  3. MAVROS not connecting to FCU on m500
2 Posts 2 Posters 875 Views 2 Watching
  • Prasad AntervediP Offline
    Prasad Antervedi
    Hi again!
    I am trying to run mavros on VOXL on the m500 and I have been following the tutorial given here. The output when I run do ./run_mavros.sh is as shown here
    ... logging to /root/.ros/log/0c573912-1dda-11b2-b775-ec5c68cd236d/roslaunch-apq8096-2040.log
    Checking log directory for disk usage. This may take awhile.
    Press Ctrl-C to interrupt
    started roslaunch server http://192.168.8.1:49495/
    SUMMARY
    CLEAR PARAMETERS
    • /mavros/
    PARAMETERS
    • /mavros/cmd/use_comp_id_system_control: False
    • /mavros/conn/heartbeat_rate: 1.0
    • /mavros/conn/system_time_rate: 1.0
    • /mavros/conn/timeout: 10.0
    • /mavros/conn/timesync_rate: 10.0
    • /mavros/distance_sensor/hrlv_ez4_pub/field_of_view: 0.0
    • /mavros/distance_sensor/hrlv_ez4_pub/frame_id: hrlv_ez4_sonar
    • /mavros/distance_sensor/hrlv_ez4_pub/id: 0
    • /mavros/distance_sensor/hrlv_ez4_pub/orientation: PITCH_270
    • /mavros/distance_sensor/hrlv_ez4_pub/send_tf: True
    • /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/x: 0.0
    • /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/y: 0.0
    • /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/z: -0.1
    • /mavros/distance_sensor/laser_1_sub/id: 3
    • /mavros/distance_sensor/laser_1_sub/orientation: PITCH_270
    • /mavros/distance_sensor/laser_1_sub/subscriber: True
    • /mavros/distance_sensor/lidarlite_pub/field_of_view: 0.0
    • /mavros/distance_sensor/lidarlite_pub/frame_id: lidarlite_laser
    • /mavros/distance_sensor/lidarlite_pub/id: 1
    • /mavros/distance_sensor/lidarlite_pub/orientation: PITCH_270
    • /mavros/distance_sensor/lidarlite_pub/send_tf: True
    • /mavros/distance_sensor/lidarlite_pub/sensor_position/x: 0.0
    • /mavros/distance_sensor/lidarlite_pub/sensor_position/y: 0.0
    • /mavros/distance_sensor/lidarlite_pub/sensor_position/z: -0.1
    • /mavros/distance_sensor/sonar_1_sub/id: 2
    • /mavros/distance_sensor/sonar_1_sub/orientation: PITCH_270
    • /mavros/distance_sensor/sonar_1_sub/subscriber: True
    • /mavros/fake_gps/eph: 2.0
    • /mavros/fake_gps/epv: 2.0
    • /mavros/fake_gps/fix_type: 3
    • /mavros/fake_gps/geo_origin/alt: 408.0
    • /mavros/fake_gps/geo_origin/lat: 47.3667
    • /mavros/fake_gps/geo_origin/lon: 8.55
    • /mavros/fake_gps/gps_rate: 5.0
    • /mavros/fake_gps/mocap_transform: True
    • /mavros/fake_gps/satellites_visible: 5
    • /mavros/fake_gps/tf/child_frame_id: fix
    • /mavros/fake_gps/tf/frame_id: map
    • /mavros/fake_gps/tf/listen: False
    • /mavros/fake_gps/tf/rate_limit: 10.0
    • /mavros/fake_gps/tf/send: False
    • /mavros/fake_gps/use_mocap: True
    • /mavros/fake_gps/use_vision: False
    • /mavros/fcu_protocol: v2.0
    • /mavros/fcu_url: udp://127.0.0.1:1...
    • /mavros/gcs_url:
    • /mavros/global_position/child_frame_id: base_link
    • /mavros/global_position/frame_id: map
    • /mavros/global_position/gps_uere: 1.0
    • /mavros/global_position/rot_covariance: 99999.0
    • /mavros/global_position/tf/child_frame_id: base_link
    • /mavros/global_position/tf/frame_id: map
    • /mavros/global_position/tf/global_frame_id: earth
    • /mavros/global_position/tf/send: False
    • /mavros/global_position/use_relative_alt: True
    • /mavros/image/frame_id: px4flow
    • /mavros/imu/angular_velocity_stdev: 0.0003490659 // 0...
