  2. VOXL Dev Kits
  3. Starling 2 MAX with position flight mode with VOXL
Scheduled Pinned Locked Moved VOXL Dev Kits
3 Posts 2 Posters 2.8k Views
  • TOMPLAT Offline
    TOMPLAT Offline
    TOMPLA
    When I try to fly Starling 2 MAX with position mode with VOXL.
    ,It is not possible to fly with error [No valid local position estimate].
    I checked VIO status with VOXL portal.
    It's QUAL=100% Ithink it's no problem.
    I have no idea to fix it and need advieses.
    James StrawsonJ 1 Reply Last reply
    • TOMPLAT TOMPLA
      James StrawsonJ Offline
      James Strawson
      wrote on last edited by James Strawson
      @TOMPLA
      Starling 2 Max comes out of the box with PX4's EKF2 configured for GPS outdoor flight.
      To fly indoors with VIO only you need to modify PX4's EKF2 parameters in QGC or with the voxl-configure-px4-params utility. In the EKF2_helpers menu, select "indoor_vio.params"
      voxl2:/$ voxl-configure-px4-params -w
      [INFO] Voxl-px4 service found and active.
      Select an option:
      [1] Quit
      [2] Reset ALL PX4 params to default
      [3] experimental_do_not_use
      [4] EKF2_helpers
      [5] battery_helpers
      [6] ci_helpers
      [7] voxl2_io_helpers
      [8] other_helpers
      [9] platforms
      [10] radio_helpers
      [11] voa_helpers
      [12] calibration files
      Select a EKF2 helper:
      [1] Quit
      [2] Back
      [3] outdoor_flow.params
      [4] outdoor_gps.params
      [5] outdoor_gps_baro.params
      [6] vio_gps_baro.params
      [7] indoor_vio.params
      [8] indoor_vio_missing_gps.params
      [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/EKF2_helpers/indoor_vio.params
      [INFO] Scanning currently loaded parameters...
      The following parameters about to be loaded differ from those currently loaded:
      	NAME    		CURRENT    	NEW
      [1]	EKF2_MAG_TYPE    	0.0		5.0
      [2]	EKF2_EV_CTRL    	0.0		15.0
      [3]	EKF2_HGT_REF    	1.0		3.0
      [4]	EKF2_GPS_CTRL    	7.0		0.0
      [5]	EKF2_EV_QMIN    	0.0		1.0
      Would you like to continue with the parameter differences listed above? (y/n)
      y
      [INFO] Setting params...
      [INFO] PX4 parameter configuration successful!
      Select an option:
      [1] Quit
      [4] EKF2_helpers
      [5] battery_helpers
      [6] ci_helpers
      [8] other_helpers
      [9] platforms
      [10] radio_helpers
      [11] voa_helpers
      voxl2:/$
      Then reboot the Starling and PX4 should be configured to use the VIO data.
      TOMPLAT 1 Reply Last reply
        @TOMPLA
        Select an option:
        [1] Quit
        [4] EKF2_helpers
        [5] battery_helpers
        [6] ci_helpers
        [8] other_helpers
        [9] platforms
        [10] radio_helpers
        [11] voa_helpers
        [1] Quit
        [2] Back
        	NAME    		CURRENT    	NEW
        y
        Select an option:
        [1] Quit
        [4] EKF2_helpers
        [5] battery_helpers
        [6] ci_helpers
        [8] other_helpers
        [9] platforms
        [10] radio_helpers
        [11] voa_helpers
        voxl2:/$
        TOMPLAT Offline
        TOMPLAT Offline
        TOMPLA
        @James-Strawson said in Starling 2 MAX with position flight mode with VOXL:
        NAME CURRENT NEW
        I check the param that you recommend , but It is not fixed.
        Starling 2MAX is already set same param.
        Should I check another point?
