  2. VOXL SDK and Software
  3. Error when launching mpa_to_ros2
ros
4 Posts 2 Posters 979 Views
  • J Offline
    Judoor 0
    I'm on the starling2 with sdk-1.3.
    I tried to follow the tutorial to install mpa_to_ros2 but at the end I can't run the mpa_to_ros2 node.
    First I installed ros2 on the voxl2, then I built the mpa_to_ros2 package on qrb5165 emulator
    (I did it with master branch and dev branch)
    And finally run ./deploy_to_voxl.sh then when running
    ros2 launch voxl_mpa_to_ros2 voxl_mpa_to_ros2.launch
    I've got this error message :
    [INFO] [launch]: All log files can be found below /opt/ros/foxy/log/2024-06-24-16-50-13-486942-m0054-9328
    [INFO] [launch]: Default logging verbosity is set to INFO
    Task exception was never retrieved
    future: <Task finished coro=<LaunchService._process_one_event() done, defined at /opt/ros/foxy/lib/python3.6/site-packages/launch/launch_service.py:226> exception=InvalidLaunchFileError('',)>
      File "/opt/ros/foxy/lib/python3.6/site-packages/launch/launch_service.py", line 228, in _process_one_event
        await self.__process_event(next_event)
      File "/opt/ros/foxy/lib/python3.6/site-packages/launch/launch_service.py", line 248, in __process_event
        visit_all_entities_and_collect_futures(entity, self.__context))
      File "/opt/ros/foxy/lib/python3.6/site-packages/launch/utilities/visit_all_entities_and_collect_futures_impl.py", line 45, in visit_all_entities_and_collect_futures
        futures_to_return += visit_all_entities_and_collect_futures(sub_entity, context)
      File "/opt/ros/foxy/lib/python3.6/site-packages/launch/utilities/visit_all_entities_and_collect_futures_impl.py", line 38, in visit_all_entities_and_collect_futures
        sub_entities = entity.visit(context)
      File "/opt/ros/foxy/lib/python3.6/site-packages/launch/action.py", line 108, in visit
        return self.execute(context)
      File "/opt/ros/foxy/lib/python3.6/site-packages/launch/actions/include_launch_description.py", line 130, in execute
        launch_description = self.__launch_description_source.get_launch_description(context)
      File "/opt/ros/foxy/lib/python3.6/site-packages/launch/launch_description_source.py", line 84, in get_launch_description
        self._get_launch_description(self.__expanded_location)
      File "/opt/ros/foxy/lib/python3.6/site-packages/launch/launch_description_sources/any_launch_description_source.py", line 53, in _get_launch_description
        return get_launch_description_from_any_launch_file(location)
      File "/opt/ros/foxy/lib/python3.6/site-packages/launch/launch_description_sources/any_launch_file_utilities.py", line 56, in get_launch_description_from_any_launch_file
        raise InvalidLaunchFileError(extension, likely_errors=exceptions)
    launch.invalid_launch_file_error.InvalidLaunchFileError: The launch file may have a syntax error, or its format is unknown
    I also tried installing mpa_to_ros2 by running apt-get install voxl-mpa-to-ros2
    But in the end the result was the same.
    Am I missing something ?
    Which tutorial am i suppose to follow ?
    Julien
    • Zachary Lowell 0Z Offline
      Zachary Lowell 0
      It is not a launch but a ros2 node itself - should just be ros2 run voxl_mpa_to_ros2 voxl_mpa_to_ros2, no launch script.
      Zach
      J 2 Replies Last reply
        Zach
        Judoor 0
        @Zachary-Lowell-0 said in Error when launching mpa_to_ros2:
        I've got
        "No executable found"
        when doing this command
        Julien
          Zach
          Judoor 0
          @Zachary-Lowell-0 well it work now!
          I found these lines on another thread of the forum:
          sudo apt-get install voxl-ros2-foxy
          sudo apt-get install voxl-mpa-to-ros2
          voxl-configure-mpa-to-ros2
          source /opt/ros/foxy/mpa_to_ros2/install/setup.bash
          export ROS_HOME=/opt/foxy
          ros2 run voxl_mpa_to_ros2 voxl_mpa_to_ros2_node
          And everything worked first time ! So please put these line directly on the documentation cause I lost so much time with this install !
