  3. Using Relocalization to establish a global reference frame for Drone Swarm Demo
apriltag
3 Posts 2 Posters 2.7k Views 1 Watching
  • QuetzalcoatlQ Offline
    Quetzalcoatl
    Hello ModalAI Team,
    we currently are trying to prepare an indoor demo with multiple Qualcomm Flight RB5 drones. First i will share the configuration currently on the drones:
    system-image: 1.7.1-M0052-14.1a-perf-nightly-20231025
    kernel:       #1 SMP PREEMPT Thu Oct 26 05:24:02 UTC 2023 4.19.125
    hw version:   M0052
    voxl-suite:   1.1.2
    current IP: wlan0: 192.168.1.34
    Output of voxl-inspect-services
     voxl-camera-server       |  Enabled  |   Running   |    63.1%
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.5%
     voxl-feature-tracker     |  Enabled  | Not Running |
     voxl-imu-server          | Disabled  | Not Running |
     voxl-mavlink-server      |  Enabled  |   Running   |     2.7%
     voxl-microdds-agent      |  Enabled  |   Running   |     5.6%
     voxl-neopixel-manager    | Disabled  | Not Running |
     voxl-portal              |  Enabled  |   Running   |     0.1%
     voxl-px4-imu-server      |  Enabled  |   Running   |     0.9%
     voxl-px4                 |  Enabled  |   Running   |    38.4%
     voxl-qvio-server         |  Enabled  |   Running   |    20.4%
     voxl-streamer            |  Enabled  |   Running   |     0.1%
     voxl-tag-detector        |  Enabled  |   Running   |     4.2%
     voxl-vision-hub          |  Enabled  |   Running   |     1.8%
    Since the drones are going to fly indoors, they will operate in a GPS-denied area. We are already able to fly the drone in position mode with VIO tracking. For the use case of the demo however, this will not be enough, because we will need the drones to be positioned in a global coordinate system.
    The first approach to resolve this issue was trying out the Relocalization with April Tags. The voxl-vision-hub.conf file looks like this at the moment:
            "config_file_version":  1,
            "en_localhost_mavlink_udp":     true,
            "localhost_udp_port_number":    14551,
            "en_vio":       true,
            "vio_pipe":     "qvio",
            "secondary_vio_pipe":   "ov",
            "vio_warmup_s": 3,
            "send_odom_while_failed":       true,
            "horizon_cal_tolerance":        0.5,
            "offboard_mode":        "off",
            "follow_tag_id":        0,
            "figure_eight_move_home":       true,
            "collision_sampling_dt":        0.1,
            "max_lookahead_distance":       1,
            "en_tag_fixed_frame":   true,
            "fixed_frame_filter_len":       5,
            "en_transform_mavlink_pos_setpoints_from_fixed_frame":  true,
            "en_voa":       true,
            "voa_upper_bound_m":    -0.15000000596046448,
            "voa_lower_bound_m":    0.15000000596046448,
            "voa_voa_memory_s":     1,
            "voa_max_pc_per_fusion":        100,
            "voa_pie_max_dist_m":   20,
            "voa_pie_min_dist_m":   0.25,
            "voa_pie_under_trim_m": 1,
            "voa_pie_threshold":    3,
            "voa_send_rate_hz":     20,
            "voa_pie_slices":       36,
            "voa_pie_bin_depth_m":  0.15000000596046448,
            "voa_inputs":   [{
                            "enabled":      true,
                            "type": "point_cloud",
                            "input_pipe":   "dfs_point_cloud",
                            "frame":        "stereo_l",
                            "max_depth":    8,
                            "min_depth":    0.300000011920929,
                            "cell_size":    0.079999998211860657,
                            "threshold":    4,
                            "x_fov_deg":    68,
                            "y_fov_deg":    56,
                            "conf_cutoff":  0
                            "enabled":      true,
                            "input_pipe":   "stereo_front_pc",
                            "frame":        "stereo_front_l",
                            "max_depth":    8,
                            "threshold":    4,
                            "x_fov_deg":    68,
                            "y_fov_deg":    56,
                            "conf_cutoff":  0
                            "enabled":      true,
                            "input_pipe":   "stereo_rear_pc",
                            "frame":        "stereo_rear_l",
                            "max_depth":    8,
                            "threshold":    4,
                            "x_fov_deg":    68,
                            "y_fov_deg":    56,
                            "conf_cutoff":  0
                            "enabled":      true,
                            "type": "tof",
                            "input_pipe":   "tof",
                            "frame":        "tof",
                            "max_depth":    6,
                            "min_depth":    0.15000000596046448,
                            "threshold":    3,
                            "x_fov_deg":    106.5,
                            "y_fov_deg":    85.0999984741211,
                            "conf_cutoff":  125
                            "enabled":      true,
                            "type": "rangefinder",
                            "input_pipe":   "rangefinders",
                            "frame":        "body",
                            "max_depth":    8,
                            "threshold":    4,
                            "x_fov_deg":    68,
                            "y_fov_deg":    56,
                            "conf_cutoff":  0
    and the tag_locations.conf file looks like this:
            "locations":    [{
                            "id":   1,
                            "name": "origin",
                            "loc_type":     "fixed",
                            "size_m":       0.40000000596046448,
                            "T_tag_wrt_fixed":      [0, 0, 0],
                            "R_tag_to_fixed":       [[0, -1, 0], [1, 0, 0], [0, 0, 1]]
            "default_size_m":       0.40000000596046448
    For the sake of clarity i removed your comments here. We were able to confirm with the command voxl-vision-hub -p that the april tag is correctly recognized and value T_body_wrt_fixed relocates to closely [0,0,0] as expected. So we can confirm that the relocalization is internally working.
