  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. Powering the VOXL 2 as a Standalone Computer
5 Posts 3 Posters 1.4k Views 2 Watching
  • Mihir BalaM Offline
    Mihir BalaM Offline
    Mihir Bala
    I was wondering if anyone had insight on what battery to purchase for the VOXL 2 if I want to use it as a standalone lightweight mobile computer. I would ideally like the battery to weigh < 50g (the lighter the better) and would like for it to power the VOXL 2 for at least 30 minutes. I don't know much about batteries and so I would appreciate any help. Thanks!
    ? 1 Reply Last reply
    • Mihir BalaM Mihir Bala
      @Mihir-Bala
      We sell a number of batteries on our website https://www.modalai.com/collections/all?filter.p.tag=batteries
      Hope this helps!
      Thomas
        Mihir BalaM Offline
        Mihir Bala
        Hi Thomas,
        Thanks for your help. I was however looking for something much lighter, ideally under 50g. All of the batteries you sell are over 150g and are also designed to power the rotors (and so I assume are much more powerful than what is necessary to power just the VOXL 2). What specs should I look for if I just want to power the VOXL 2 and nothing else (other than, say, an attached 5G modem)? Thanks in advance for your assistance.
        VinnyV 1 Reply Last reply
          Hi Thomas,
          VinnyV Offline
          VinnyV Offline
          Vinny
          Hi @Mihir-Bala
          You will need a 2S minimum to satisfy all the requirements of our power module: https://docs.modalai.com/power-module-v3-datasheet/
          Then, you need to do the math to support a 30Watt transient on power up... which equates to a ~5amp burst at the low end of the 2S cell ~6.4V.
          So, if you have a 1,000mAh cell at 2S, that will require a 5C rating.
          If you have a 2,000mAh cell, you need ~2.5C rating, and so on...
          Hope this helped!
          Mihir BalaM 1 Reply Last reply
          • VinnyV Vinny
            Hi @Mihir-Bala
            Hope this helped!
            Mihir BalaM Offline
            Mihir BalaM Offline
            Mihir Bala
            @Vinny yes thanks so much! I'll look into it.
