  2. VOXL SDK and Software
  3. Stuck installing ros-melodic-pcl-conversions
ros
5 Posts 3 Posters 3.3k Views
  • V Offline
    V Offline
    VSK
    Hello
    I have installed ROS in VOXL 2 board using the instructions in the link https://docs.modalai.com/ros-installation-voxl2/.
    When I tried installing ros-melodic-PCL-conversions it took more than 30 minutes trying to install python-twisted-core
    Are there any alternatives or steps I am missing ...
    • Zachary Lowell 0Z Offline
      Zachary Lowell 0
      @vicky-s-karthik mind posting the exact commands that you ran?
      ROS melodic is fully deprecated - so my recommendation is to move over to ros2 foxy which is what we support on the voxl2 as of right now. I will try and recreate your issue in the meantime. Please try installing ros melodic base as the cv2 instance on there conflicts with opencv on voxl-sdk.
      V 2 Replies Last reply
        V Offline
        V Offline
        VSK
        @Zachary-Lowell-0
        The voxl2 board has the Ubuntu 18.04.5 LTS OS on it.
        So I installed ROS Medolic as mentioned in https://docs.modalai.com/ros-installation-voxl2/
        Then I tried installing the ros packages using the following command
        sudo apt-get install -y ros-melodic-pcl-ros ros-melodic-pcl-conversions
        but the installation is getting stuck at Setting up python-twisted-core (17.9.0-2ubuntu0.3)
        I ran tail -f /var/log/dpkg.log to check the status which showed
        configure python-twisted-core:all 17.9.0-2ubuntu0.3 <none>
        status half-configured python-twisted-core:all 17.9.0-2ubuntu0.3
        T 1 Reply Last reply
          V Offline
          V Offline
          VSK
          wrote on last edited by VSK
          @Zachary-Lowell-0
          Due to project requirements, I cannot change the OS version
          Please find the installation commands used
          voxl2:/$ sudo sh -c 'echo "deb http://packages.ros.org/ros/ubuntu $(lsb_release -sc) main" > /etc/apt/sources.list.d/ros-latest.list'
          voxl2:/$ sudo apt-key adv --keyserver 'hkp://keyserver.ubuntu.com:80' --recv-key C1CF6E31E6BADE8868B172B4F42ED6FBAB17C654
          voxl2:/$ sudo apt update
          voxl2:/$ apt install -y ros-melodic-ros-base ros-melodic-image-transport
          • V VSK
            @Zachary-Lowell-0
            T Offline
            T Offline
            teddy.zaremba
            wrote on last edited by teddy.zaremba
            @VSK said in Stuck installing ros-melodic-pcl-conversions:
            Maybe that package got corrupted on the install. Can you try running sudo apt-get clean?
            If that doesn't work, you could also try removing both of the packages and do the install again.
            $ sudo apt remove  python-twisted-core:all
            $ sudo apt remove ros-melodic-pcl-ros ros-melodic-pcl-conversions
