m0065 connecting a sensor
Hi Modal AI Team.
I was wondering how I can connect inputs like sensors to voxl2 to read and process data. My current attempt is through m0065, the voxl2 io expander board but i dont quite get how i can flash the board to control and read the pwm channels (which i believe to be the only gpio available)..
Please let me know if this is even feasible at all.Thanks in advance!!
Hi Modal AI Team.
@andrevs01 , what sensors are you trying to connect to VOXL2? M0065 board is only used for PWM output and RC input (Sbus).
https://docs.modalai.com/voxl2-io-datasheet/
@Alex-Kushleyev Hi. Sorry for the delay in my response.
Currently i would just like to know how do i flash the board with my code to control a simple servo motor, or the luminosity of an led... What's the best approach to do that? I can't find any information on the SDK regarding the I/O expansion board.Later on, I would like to connect solenoid valves (On/Off) (i don't require a pwm output but that is the only I/O I have access).
The documentation is available here:
https://docs.modalai.com/voxl2-io-user-guide/
https://docs.modalai.com/voxl2-io-firmware/We do not provide a way to flash the board with your own code (although you could do it if you REALLY wanted to, since the board uses a standard STM32 processor).
For your use case, are you using PX4 or not? We normally control M0065 PWM outputs from PX4, but it is possible to do it without PX4.
@Alex-Kushleyev Thank you for the quick response Alex.
I don't necessarily need to develop my own code and flash the board, it's just the method I am familiar with working with previous uC...
But if I were to implement my sensors/pwm outputs through PX4 what would be the recommended steps to do so? Is there git libraries already available for it? If so, can I still change code snippets to operate under my conditions? or parameters in Qgroundcontrol?
Sorry if I am not clear with my questions but I'm pretty new to these types of complex architectures...Thank you again Alex and the Modal AI team
The documentation links I provided describe how to get M0065 board running in PX4 as a standard actuator that supports 8 PWM outputs.
If you are familiar with PX4, GCS, Actuators, then look through those documentation pages and follow the setup.
However, i don't have the full information about your hardware, so i don't know if you need some customizations:
- are you using voxl2 on a flying drone? if so, are you using a modalai ESC or another ESC?
- Are you planning to use M0065 board to generate pwm output for your ESC (if you are using a standard ESC that accepts PWM as control input)
- do you need to use PX4 for your application? the reason why I ask is that you can use M0065 pwm outputs without PX4 if you don't need PX4 at all.
