  2. FAQs
  3. voxl_spi_init, failed to open /dev/spidev device: No such file or directory.
Scheduled Pinned Locked Moved Unsolved FAQs
30 Posts 4 Posters 9.7k Views 2 Watching
  • 이광철이 이광철
    @Alex-Kushleyev
    I tested according to your advice.
    This is the result of testing on my mini.
    voxl2-mini:~$ cd /usr/bin
    voxl2-mini:/usr/bin$ spidev_test -D /dev/spidev3.0 -p "\x76\x00\xF5\x00"
    spi mode: 0x0
    bits per word: 8
    max speed: 500000 Hz (500 KHz)
    can't send spi message: Invalid argument
    Aborted
    이광철이 Offline
    이광철이 Offline
    이광철
    @이광철
    Alex-Kushleyev sorry.
    spi mode: 0x0
    bits per word: 8
    Aborted
    This test was my mistake.
    Below are the final test results.
    spi mode: 0x0
    bits per word: 8
    RX | 00 00 00 47 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ | ...G
    • 이광철이 이광철
      @이광철
      spi mode: 0x0
      bits per word: 8
      Aborted
      spi mode: 0x0
      bits per word: 8
      @이광철 ,
      Please note that qrb5165io-spi-test -d 14 is a test app that just tries to detect a specific IMU on the SPI port. If the specific IMU is not connected, the test will not be successful.
      Are you able to read any data from your SPI sensor (using spidev_test -D /dev/spidev14.0 ... ? Can you share what your sensor is? You should look in the documentation of your sensor and it will tell you how to communicate with it. SPI protocol for reading / writing is specific to the device.
      Also, don't forget about the gpio setting that needs to be made before using SPI 14 (voxl-gpio -w 67 1). this needs to be run after each reboot.
      이광철이 1 Reply Last reply
        @이광철 ,
        이광철이 Offline
        이광철이 Offline
        이광철
        @Alex-Kushleyev
        Yes I know.
        My spi device and test program works fine on volx2's J10.
        Please refer to j10 in the url below.
        https://docs.px4.io/main/en/flight_controller/modalai_voxl_2.html
        • 이광철이 이광철
          @Alex-Kushleyev
          Yes I know.
          @이광철 , do you still have any issue? Does spidev_test work with spi 14?
            이광철이 Offline
            이광철이 Offline
            이광철
            @Alex-Kushleyev
            I tested it by connecting my spi device to j10.
            This spi device is working normally in voxl2.
            My program for testing also operates normally with this spi device in voxl2.
            voxl_spi_init(SPI_BUS, SPI_MODE_0, VOXL_SPI_MAX_SPEED) is OK
            but, there is no response to the voxl_spi_write function.
            • 이광철이 이광철
              @Alex-Kushleyev
              #26
              @이광철 , can you confirm that you are setting gpio 67 on voxl2 mini before testing spi 14?
                이광철이 Offline
                이광철이 Offline
                이광철
                @Alex-Kushleyev
                Yes.
                After executing voxl-gpio -w 67 1, run my test.
                voxl-gpio -r 67
                • 이광철이 이광철
                  @Alex-Kushleyev
                  Yes.
                  voxl-gpio -r 67
                  Hmm.. we will investigate.
                    Hi @이광철
                    Sorry for missing guidance, I do think an alias is also needed like this:
                    https://gitlab.com/voxl-public/system-image-build/meta-voxl2-bsp/-/commit/e97a22de6b4e5582fc276a963b958d01a478d56b#999b45d40c8aafd81669d788073c2ea1315dac66_66_62
                    Also for this to work, I believe you will want to use the older devcfg.mbn file as well from SDK 1.0.0 as that has trustzone setup for SPI, and the new devcfg.mbn is setup for UART.
                    If trustzone isn't configured correctly I do think the kernel halts on bootup.
                    Flashing devcfg.mbn is like this, which is likely needed once alias is setup, to convert back to SPI from UART.
                    fastboot flash devcfg_a devcfg.mbn
                    fastboot flash devcfg_b devcfg.mbn
                    • modaltbM modaltb
                      Hi @이광철
                      이광철이 Offline
                      이광철이 Offline
                      이광철
                      @modaltb
                      Hi.
                      I try a test on voxl-mini with your advice applied.
                      voxl-mini sdk version is 1.0.0
                      My program and spi device operates is normal.
                      Thanks for your advice.
                      • H Haxerus referenced this topic on
