  2. VOXL SDK and Software
  3. Pipe Overflow Error
Pipe Overflow Error
mpa
6 Posts 2 Posters 3.9k Views 1 Watching
  • Jeffrey MaoJ Offline
    Jeffrey Mao
    Currently, I am using the voxl_mpa_to_ros2 repository. Do you have any idea what causes the following error
    ERROR: invalid metadata, magic number=0, expected 1448040524
    most likely client fell behind and pipe overflowed
    This only happens when I try streaming the depth_image through the piep> There is no problem with lowbandwith data like imu_app/qvio odometry. Do you know what the root cause is for this or if there is a way to solve this in ROS2?
    Jeff
    Alex KushleyevA Jeffrey MaoJ 2 Replies Last reply
    • Jeffrey MaoJ Jeffrey Mao
      Jeff
      @Jeffrey-Mao , does this happen occasionally (how often) or very frequently (every frame?)
        Jeff
        Jeffrey Mao
        This happens if we leave the pipe on while streaming depth_images from stereo_disparity for a minute or two. After which it happens very frequently.
          @Jeffrey-Mao , depth_image is just a regular image, correct (not a 3D point cloud)? What is publishing this image?
          Jeffrey MaoJ 1 Reply Last reply
            Jeffrey Mao
            @Alex-Kushleyev Sorry for the confusion I mean Disparity Image.
            On further examination, I think this is a network problem. When streaming high bandwith objects like Disparity images or images in general across wifi. I think effectively managing the bandwidth can alleviate this problem.
              @Jeffrey-Mao , no worries, thanks for the update!
