    voxl-streamer service down when using H.265
    VOXL SDK
    880
    • J
      Jskim
      Hi!
      1. We are using VOXL2 mini.
      2. VOXL2 mini version is SDK 1.4.3.
      3. Problem with voxl-streamer when using uvc camera h.265 encoder
      1. When using "h.265" in voxl-streamer.conf, voxl-streamer service dies.
        There is no problem at all in h.264.
        The player we use is VLC and potplayer.
      2. The config settings are as follows.
        [voxl-uvc-server.conf]
        -Resolution = 640x480
        -Frame = 20
        [voxl-streamer.conf]
        Bandwidth = 500000
        encoder = "h.265"
      3. The error code is as follows.
      4) Please tell me the solution.
      JS, Kim
        Alex Kushleyev ModalAI Team @Jskim
        Hello @Jskim,
        the parameter in voxl-streamer.conf should be h265, not h.265, i think behavior is undefined otherwise. The two options are h264 and h265. There should probably be a check for this.. I will add...
        Please try h265 and let me know if that fixes the issue.
        • J
          Jskim @Alex Kushleyev
          @Alex-Kushleyev
          Hi Ales,
          I think the above statement is wrong. Sorry. I inputted it as h265.
          There is no problem with h264, but voxl-streamer dies when I use only h265.
          JS, Kim
            @Jskim , can you please run voxl-streamer in foreground and paste the whole output (the full error description is cut off by the screen shot).
            Also please check which version of voxl-streamer you are using (voxl-version | grep voxl-streamer)
            • J
              @Alex-Kushleyev
              Currently alive, but have to wait until the streamer dies. Sometimes he dies.
              JS, Kim
              • J
                Jskim @Jskim
                @Jskim
                Send streamer error code
                JS, Kim
                • J
                  Jskim @Jskim
                  @Jskim
                  [The phenomenon is as follows]
                  Video Player restart
                  Video works normally (about 3 minutes)
                  Streamer is not dead, but the video is frozen.
                  Looking at the top command contents, Streamer CPU usage is 2.3%.
                  It stops for 5 minutes and then works normally again (about 1 minute).
                  It stops again. (CPU usage 1.9%)
                  Normal operation after 5 minutes
                  Video freezes after 1 minute (CPU usage 2.3%)
                  JS, Kim
                  • J
                    Jskim @Jskim
                    @Jskim
                    Finally, I tried a test.
                    I tried changing the video player and the Streamer died immediately.
                    The conclusion is that the Streamer died even when it was in the foreground.
                    JS, Kim
