  2. VOXL SDK and Software
  3. DFS undistort issue
DFS undistort issue
camera
2 Posts 2 Posters 912 Views 1 Watching
  • S Offline
    S Offline
    SKA
    wrote on last edited by SKA
    Hi! I'm trying to set up DFS using ar0144 cameras. I have the voxl-camera-server side working, and I'm able to view the stereo preview stream on voxl-portal. I've set up my extrinsics and intrinsics using voxl-calibrate-cameras and have acceptable reprojection error.
    However, when I run voxl-dfs-server I get these errors:
    ERROR computing undistort on left image in mcv_cvp_undistort_and_dfs_process
    ERROR performing undistort+DFS pipeline
    ERROR computing UD+DFS pipeline on CVP
    Whether I enable or disable cvp rectification in the .conf file, I am facing errors. Let me know how I might be able to resolve this, thanks!
    • S SKA
      @SKA , this is most likely due to the max disparity value being too large - for 1280x800 resolution the maximum value is 32.
      the max disparity parameter limit is as follows:
      • width <= 640 : max disparity = 64 (or less, in steps of 4)
      • 640 < width <= 1280 : max disparity 32 (or less in steps of 4)
      • 1280 < width <= 1920: 16, 12,8, or 4
      So in your case, you should update your max disparity parameter to 32 or less.
      I have been testing AR0144 DFS recently and i also found that i needed to increase the min_threshold and cost_threshold from the default of 10 that was used for OV7251. I found that values in the range of 50-80 produced good results.
      Here is some additional information regarding DFS:
      min_threshold:
      Lower bound for adjusting occlusion cost threshold.
      When set to < cost_threshold, the occlusion penalty
      is varied linearly from this minimum value from the first row
      to the last row.
      The last row takes cost_threshold.
      Range: 0 to 100
      Recommended range: 50 to 75
      min_threshold <= cost_threshold
      cost_threshold:
      Occlusion cost threshold.
      The higher the value, more smoothness is enforced.
      Range: 0 to 100
