  3. VOXL FPV ESC Current sensing
esc
3 Posts 2 Posters 1.9k Views 1 Watching
  • D Offline
    D Offline
    Dronodev
    Hi guys,
    I’m planning to use a VOXL FPV ESC and was wondering whether the current sensor detects not only the current drawn by the motors but also the current drawn from the payload connector J2.
    Does the payload current get sensed as well?
    Thanks in advance!
    VinnyV 1 Reply Last reply
    • D Dronodev
      Hi guys,
      Thanks in advance!
      VinnyV Offline
      VinnyV Offline
      Vinny
      Hi @Dronodev
      Yes, the payload connector J2 is included in the system current sensing.
      If you needed to get independent readings, you could disable all motor spinning, and get current readings from CH2 which would effectively give you all local quiescent current (including VOXL 2 loads) plus the payload at J2.
      Hope that helps.
      D 1 Reply Last reply
      • VinnyV Vinny
        Hi @Dronodev
        Hope that helps.
        D Offline
        D Offline
        Dronodev
        @Vinny Yes, thank you very much!