    The PC and all Drones are connected with the same WiFi. The goal is to control multiple drones with a single python script using MAVSDK running on the PC. This is where we would need your help
    async def run():
        drone = System()
        await drone.connect()
    The MAVSDK classes and functions are defined as following:
    class mavsdk.system.System(mavsdk_server_address=None, port=50051, sysid=245, compid=190)
    Bases: object
    Instantiate a System object, that will serve as a proxy to all the MAVSDK plugins.
    Parameters:
    mavsdk_server_address (str) – Address of a running mavsdk_server instance. If None, an instance of mavsdk_server will be automatically started (on localhost).
    port (int) – Port of the running mavsdk_server instance specified by mavsdk_server_address.
    sysid (int) – MAVLink system ID of the mavsdk_server (1..255).
    compid (int) – MAVLink component ID of the mavsdk_server (1..255).
    async connect(system_address=None)
    Connect the System object to a remote system.
    Parameters:
    system_address (str) –
    The address of the remote system. If None, it will default to udp://:14540. Supported URL formats:
    Serial: serial:///path/to/serial/dev[:baudrate]
    UDP: udp://[bind_host][:bind_port]
    TCP: tcp://[server_host][:server_port]
    Can you help us which parameters needs to be put in the System() and connect() to be able to control a drone in offboard flightmode. Or if we would need to do some adjustments on the voxl-mavlink-server.
    Thank you in advance for your help and let me know if you need any further information on our system/setup.
    With kind regards
    Julian
    • QuetzalcoatlQ Quetzalcoatl
      Hello ModalAI Team,
      hw version:   M0052
      voxl-suite:   1.1.2
              "en_vio":       true,
              "vio_pipe":     "qvio",
              "vio_warmup_s": 3,
              "follow_tag_id":        0,
              "en_voa":       true,
              "voa_inputs":   [{
                              "enabled":      true,
                              "max_depth":    8,
                              "threshold":    4,
                              "x_fov_deg":    68,
                              "y_fov_deg":    56,
                              "conf_cutoff":  0
                              "enabled":      true,
                              "max_depth":    8,
                              "threshold":    4,
                              "x_fov_deg":    68,
                              "y_fov_deg":    56,
                              "conf_cutoff":  0
                              "enabled":      true,
                              "max_depth":    8,
                              "threshold":    4,
                              "x_fov_deg":    68,
                              "y_fov_deg":    56,
                              "conf_cutoff":  0
                              "enabled":      true,
                              "type": "tof",
                              "frame":        "tof",
                              "max_depth":    6,
                              "threshold":    3,
                              "x_fov_deg":    106.5,
                              "conf_cutoff":  125
                              "enabled":      true,
                              "frame":        "body",
                              "max_depth":    8,
                              "threshold":    4,
                              "x_fov_deg":    68,
                              "y_fov_deg":    56,
                              "conf_cutoff":  0
              "locations":    [{
                              "id":   1,
                              "name": "origin",
      async def run():
          drone = System()
      Bases: object
      Parameters:
      Parameters:
      With kind regards
      Julian
      @Quetzalcoatl We have used mavsdk running on VOXL2 (versus on the PC). Some documentation is here: https://docs.modalai.com/mavsdk/. An example Python script is here: https://github.com/mavlink/MAVSDK-Python/blob/main/examples/takeoff_and_land.py. Hopefully this information can help you resolve your issue.
      QuetzalcoatlQ 1 Reply Last reply
        Quetzalcoatl
        @Eric-Katzfey Thank you for the reply,
        If I understand correctly, the example you provided shows MAVSDK running directly on the VOXL — so on the drone itself. However, we want to run our script on a separate PC to be able to control all drones at once. We're not sure which port to use to communicate with PX4 while also taking advantage of the relocalization handled by VOXL.
        Thank you again for your help!