    • /mavros/imu/frame_id: base_link
    • /mavros/imu/linear_acceleration_stdev: 0.0003
    • /mavros/imu/magnetic_stdev: 0.0
    • /mavros/imu/orientation_stdev: 1.0
    • /mavros/landing_target/camera/fov_x: 2.0071286398
    • /mavros/landing_target/camera/fov_y: 2.0071286398
    • /mavros/landing_target/image/height: 480
    • /mavros/landing_target/image/width: 640
    • /mavros/landing_target/land_target_type: VISION_FIDUCIAL
    • /mavros/landing_target/listen_lt: False
    • /mavros/landing_target/mav_frame: LOCAL_NED
    • /mavros/landing_target/target_size/x: 0.3
    • /mavros/landing_target/target_size/y: 0.3
    • /mavros/landing_target/tf/child_frame_id: camera_center
    • /mavros/landing_target/tf/frame_id: landing_target
    • /mavros/landing_target/tf/listen: False
    • /mavros/landing_target/tf/rate_limit: 10.0
    • /mavros/landing_target/tf/send: True
    • /mavros/local_position/frame_id: map
    • /mavros/local_position/tf/child_frame_id: base_link
    • /mavros/local_position/tf/frame_id: map
    • /mavros/local_position/tf/send: False
    • /mavros/local_position/tf/send_fcu: False
    • /mavros/mission/pull_after_gcs: True
    • /mavros/mocap/use_pose: True
    • /mavros/mocap/use_tf: False
    • /mavros/odometry/fcu/odom_child_id_des: base_link
    • /mavros/odometry/fcu/odom_parent_id_des: map
    • /mavros/plugin_blacklist: ['safety_area', '...
    • /mavros/plugin_whitelist: []
    • /mavros/px4flow/frame_id: px4flow
    • /mavros/px4flow/ranger_fov: 0.118682
    • /mavros/px4flow/ranger_max_range: 5.0
    • /mavros/px4flow/ranger_min_range: 0.3
    • /mavros/safety_area/p1/x: 1.0
    • /mavros/safety_area/p1/y: 1.0
    • /mavros/safety_area/p1/z: 1.0
    • /mavros/safety_area/p2/x: -1.0
    • /mavros/safety_area/p2/y: -1.0
    • /mavros/safety_area/p2/z: -1.0
    • /mavros/setpoint_accel/send_force: False
    • /mavros/setpoint_attitude/reverse_thrust: False
    • /mavros/setpoint_attitude/tf/child_frame_id: target_attitude
    • /mavros/setpoint_attitude/tf/frame_id: map
    • /mavros/setpoint_attitude/tf/listen: False
    • /mavros/setpoint_attitude/tf/rate_limit: 50.0
    • /mavros/setpoint_attitude/use_quaternion: False
    • /mavros/setpoint_position/mav_frame: LOCAL_NED
    • /mavros/setpoint_position/tf/child_frame_id: target_position
    • /mavros/setpoint_position/tf/frame_id: map
    • /mavros/setpoint_position/tf/listen: False
    • /mavros/setpoint_position/tf/rate_limit: 50.0
    • /mavros/setpoint_raw/thrust_scaling: 1.0
    • /mavros/setpoint_velocity/mav_frame: LOCAL_NED
    • /mavros/startup_px4_usb_quirk: True
    • /mavros/sys/disable_diag: False
    • /mavros/sys/min_voltage: 10.0
    • /mavros/target_component_id: 1
    • /mavros/target_system_id: 1
    • /mavros/tdr_radio/low_rssi: 40
    • /mavros/time/time_ref_source: fcu
    • /mavros/time/timesync_avg_alpha: 0.6
    • /mavros/time/timesync_mode: MAVLINK
    • /mavros/vibration/frame_id: base_link
    • /mavros/vision_pose/tf/child_frame_id: vision_estimate
    • /mavros/vision_pose/tf/frame_id: odom
    • /mavros/vision_pose/tf/listen: False
    • /mavros/vision_pose/tf/rate_limit: 10.0
    • /mavros/vision_speed/listen_twist: True
    • /mavros/vision_speed/twist_cov: True
    • /mavros/wheel_odometry/child_frame_id: base_link
    • /mavros/wheel_odometry/count: 2
    • /mavros/wheel_odometry/frame_id: odom
    • /mavros/wheel_odometry/send_raw: True
    • /mavros/wheel_odometry/send_twist: False
    • /mavros/wheel_odometry/tf/child_frame_id: base_link
    • /mavros/wheel_odometry/tf/frame_id: odom
    • /mavros/wheel_odometry/tf/send: False
    • /mavros/wheel_odometry/use_rpm: False
    • /mavros/wheel_odometry/vel_error: 0.1
    • /mavros/wheel_odometry/wheel0/radius: 0.05
    • /mavros/wheel_odometry/wheel0/x: 0.0
    • /mavros/wheel_odometry/wheel0/y: -0.15
    • /mavros/wheel_odometry/wheel1/radius: 0.05
    • /mavros/wheel_odometry/wheel1/x: 0.0
    • /mavros/wheel_odometry/wheel1/y: 0.15
    • /rosdistro: kinetic
    • /rosversion: 1.12.14
    NODES
    mavros (mavros/mavros_node)
    auto-starting new master
    process[master]: started with pid [2050]
    ROS_MASTER_URI=http://127.0.0.1:11311/
    setting /run_id to 0c573912-1dda-11b2-b775-ec5c68cd236d
