  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. Regarding building the mavsdk-python Docker image.
8 Posts 2 Posters 1.3k Views 1 Watching
  • C Offline
    C Offline
    cy208183395
    When I was preparing to follow the mavsdk-python tutorial , I encountered an issue with the command :
    voxl-configure-docker-support.sh
    As a workaround, I tried using the command:
    ./build-image.sh
    to execute this repo, but then I faced this problem:
    What should I do? My development board is VOXL2. Please help me, thank you!
    • C cy208183395
      ./build-image.sh
      @cy208183395 Have you installed Docker on target? It doesn't come preinstalled. The documentation is here: https://docs.modalai.com/docker-on-voxl/#configuration
      • C cy208183395
        ./build-image.sh
        @cy208183395 The voxl-configure-docker-support script is only used on VOXL. For VOXL 2 you need to install Docker and not run that script.
        C 2 Replies Last reply
          C Offline
          C Offline
          cy208183395
          @Eric-Katzfey said in Regarding building the mavsdk-python Docker image.:
          Thank you very much for your reply
            C Offline
            C Offline
            cy208183395
            @Eric-Katzfey
            I encountered a new problem. After I installed Docker as you suggested this website .I successfully started and ran it:
            But when I followed the tutorial to download the repository and executed the command
            ./build-image.sh
            it showed "command not found":
            I tried setting the environment variable, but it still didn't work.
            Then I continued to watch the tutorial video, entered the voxl2 shell, navigated to the folder /data/docker/mavsdk, and executed the command ./run-docker.sh. It still showed that the docker command was not found:
            This means that whether I am in the voxl2 shell environment or not, the docker command is not found.
            Can you help me? I followed your requirements, but I am stuck here. Please help me, thank you!
            • C cy208183395
              @Eric-Katzfey
              ./build-image.sh
              @cy208183395 Did you install Docker on your host machine or on VOXL 2? It needs to be installed on VOXL 2.
              C 1 Reply Last reply
                C Offline
                C Offline
                cy208183395
                @Eric-Katzfey Yes, I currently have Docker installed on my host machine, but it is not installed on the voxl2.
                • C cy208183395
                  @cy208183395 Yes, well then that is your problem. When you try to run it on VOXL 2 and you don't have Docker installed on VOXL 2 then you will see an error like docker: command not found. You have to install Docker on VOXL 2.
