    Access position data at higher frequency
    Starling & Starling 2
    starling2 max mavlink offboard-mode
    • G
      griffin
      Hey all,
      I'm trying to use offboard control mode to give velocity commands to a starling 2 max and need position information at higher than 10 Hz (the default rate at which mavlink position messages are published)
      Is it possible to access this information at a higher rate either by increasing the mavlink publishing rate or using MPA?
      Kind regards,
      Griffin
      • G
        griffin @griffin
        For anyone running into similar issues, here is the solution I found:
        You can manually adjust the interval times of mavlink messages with the MAV_CMD_SET_MESSAGE_INTERVAL command, in this case for the LOCAL_POSITION_NED message.
        Using pymavlink this can be accomplished with:
                self.client = mavutil.mavlink_connection(
                    connection_string,
                self.client.mav.command_long_send(
                    self.client.target_system,
                    self.client.target_component,
                    mavutil.mavlink.MAV_CMD_SET_MESSAGE_INTERVAL,
                    0,  # confirmation
                    32, # LOCAL_POSITION_NED
                    10000, # Wait time in us
                    0, 0, 0, 0, 0  # param3-7: unused
        Hope this helps anyone else who wants higher rate data!
        • G
          griffin @griffin
          edit: use mavutil.mavlink.MAVLINK_MSG_ID_LOCAL_POSITION_NED* instead of magic number 32 for message ID
