VOXL 2 mini support for flir boson
has VOXL 2 Mini board support for Flir Boson cameras and are there additional components needed to connect to the Boson?
USB version should be ready to go:
USB connector on VOXL2 Mini (M0104) is J3. It's USB3 but USB2 can be used on it:
https://docs.modalai.com/voxl2-mini-connectors/#j3-usb-3-10-pinBoson 640 is USB2, but you can use this cable (likely event depop the USB3 portions and just use 4 wire)...
https://docs.modalai.com/cable-datasheets/#mcbl-00022voxl-uvc-server has Boson support:
https://docs.modalai.com/voxl-uvc-server/Streaming off target:
https://docs.modalai.com/voxl-streamer-0_9/#streaming-uvc-cameras-from-voxl-uvc-server -
https://docs.modalai.com/voxl-streamer-0_9/#streaming-uvc-cameras-from-voxl-uvc-serverThank you @modaltb, but I have selected Boson 320 (https://www.flircameras.com/thermal-imaging-cameras/thermal-imaging-cores/flir-boson-series.htm/flir-boson-320x256-2mm.htm). is this camera supported?
@Memmed-Shamurov although we haven't physically tried that one I would expect it to work, the source code for the voxl-uvc-server is open and maybe the resolution would need to be updated in config file, e.g. https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server/-/blob/master/src/config_file.h?ref_type=heads#L49
A 'backback' is needed to get USB out of the Bosons like this: https://www.flircameras.com/rhp-bos-vpc3-if.htm , so highly likely it would work
@Memmed-Shamurov it claims
USB Video Supportso it 'should' work although we've not tried this exact one.
