  3. mapper not working
mapper not working
1 Posts 1 Posters 465 Views
  • Allister LimA Offline
    Allister Lim
    We are using the voxl starling max 2
    we are following this tutorial: https://docs.modalai.com/setting-up-voxl-mapper/ and have used this set up
    however nothing appears on our mapper in the voxl web portal.
    please see me .conf file:
    "config_file_version": 1,
    "en_localhost_mavlink_udp": false,
    "localhost_udp_port_number": 14551,
    "en_vio": true,
    "vio_pipe": "qvio",
    "secondary_vio_pipe": "ov",
    "vfc_vio_pipe": "ov",
    "vio_warmup_s": 3,
    "send_odom_while_failed": true,
    "horizon_cal_tolerance": 0.5,
    "en_hitl": false,
    "offboard_mode": "trajectory",
    "follow_tag_id": 0,
    "figure_eight_move_home": true,
    "collision_sampling_dt": 0.1,
    "max_lookahead_distance": 1,
    "backtrack_seconds": 60,
    "backtrack_rc_chan": 8,
    "backtrack_rc_thresh": 1500,
    "wps_move_home": true,
    "wps_stride": 0,
    "wps_timeout": 0,
    "wps_damp": 1,
    "wps_vfc_mission": true,
    "wps_vfc_mission_loop": false,
    "wps_vfc_mission_to_ramp": 25,
    "wps_vfc_mission_to_kp": 0.10000000149011612,
    "wps_vfc_mission_cruise_speed": 1,
    "en_tag_fixed_frame": false,
    "fixed_frame_filter_len": 5,
    "en_transform_mavlink_pos_setpoints_from_fixed_frame": false,
    This is what the mapper looks like:
    voxl-version:
    starling2-max (D0012):~$ voxl-version
    system-image: 1.8.04-M0054-14.1a-perf
    kernel: #1 SMP PREEMPT Mon Mar 24 22:31:58 UTC 2025 4.19.125
    hw platform: M0054
    mach.var: 1.0.1
    SKU: MRB-D0012-4-V2-C28-T9-M11-X0
    voxl-suite: 1.5.0
    Packages:
    Repo: http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.5/binary-arm64/
    Last Updated: 2023-03-02 12:58:39
    List:
    libfc-sensor 1.0.7
    libmodal-cv 0.5.18
    libmodal-exposure 0.1.4
    libmodal-journal 0.2.6
    libmodal-json 0.4.7
    libmodal-pipe 2.13.2
    libqrb5165-io 0.5.0
    libvoxl-cci-direct 0.3.3
    libvoxl-cutils 0.1.5
    modalai-slpi 1.2.0
    mv-voxl 0.1-r0
    qrb5165-bind 0.1-r0
    qrb5165-dfs-server 0.2.0
    qrb5165-imu-server 1.1.3
    qrb5165-mini-tof-server 0.2.2
    qrb5165-rangefinder-server 0.1.5
    qrb5165-slpi-test-sig 01-r0
    qrb5165-system-tweaks 0.3.6
    qrb5165-tflite 2.8.0-2
    voxl-bind-spektrum 0.1.1
    voxl-camera-calibration 0.6.0
    voxl-camera-server 2.2.4
    voxl-ceres-solver 2:1.14.0-10
    voxl-configurator 1.0.2
    voxl-cpu-monitor 0.6.0
    voxl-docker-support 1.3.1
    voxl-elrs 0.4.7
    voxl-esc 1.5.4
    voxl-feature-tracker 0.5.2
    voxl-flow-server 0.3.6
    voxl-gphoto2-server 0.0.10
    voxl-joystick-server 0.0.6
    voxl-jpeg-turbo 2.1.3-7
    voxl-lepton-server 1.3.3
    voxl-lepton-tracker 0.0.4
    voxl-libgphoto2 0.0.4
    voxl-libuvc 1.0.7
    voxl-logger 0.5.3
    voxl-mavcam-manager 0.6.0
    voxl-mavlink 0.1.5
    voxl-mavlink-server 1.4.9
    voxl-modem 1.1.8
    voxl-mongoose 7.7.0-2
    voxl-mpa-to-ros 0.3.9
    voxl-mpa-tools 1.4.0
    voxl-open-vins 0.4.19
    voxl-open-vins-server 0.3.12
    voxl-opencv 4.5.5-3
    voxl-osd 0.1.8
    voxl-portal 0.7.11
    voxl-px4 1.14.0-2.0.105
    voxl-px4-params 0.7.5
    voxl-qvio-server 1.2.0
    voxl-remote-id 0.0.9
    voxl-reset-slpi 0.0.1
    voxl-state-estimator 0.0.5
    voxl-streamer 0.7.5
    voxl-suite 1.5.0
    voxl-tag-detector 0.0.5
    voxl-tflite-server 0.4.1
    voxl-utils 1.4.8
    voxl-uvc-server 0.1.7
    voxl-vision-hub 1.8.23
    voxl-vtx 1.4.7
    voxl-wavemux 0.0.1
    voxl2-io 0.0.3
    voxl2-system-image 1.8.04-r0
    voxl2-wlan 1.0-r0
    We expect a Map like this as per the video https://www.youtube.com/watch?v=MGJwPyVU71g&ab_channel=ModalAI
