  3. custom camera config for imx214
1 Posts 1 Posters 397 Views
  • S Offline
    S Offline
    skn256
    Hi!,
    I'm currently using a imx214 camera with a voxl2 board. I'm trying to setup the hires imx214 only so I am trying to setup a custom config.
    I'm using the latest voxl-suite (1.4.1) which no longer has default configurations for imx214.
    /data/modalai/custom_camera_config.txt
    #!/bin/bash
    # This file allows setting of custom camera configurations by defining what
    # sensors are plugged into which port.
    # There is no guarantee that any arbitrary configuration will work. Only the
    # predefined camera configs at https://docs.modalai.com/voxl2-camera-configs/
    # are supported.
    # each slot can be one of the following sensors:
    # pmd-tof
    # pmd-tof-liow2
    # ov7251
    # ov7251-combo
    # ov9782
    # ov9782-combo
    # ar0144
    # ar0144-fsin (for use with m0173 and Starling 2 only)
    # ar0144-fsin-combo (for use with m0173 and Starling 2 only)
    # ar0144-12bit
    # ar0144-12bit-fsin (for use with m0173 and Starling 2 only)
    # ar0144-12bit-fsin-combo (for use with m0173 and Starling 2 only)
    # imx214
    # imx412
    # imx412-fpv (low latency mode)
    # imx678
    # When using a combo mode pair, you must also add a JX_COMBO_MODE field which
    # specifies is the pair is to be set up as either a stereo pair ordered
    # left-right, right-left, or treated as two independent cameras. If you are
    # using a combo-mode flex but only physically connect one of the two cameras
    # then select "single" it does not matter which one you connect.
    # For example:
    # J6_LOWER_COMBO_MODE="left-right"
    # J6_LOWER_COMBO_MODE="right-left"
    # J6_LOWER_COMBO_MODE="independent"
    # J6_LOWER_COMBO_MODE="single"
    # when running "independent" combo mode, also add a NAME2 field for the second cam
    # e.g J6_LOWER_NAME2="tracking_rear"
    # for all sensors except TOF, you can specify a "rotate" flag to
    # rotate the image 180 degrees e.g. J6_LOWER_ROTATE="true" or "false"
    # for stereo pairs (e.g. ov7251 combo or ar0144-slave-strereo) you can specify
    # "rotate-first-only" or "rotate-second-only" to only rotate one, other wise
    # when setting the rotate option to "true" both will be rotated.
    # Once configured, this file should live in /data/modalai/custom_camera-config.txt
    # then run voxl-configure-cameras custom to load it in
    # cp /usr/share/modalai/voxl-camera-server/custom_camera_config.txt /data/modalai/
    # We also suggest changing your /data/modalai/sku.txt file to have a camera
    # config term "CC" such as MRB-D0005-4-V2-CC
    J6_LOWER_SENSOR=""
    J6_LOWER_NAME=""
    J6_LOWER_ROTATE="false"
    J6_UPPER_SENSOR=""
    J6_UPPER_NAME=""
    J6_UPPER_ROTATE="false"
    J7_LOWER_SENSOR=""
    J7_LOWER_NAME=""
    J7_LOWER_ROTATE="false"
    J7_UPPER_SENSOR="imx214"
    J7_UPPER_NAME="hires"
    J7_UPPER_ROTATE="false"
    J8_LOWER_SENSOR=""
    J8_LOWER_NAME=""
    J8_LOWER_ROTATE="false"
    J8_UPPER_SENSOR=""
    J8_UPPER_NAME=""
    J8_UPPER_ROTATE="false"
    voxl-inspect-services
    Scanning services...
     voxl-auto-logger         | Disabled  | Not Running |
     voxl-camera-server       |  Enabled  | Not Running |
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.0%
     voxl-elrs-startup        | Disabled  | Not Running |
     voxl-imu-server          |  Enabled  |   Running   |     4.0%
     voxl-io-server           | Disabled  | Not Running |
     voxl-lepton-tracker      | Disabled  | Not Running |
     voxl-logger              | Disabled  | Not Running |
     voxl-mavcam-manager      | Disabled  | Not Running |
     voxl-mavlink-server      |  Enabled  |   Running   |     2.5%
     voxl-microdds-agent      | Disabled  | Not Running |
     voxl-open-vins-server    | Disabled  | Not Running |
     voxl-osd                 | Disabled  | Not Running |
     voxl-portal              |  Enabled  |   Running   |     0.1%
     voxl-px4-imu-server      |  Enabled  |   Running   |     1.1%
     voxl-px4                 |  Enabled  |   Running   |    34.5%
     voxl-qvio-server         |  Enabled  | Not Running |
     voxl-softap              |  Enabled  |  Completed  |
     voxl-state-estimator     | Disabled  | Not Running |
     voxl-static-ip           |  Enabled  | Not Running |
     voxl-streamer            | Disabled  | Not Running |
     voxl-vision-hub          |  Enabled  |   Running   |     1.5%
     voxl-vrx                 | Disabled  | Not Running |
     voxl-vtx                 | Disabled  | Not Running |
    when I try to run voxl-camera-server after configuring.
    voxl-camera-server
    detected system image 1.8.2
    using new imx214 defaults
    configuration for 1 cameras:
    cam #0
        sensor type:         imx214
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          0
        pre_width:           640
        pre_height:          480
        en_raw_preview:      0
        en_small_video:      1
        small_video_width:   1024
        small_video_height:  768
        en_large_video:      1
        large_video_width:   4208
        large_video_height:  3120
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         1
        snap_width:          4208
        snap_height:         3120
        exif_focal_length:   0.000000
        exif_focal_len_35mm_format:0
        exif_fnumber:        0.000000
        ae_mode:             isp
        msv_exposure_min_us: 20
        msv_exposure_max_us: 33000
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
        independent_exposure:0
    fsync_en:            0
    fsync_gpio:          109
    ERROR:   Found zero cameras connected, need at least one.
    I have made all connections as per the [C-08 configuration] however the camera is not being detected.
    (https://docs.modalai.com/voxl2-camera-configs/#c-08-hires-only)
    I appreciate any advice that can help me resolve this issue.