    process[rosout-1]: started with pid [2063]
    process[mavros-2]: started with pid [2081]
    [ INFO] [3426.096303900]: FCU URL: udp://127.0.0.1:14551@:14551
    [ INFO] [3426.103686380]: udp0: Bind address: 127.0.0.1:14551
    [ INFO] [3426.104249508]: GCS bridge disabled
    [ INFO] [3426.137194964]: Plugin 3dr_radio loaded
    [ INFO] [3426.146114065]: Plugin 3dr_radio initialized
    [ INFO] [3426.146529380]: Plugin actuator_control loaded
    [ INFO] [3426.167594784]: Plugin actuator_control initialized
    [ INFO] [3426.168073849]: Plugin altitude loaded
    [ INFO] [3426.173392987]: Plugin altitude initialized
    [ INFO] [3426.174679971]: Plugin command loaded
    [ INFO] [3426.217533648]: Plugin command initialized
    [ INFO] [3426.218051879]: Plugin ftp loaded
    [ INFO] [3426.262606814]: Plugin ftp initialized
    [ INFO] [3426.263183066]: Plugin global_position loaded
    [ INFO] [3426.403349147]: Plugin global_position initialized
    [ INFO] [3426.405406343]: Plugin hil loaded
    [ INFO] [3426.550259840]: Plugin hil initialized
    [ INFO] [3426.552356359]: Plugin home_position loaded
    [ INFO] [3426.584895147]: Plugin home_position initialized
    [ INFO] [3426.586284216]: Plugin imu loaded
    [ INFO] [3426.645288119]: Plugin imu initialized
    [ INFO] [3426.647154846]: Plugin local_position loaded
    [ INFO] [3426.697651837]: Plugin local_position initialized
    [ INFO] [3426.699237990]: Plugin manual_control loaded
    [ INFO] [3426.722194757]: Plugin manual_control initialized
    [ INFO] [3426.723371793]: Plugin param loaded
    [ INFO] [3426.742331303]: Plugin param initialized
    [ INFO] [3426.743906883]: Plugin rc_io loaded
    [ INFO] [3426.767917352]: Plugin rc_io initialized
    [ INFO] [3426.768082457]: Plugin safety_area blacklisted
    [ INFO] [3426.768497928]: Plugin setpoint_accel loaded
    [ INFO] [3426.787777179]: Plugin setpoint_accel initialized
    [ INFO] [3426.788179680]: Plugin setpoint_attitude loaded
    [ INFO] [3426.855109035]: Plugin setpoint_attitude initialized
    [ INFO] [3426.857526285]: Plugin setpoint_position loaded
    [ INFO] [3426.985575542]: Plugin setpoint_position initialized
    [ INFO] [3426.987834302]: Plugin setpoint_raw loaded
    [ INFO] [3427.048711495]: Plugin setpoint_raw initialized
    [ INFO] [3427.049813322]: Plugin setpoint_trajectory loaded
    [ INFO] [3427.077156983]: Plugin setpoint_trajectory initialized
    [ INFO] [3427.078320790]: Plugin setpoint_velocity loaded
    [ INFO] [3427.122030304]: Plugin setpoint_velocity initialized
    [ INFO] [3427.125250474]: Plugin sys_status loaded
    [ INFO] [3427.205486606]: Plugin sys_status initialized
    [ INFO] [3427.205882389]: Plugin sys_time loaded
    [ INFO] [3427.242300308]: TM: Timesync mode: MAVLINK
    [ INFO] [3427.250766699]: Plugin sys_time initialized
    [ INFO] [3427.251244826]: Plugin vfr_hud loaded
    [ INFO] [3427.255015832]: Plugin vfr_hud initialized
    [ INFO] [3427.256062087]: Plugin waypoint loaded
    [ INFO] [3427.285587164]: Plugin waypoint initialized
    [ INFO] [3427.287675715]: Plugin wind_estimation loaded
    [ INFO] [3427.293713085]: Plugin wind_estimation initialized
    [ INFO] [3427.295370696]: Autostarting mavlink via USB on PX4
    [ INFO] [3427.296400596]: Built-in SIMD instructions: ARM NEON
    [ INFO] [3427.297354819]: Built-in MAVLink package version: 2019.12.30
    [ INFO] [3427.298312532]: Known MAVLink dialects: common ardupilotmega ASLUAV autoquad icarous matrixpilot paparazzi slugs standard uAvionix ualberta
    But when I do rostopic echo /mavros/state I get the following output rostopic_mavros_state_output.png
    For your reference here are my voxl-vision-px4.conf file voxl-vision-px4_conf.png
    And here is my run_mavros.sh file
    As shown above, MAVROS is not connecting to FCU and as a result I am not getting anything on the /mavros/local_position/pose rostopic. Just FYI I am getting pose information in my QGC (in MAVLink Inspector) and it seemed to be accurate (moved approximately 1m forward and it was reflected in the QGC)
    Please let me know if you need any more information. Any insight into solving this would be greatly appreciated.
    Thank you 🙂
      Have you followed the mavros tutorial here?
