGC several times, and this did not resolve the issue. I have attached a brief log which shows the issue, and would appreciate any suggestions about how to fix it. Given that the motors work correctly when tested outside of PX4, I am leaning towards it being a configuration issue with that.
    https://review.px4.io/plot_app?log=6b99b5ad-9cfd-4a7c-b76f-2e6ea2a20393
    • O owf226
      Eric KatzfeyE Online
      @owf226 In the log you can see that at 2:52 it takes off. Up until then the motor RPMS are close but not equal. Is that the part you are talking about? After takeoff it is in stabilized mode and so it is trying to level itself and that makes the motor speeds quite a bit different as expected.
      O 1 Reply Last reply
        O Offline
        O Offline
        owf226
        @Eric-Katzfey
        Sorry for the delayed response. This "flight" log was from when it was sitting on a level surface, with no propellers attached.
        Since the drone was level with no propellers attached, I would expect the actuator controls to match the manual control, but this doesn't appear to be the case?
        Thank you.
        • O owf226
          @Eric-Katzfey
          Thank you.
          @owf226 As soon as PX4 thinks it has taken off then it is trying to level the drone but can't since there are no propellers on the drone. So, it keeps increasing the speed of the motors on the side that needs to come up. That all seems normal to me.
