  3. Mini ESC with Motor spin problems
esc
2 Posts 2 Posters 482 Views 1 Watching
  • astro_philA Offline
    astro_philA Offline
    astro_phil
    Hi Team,
    I've bought 2 voxl mini ecs, but both have issue spinning up a motor connected on port 0. It seems to be stuck in the synchronisation phase when motor ist jumping back and forth.
    However the motor works fine on every other port. I also used the script to set params to the esc and the spin script to check. Also tested with different firmware versions of the voxl2-mini computer with no change.
    Any idea what the issue could be ?
    Thanks in advance
    Phil
    • astro_philA astro_phil
      Hi Team,
      Thanks in advance
      Phil
      @astro_phil can you please share a video of the issue and the esc params that you are using?
