  2. FAQs
  3. voxl_spi_init, failed to open /dev/spidev device: No such file or directory.
Scheduled Pinned Locked Moved Unsolved FAQs
30 Posts 4 Posters 10.1k Views 2 Watching
    @이광철 , if you update just the kernel (or boot using a temporary one), the rest of the file system is unaffected, so voxl suite will remain the same. You can look at the kernel build dates to see the difference (it is also printed when you start adb shell).
    I am not sure why spi is not showing up, will need to ask @admin
    Maybe the change spi ->uart was actually made before sdk 1.1.1. We will need to double check that.
      #14
      I confirmed that kernel from SDK 1.1.1 does not have the spi mapped. So i tried the kernel from SDK 1.0.0 and it does. In this case my board has SDK 1.1.1 installed, but i am booting into kernel from SDK 1.0.0.
      voxl2/builds/voxl2-mini_SDK_1.0.0/system-image$ adb reboot bootloader
      voxl2/builds/voxl2-mini_SDK_1.0.0/system-image$ fastboot boot qti-ubuntu-robotics-image-m0104-boot.img
      Sending 'boot.img' (17552 KB)                      OKAY [  0.508s]
      Booting                                            OKAY [  0.034s]
      Finished. Total time: 0.573s
      adb shell
      system-image: 1.7.1-M0104-14.1a-perf-nightly-20231025
      kernel:       #1 SMP PREEMPT Fri May 19 22:53:15 UTC 2023 4.19.125
      hw version:   M0104
      voxl-suite:   1.1.1
      no current network connection
      voxl2-mini:/$ ls /dev/spidev*
      /dev/spidev0.0  /dev/spidev11.0  /dev/spidev14.0  /dev/spidev3.0
      Now, i am not sure why your manual kernel build did not work. if you still cannot get it to work, let us know, we can build it with spi enabled and test it for you.
      이광철이 1 Reply Last reply
        adb shell
        hw version:   M0104
        voxl-suite:   1.1.1
        이광철이 Offline
        이광철이 Offline
        이광철
        I downloaded voxl2-mini_SDK_1.0.0.tar.gz from https://developer.modalai.com/asset/eula-download/127
        It was tested as follows.
        C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>adb reboot bootloader
        C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>fastboot flash boot_a qti-ubuntu-robotics-image-m0104-boot.img
        Sending 'boot_a' (17552 KB) OKAY [ 0.399s]
        Writing 'boot_a' OKAY [ 0.023s]
        Finished. Total time: 0.565s
        C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>fastboot flash boot_b qti-ubuntu-robotics-image-m0104-boot.img
        Sending 'boot_b' (17552 KB) OKAY [ 0.397s]
        Writing 'boot_b' OKAY [ 0.019s]
        Finished. Total time: 0.561s
        C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>fastboot reboot
        Rebooting OKAY [ 0.000s]
        Finished. Total time: 0.005s
        C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>adb shell
        hw version: M0104
        voxl-suite: 1.1.2
        voxl2-mini:/dev$ ls spi*
        spidev0.0 spidev11.0 spidev14.0 spidev3.0
        OK!
        The spidev14.0 file exists.
        I tested it as below:
        voxl2-mini:/dev$ qrb5165io-spi-test -d 0
        failed to ping icm42688p IMU
        voxl2-mini:/dev$ qrb5165io-spi-test -d 11
        voxl2-mini:/dev$ qrb5165io-spi-test -d 3
        [INFO] success! ICM42688 Detected
        voxl2-mini:/dev$ qrb5165io-spi-test -d 14
        There is no response to the qrb5165io-spi-test -d 14 command.
        is this right?
        Is spidev14.0 not working?
        • 이광철이 이광철
          hw version: M0104
          voxl-suite: 1.1.2
          OK!
          is this right?
          @이광철 , do you have anything connected to spidev14.0 ? You need a device connected to the spi port.
          If you look at the source code for this test app, it simply tries to ping a specific IMU device, which happens to be installed on board on SPI3 (ICM42688 IMU) : https://gitlab.com/voxl-public/voxl-sdk/core-libs/libqrb5165-io/-/blob/master/apps/examples/qrb5165io-spi-test.c
          So, you should connect your desired device to J10 and modify the example to communicate with your device.
          Also, based on this documentation, https://docs.modalai.com/voxl2-mini-connectors/#j10-pin-out-spi-mode-gpio_67--low-kernel-rebuild-required-to-use, you need to set the GPIO before using:
          voxl-gpio -w 67 1
          I hope that helps
          Alex KushleyevA 이광철이 2 Replies Last reply
            voxl-gpio -w 67 1
            I hope that helps
            Another quick tip for testing SPI stuff. I found this useful:
            https://github.com/rm-hull/spidev-test/blob/master/spidev_test.c
            You can download this file to VOXL2, build it using
            gcc -O2 spidev_test.c -o spidev_test
            and then you can actually query the IMU on spi 3:
            voxl2-mini:~$ ./spidev_test -D /dev/spidev3.0 -p "\x76\x00\xF5\x00"
            spi mode: 0x0
            bits per word: 8
            max speed: 500000 Hz (500 KHz)
            RX | 00 00 00 47 ...
            and from here we know that 0x47 is actually the value WHOAMI register of ICM42688 IMU 🙂
            The data i am sending to the device is 4 bytes used to query the imu, as done here . the value 0xF5 = 0x75 | 0x80 which tells the IMU to send back the value of register 0x75
              voxl-gpio -w 67 1
              I hope that helps
              이광철이 Offline
              이광철이 Offline
              이광철
              I will connect my spi device and let you know the results after testing.
