  3. Configuring battery monitor with FPV ESC
21 Posts 5 Posters 6.1k Views 2 Watching
    @restore, thank you for checking.
    Let's do another test:
    • for safety, remove propellers from motors
    • with px4 disabled, go to /usr/share/modalai/voxl-esc-tools on voxl2
    • run: ./voxl-esc-spin.py --id 2 --power 0 -- this will send a zero power command to ESC ID 2 (which measures the total current and sends back the battery status message). Motors will not spin. This will also request the battery status and you should see output (if possible you can use the latest voxl-esc tools from dev branch from (https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tree/dev) since I am not sure which voxl-esc version is installed on your board).
    Found voxl-esc tools bin version: 1.6
    VOXL Platform: M0054
    	Board      : version 42: ModalAi 4-in-1 ESC (M0138-1)
    [0.017] (2) RPM: 0, PWR: 0, VOLTAGE: 15.612V, TEMPERATURE: 35.87C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.612V, BOARD_CURRENT: -0.232A
    [0.034] (2) RPM: 0, PWR: 0, VOLTAGE: 15.609V, TEMPERATURE: 35.88C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.609V, BOARD_CURRENT: -0.200A
    [0.060] (2) RPM: 0, PWR: 0, VOLTAGE: 15.610V, TEMPERATURE: 35.86C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.610V, BOARD_CURRENT: -0.248A
    [0.080] (2) RPM: 0, PWR: 0, VOLTAGE: 15.618V, TEMPERATURE: 35.85C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.618V, BOARD_CURRENT: -0.224A
    [0.095] (2) RPM: 0, PWR: 0, VOLTAGE: 15.612V, TEMPERATURE: 35.87C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.612V, BOARD_CURRENT: -0.272A
    [0.120] (2) RPM: 0, PWR: 0, VOLTAGE: 15.608V, TEMPERATURE: 35.90C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.608V, BOARD_CURRENT: -0.240A
    [0.134] (2) RPM: 0, PWR: 0, VOLTAGE: 15.612V, TEMPERATURE: 35.92C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.612V, BOARD_CURRENT: -0.264A
    [0.160] (2) RPM: 0, PWR: 0, VOLTAGE: 15.613V, TEMPERATURE: 35.90C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.613V, BOARD_CURRENT: -0.248A
    [0.174] (2) RPM: 0, PWR: 0, VOLTAGE: 15.608V, TEMPERATURE: 35.92C, CURRENT: 0.000A, BOARD_VOLTAGE: 15.608V, BOARD_CURRENT: -0.168A
    note that there are BOARD_VOLTAGE and BOARD_CURRENT printed, which are parsed from the battery status message coming from the ESC ID2. Please note that the current around 0 is not very accurate due to a very large measurement range (showing -0.2A, but the discharge current should really be positive based on our convention).
    R Offline
    R Offline
    restore
    @Alex-Kushleyev
    Thanks for the help, as I was calibrating the ESCs I did notice those messages, which confused me as to why we weren't able to get that information in PX4. On Monday it suddenly just started working despite my changing nothing. Gotta love when things fix themselves
