    Help!!! When flying can't control speed
    velocitynedyaw
    • C
      cy208183395
      VelocityNedYaw fails when it controls the code of flight distance and speed, no matter how to adjust the parameters, it will fly at the same speed. And the orientation of the header at initialization is random rather than fixed to the north.
      #!/usr/bin/env python3
      import asyncio
      from mavsdk import System
      from mavsdk.offboard import (PositionNedYaw, VelocityNedYaw, OffboardError)
      async def run():
      drone = System()
      await drone.connect(system_address="udp://:14551")
      print("Waiting for drone to connect...")
      async for state in drone.core.connection_state():
          if state.is_connected:
              print(f"-- Connected to drone!")
              break
      # print("Waiting for drone to have a global position estimate...")
      # async for health in drone.telemetry.health():
      #     if health.is_global_position_ok and health.is_home_position_ok:
      #         print("-- Global position estimate OK")
      #         break
      print("-- Arming")
      await drone.action.arm()
      # need delay!!
      await asyncio.sleep(5)
      print("-- Setting initial setpoint")
      await drone.offboard.set_position_ned(PositionNedYaw(0.0, 0.0, 0.0, 0.0))
      print("-- Starting offboard")
      try:
          await drone.offboard.start()
      except OffboardError as error:
          print(f"Starting offboard mode failed with error code: {error._result.result}")
          print("-- Disarming")
          await drone.action.disarm()
          return
      # async def print_z_velocity(drone):
      #     async for odom in drone.telemetry.position_velocity_ned():
      #         print(f"{odom.velocity.north_m_s} {odom.velocity.down_m_s}")
      # asyncio.ensure_future(print_z_velocity(drone))
      # print("-- Go 0m North, 0m East, -10m Down within local coordinate system")
      # await drone.offboard.set_position_velocity_ned(
      #     PositionNedYaw(0.0, 0.0, -10.0, 0.0),
      #     VelocityNedYaw(0.0, 0.0, -1.0, 0.0))
      # await asyncio.sleep(10)
      # print("-- Go 10m North, 0m East, 0m Down within local coordinate system")
      #     PositionNedYaw(50.0, 0.0, -10.0, 0.0),
      #     VelocityNedYaw(1.0, 0.0, 0.0, 0.0))
      # await asyncio.sleep(20)
      print("-- Go 0m North, 0m East, -0.5m Down within local coordinate system")
          PositionNedYaw(0.0, 0.0, -0.5, 0.0),
      print("-- Go 0.5m North, 0m East, -0.5m Down within local coordinate system")
          PositionNedYaw(0.5, 0.0, -0.5, 90.0),
          VelocityNedYaw(0.2, 0.0, 0.0, 90.0)
      # print("-- Go 0.5m North, 0m East, -0.5m Down within local coordinate system")
      #     PositionNedYaw(0.3, 0.3, -0.5, 90.0),
      #     VelocityNedYaw(0.0, 0.2, 0, 0.0))
      # await asyncio.sleep(5)
      # await drone.action.land()
      try:
      except:
          print("Failed to land")
      try:
      except:
          print("Disarming failed")
      # print("-- Stopping offboard")
      # try:
      #     await drone.offboard.stop()
      # except OffboardError as error:
      #     print(f"Stopping offboard mode failed with \
      #             error code: {error._result.result}")
      if __name__ == "__main__":
          # Run the asyncio loop
          # asyncio.run(run())
          loop = asyncio.get_event_loop()
          loop.run_until_complete(run())
      • Eric KatzfeyE
        Eric Katzfey ModalAI Team @cy208183395
        @cy208183395 Can you test this with SITL? Does it work fine there but not on VOXL 2?