              Thanks for your help.
                spi mode: 0x0
                bits per word: 8
                이광철이 Offline
                이광철이 Offline
                이광철
                Hi.
                I tested it by connecting my spi device to j10.
                This spi device is working normally in voxl2.
                My program for testing also operates normally with this spi device in voxl2.
                However, when I test the spi device and test program on voxl mini, there is no response to the voxl_spi_write function.
                Also, the test below is the same as before.
                I need your help and thanks in advance.
                  spi mode: 0x0
                  bits per word: 8
                  이광철이 Offline
                  이광철이 Offline
                  이광철
                  I tested according to your advice.
                  This is the result of testing on my mini.
                  voxl2-mini:~$ cd /usr/bin
                  voxl2-mini:/usr/bin$ spidev_test -D /dev/spidev3.0 -p "\x76\x00\xF5\x00"
                  spi mode: 0x0
                  bits per word: 8
                  can't send spi message: Invalid argument
                  Aborted
                  • 이광철이 이광철
                    spi mode: 0x0
                    bits per word: 8
                    Aborted
                    이광철이 Offline
                    이광철이 Offline
                    이광철
                    @이광철
                    Alex-Kushleyev sorry.
                    spi mode: 0x0
                    bits per word: 8
                    Aborted
                    This test was my mistake.
                    Below are the final test results.
                    spi mode: 0x0
                    bits per word: 8
                    RX | 00 00 00 47 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ | ...G
                    • 이광철이 이광철
                      @이광철
                      spi mode: 0x0
                      bits per word: 8
                      Aborted
                      spi mode: 0x0
                      bits per word: 8
                      @이광철 ,
                      Please note that qrb5165io-spi-test -d 14 is a test app that just tries to detect a specific IMU on the SPI port. If the specific IMU is not connected, the test will not be successful.
                      Are you able to read any data from your SPI sensor (using spidev_test -D /dev/spidev14.0 ... ? Can you share what your sensor is? You should look in the documentation of your sensor and it will tell you how to communicate with it. SPI protocol for reading / writing is specific to the device.
                      Also, don't forget about the gpio setting that needs to be made before using SPI 14 (voxl-gpio -w 67 1). this needs to be run after each reboot.
                        @이광철 ,
                        이광철이 Offline
                        이광철이 Offline
                        이광철
                        Yes I know.
                        My spi device and test program works fine on volx2's J10.
                        Please refer to j10 in the url below.
                        https://docs.px4.io/main/en/flight_controller/modalai_voxl_2.html
                        • 이광철이 이광철
                          Yes I know.
                          @이광철 , do you still have any issue? Does spidev_test work with spi 14?
                            이광철이 Offline
                            이광철이 Offline
                            이광철
                            voxl_spi_init(SPI_BUS, SPI_MODE_0, VOXL_SPI_MAX_SPEED) is OK
                            but, there is no response to the voxl_spi_write function.
                            • 이광철이 이광철
                              #26
                              @이광철 , can you confirm that you are setting gpio 67 on voxl2 mini before testing spi 14?
                                이광철이 Offline
                                이광철이 Offline
                                이광철
                                Yes.
                                After executing voxl-gpio -w 67 1, run my test.
                                voxl-gpio -r 67
                                • 이광철이 이광철
                                  Yes.
                                  voxl-gpio -r 67
                                  Hmm.. we will investigate.
                                  • modaltbM Offline
                                    modaltbM Offline
                                    modaltb
                                    Hi @이광철
                                    Sorry for missing guidance, I do think an alias is also needed like this:
                                    https://gitlab.com/voxl-public/system-image-build/meta-voxl2-bsp/-/commit/e97a22de6b4e5582fc276a963b958d01a478d56b#999b45d40c8aafd81669d788073c2ea1315dac66_66_62
                                    Also for this to work, I believe you will want to use the older devcfg.mbn file as well from SDK 1.0.0 as that has trustzone setup for SPI, and the new devcfg.mbn is setup for UART.
                                    If trustzone isn't configured correctly I do think the kernel halts on bootup.
                                    Flashing devcfg.mbn is like this, which is likely needed once alias is setup, to convert back to SPI from UART.
                                    fastboot flash devcfg_a devcfg.mbn
                                    fastboot flash devcfg_b devcfg.mbn
                                    • modaltbM modaltb
                                      Hi @이광철
                                      이광철이 Offline
                                      이광철이 Offline
                                      이광철
                                      @modaltb
                                      Hi.
                                      I try a test on voxl-mini with your advice applied.
                                      voxl-mini sdk version is 1.0.0
                                      My program and spi device operates is normal.
                                      Thanks for your advice.
                                      • H Haxerus referenced this topic on
