  2. VOXL SDK and Software
  3. custom uart usage
custom uart usage
voxl-sdk
5 Posts 2 Posters 861 Views 1 Watching
  • G Offline
    G Offline
    giladWDS
    I wanted to add a custom sensor to my voxel-2 through j19 UART.
    now I see that this UART is reserved to RC-inputs. but even when I disabled those in /etc/modalai/voxl-px4.conf, I still can't access the port.
    I looked a bit and found this:
    https://gitlab.com/voxl-public/voxl-sdk/core-libs/libqrb5165-io/-/tree/master/python?ref_type=heads
    and tried using it with port 7.
    when I tried to write it gave me the following:
    ERROR: voxl_uart_write: Bus '17' is not initialized
    and on init, it gave:
    Received standard error event SNS_STD_ERROR_NOT_SUPPORTED
    ERROR: fc_sensor_initialize failed
    ERROR: Failed to initialize slpi
    ERROR: Encountered error while initializing bus 17
    so it looks like it is still looking for some RC sensor.
    I guess my real question is how can I access SLPI UART as a user since I don't see them in /dev/tty*
    Thank you
    G 1 Reply Last reply
    • G giladWDS
      Thank you
      G Offline
      G Offline
      giladWDS
      @giladWDS To specify. my sensor is connected to a microcontroller. so also I prefer UART I can do i2c(I have tried and it didn't work as well) and I can do SPI if it works better.
      • G giladWDS
        @giladWDS The I/O on J19 is only for use with the DSP, not the Linux processor. If you are running PX4 then you would need to write a custom PX4 driver for your sensor. The libqrb5165-io library would allow access to the UART but only if PX4 is not already running on the DSP. It's either PX4 or libqrb5165-io, you cannot use both at the same time. You can get an applications processor (Linux processor) UART via some of our add-on boards but there isn't one available directly from any of the I/O connectors on VOXL 2.
          G Offline
          G Offline
          giladWDS
          wrote on last edited by giladWDS
          @Eric-Katzfey
          Thank you for the reply
          The only board I have no for testing is:
          MCCA-M0151-1
          I use the USB portion for the wifi and see that it exposes a uart port- HS1 for the external USB board.
          I can't seem to communicate with this HS0 port as a standalone port.
          Is it only for external Flight controllers?
          I looked into this:
          https://docs.modalai.com/usb2-type-a-breakout-add-on/
          but it seems to expose the same uart I can not talk to.
          Can you please recommend me a board that won't affect the wifi capability but would add uart ports that I desperately need?
          • EDIT:
            also if push comes to shove I would appreciate sources on how to write and compile a px4 driver that reads from the uart on j19.
          Thank you and best regards,
          Gilad
          • G giladWDS
            @Eric-Katzfey
            MCCA-M0151-1
            I looked into this:
            • EDIT:
            Gilad
            @giladWDS M0151 should expose /dev/ttyHS1 for use. It's just a UART so it isn't specific to external flight controllers.
