  3. Access position data at higher frequency
starling2 maxmavlinkoffboard-modestarling
3 Posts 1 Posters 1.6k Views
  • G Offline
    G Offline
    griffin
    Hey all,
    I'm trying to use offboard control mode to give velocity commands to a starling 2 max and need position information at higher than 10 Hz (the default rate at which mavlink position messages are published)
    Is it possible to access this information at a higher rate either by increasing the mavlink publishing rate or using MPA?
    Kind regards,
    Griffin
    G 1 Reply Last reply
    • G griffin
      Hey all,
      Kind regards,
      Griffin
      G Offline
      G Offline
      griffin
      For anyone running into similar issues, here is the solution I found:
      You can manually adjust the interval times of mavlink messages with the MAV_CMD_SET_MESSAGE_INTERVAL command, in this case for the LOCAL_POSITION_NED message.
      Using pymavlink this can be accomplished with:
              self.client = mavutil.mavlink_connection(
                  connection_string,
              self.client.mav.command_long_send(
                  self.client.target_system,
                  self.client.target_component,
                  mavutil.mavlink.MAV_CMD_SET_MESSAGE_INTERVAL,
                  0,  # confirmation
                  32, # LOCAL_POSITION_NED
                  10000, # Wait time in us
                  0, 0, 0, 0, 0  # param3-7: unused
      Hope this helps anyone else who wants higher rate data!
      • G griffin
                    connection_string,
                    0,  # confirmation
        G Offline
        G Offline
        griffin
        edit: use mavutil.mavlink.MAVLINK_MSG_ID_LOCAL_POSITION_NED* instead of magic number 32 for message ID
