  3. ROS2 ToF topic not showing proper data
2 Posts 2 Posters 556 Views
  • U Offline
    U Offline
    user1243
    Hi I'm using a Starling 2 Max with a ToF sensor. I am using voxl-suite 1.3.4~beta2 and have the ToF sensor working in the voxl mapper. However, when I echo the ROS2 topic /tof_pc when running the voxl_mpa_to_ros2_node node I don't get proper data. See image below.
    Has anyone experienced this issue? Should I make the switch to ROS?
    • B Offline
      B Offline
      brahim
      Please verify the PC data in rviz2. What you see in rviz2 should look exactly alike to what is shown in voxal portal for tof_pc. Note that the point step size is 12. See this guide for more info on pointcloud data message data
      Point cloud data will look very different from image data, since the data field is constructed very different from BGR image formats.
      I have replicated these results in a starling2 as well, with voxl-mpa-to-ros2 dev branch:rospc_.png
      Note that you may need to spin up a static transform to see the pointcloud data in ROS:
      ros2 run tf2_ros static_transform_publisher 0 0 0 0 0 0 map world
