  3. M0040 Time of Flight sensor FPS
image-sensor
29 Posts 3 Posters 8.1k Views 2 Watching
    @Alex-Kushleyev right now the FPS values need to be a multiple of 15 for some reason because I tried 35, and 20 FPS and the camera server refuses to start
    @Darshit-Desai , i will double check the available FPS. Not all arbitrary FPS are possible.
      If you run “voxl-camera-server -d 0”, you will see a lot of debug messages including all possible tof modes. If you see something you want to try, you can modify the code. Mode9 is long range and mode5 is short range.
      Darshit DesaiD 1 Reply Last reply
        Darshit DesaiD Offline
        Darshit Desai
        @Alex-Kushleyev I dont see mode descriptions when I try this
        voxl2:/etc/modalai$ voxl-camera-server -d 0
        detected system image 1.7.1
        using new imx214 defaults
        configuration for 3 cameras:
        cam #0
            sensor type:         pmd-tof
            isEnabled:           1
            camId:               0
            camId2:              -1
            fps:                 20
            en_rotate:           0
            en_rotate2:          0
            en_preview:          1
            pre_width:           224
            pre_height:          1557
            en_raw_preview:      1
            en_small_video:      0
            small_video_width:   -1
            small_video_height:  -1
            en_large_video:      0
            large_video_width:   -1
            large_video_height:  -1
            en_snapshot:         0
            snap_width:          -1
            snap_height:         -1
            ae_mode:             off
            standby_enabled:     0
            decimator:           5
            independent_exposure:0
        cam #1
            sensor type:         imx214
            isEnabled:           1
            camId:               1
            camId2:              -1
            fps:                 30
            en_rotate:           0
            en_rotate2:          0
            en_preview:          0
            pre_width:           640
            pre_height:          480
            en_raw_preview:      0
            en_small_video:      1
            small_video_width:   1024
            small_video_height:  768
            en_large_video:      1
            large_video_width:   4208
            large_video_height:  3120
            en_snapshot:         1
            snap_width:          4208
            snap_height:         3120
            ae_mode:             isp
            standby_enabled:     0
            decimator:           1
        cam #2
            sensor type:         ov7251
            isEnabled:           1
            camId:               2
            camId2:              -1
            fps:                 30
            en_rotate:           0
            en_rotate2:          0
            en_preview:          1
            pre_width:           640
            pre_height:          480
            en_raw_preview:      1
            en_small_video:      0
            en_large_video:      0
            en_snapshot:         0
            snap_width:          -1
            snap_height:         -1
            ae_mode:             lme_msv
            standby_enabled:     0
            decimator:           1
        DEBUG:   ----------- Number of cameras: 3
        DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x007A, Sensor Id: 0x003D
        DEBUG:   Cam idx: 1, Cam slot: 2, Slave Address: 0x0020, Sensor Id: 0x0214
        DEBUG:   Cam idx: 2, Cam slot: 3, Slave Address: 0x00E2, Sensor Id: 0x7750
        GPS server Connected
        DEBUG:   Connected to cpu-monitor
        DEBUG:   ------ voxl-camera-server: Starting 3 cameras
        Starting Camera: tof (id #0)
        DEBUG:   Checking Gain limits for Camera: tof
        Using gain limits min: 54 max: 8000
        DEBUG:   cam ID 0 checking for fmt:   38  w:  224 h: 1557 o:   0
        DEBUG:   i:  0 fmt: 34 w: 176 h: 144 o:0
        DEBUG:   i:  4 fmt: 34 w: 176 h: 144 o:1
        DEBUG:   i:  8 fmt: 35 w: 176 h: 144 o:0
        DEBUG:   i: 12 fmt: 35 w: 176 h: 144 o:1
        DEBUG:   i: 16 fmt: 33 w: 176 h: 144 o:0
        DEBUG:   i: 20 fmt: 37 w: 224 h:1557 o:0
        DEBUG:   i: 24 fmt: 38 w: 224 h:1557 o:0
        DEBUG:   i: 28 fmt: 32 w: 224 h:1557 o:0
        DEBUG:   i: 32 fmt: 36 w: 224 h:1557 o:0
        VERBOSE: Successfully found configuration match for camera 0: 224x1557
        VERBOSE: Adding preview stream for camera: 0
        DEBUG:   Converted gralloc flags 0x20900 to GBM flags 0x1400000
        VERBOSE: Dumping GBM flags
        DEBUG:   	Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI
        DEBUG:   	Found flag GBM_BO_USAGE_HW_COMPOSER_QTI
        VERBOSE: Opened GBM fd
        VERBOSE: Created GBM device
        DEBUG:   Allocated BO with width=224 height=1557 stride=336 aligned_w=336 aligned_h=1557 size=524288 flags=0x20900 format=GBM_FORMAT_RAW12
        DEBUG:   Successfully set up pipeline for stream: PREVIEW
        VERBOSE: Entered thread: cam0-request(tid: 3925)
        DEBUG:   Started Camera: tof
        Starting Camera: hires (id #1)
        ERROR:   Invalid TOF framerate: 20, must be either 5 or 15
        ERROR:   Failed to construct request settings for camera: tof
        WARNING: Thread: tof request thread Received ESTOP
        VERBOSE: Leaving tof request thr
        ```ead
          cam #0
              isEnabled:           1
              camId:               0
              camId2:              -1
              fps:                 20
              en_rotate:           0
              en_rotate2:          0
              en_preview:          1
              pre_width:           224
              pre_height:          1557
              en_raw_preview:      1
              en_small_video:      0
              en_large_video:      0
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             off
              standby_enabled:     0
              decimator:           5
          cam #1
              sensor type:         imx214
              isEnabled:           1
              camId:               1
              camId2:              -1
              fps:                 30
              en_rotate:           0
              en_rotate2:          0
              en_preview:          0
              pre_width:           640
              pre_height:          480
              en_raw_preview:      0
              en_small_video:      1
              en_large_video:      1
              en_snapshot:         1
              snap_width:          4208
              snap_height:         3120
              ae_mode:             isp
              standby_enabled:     0
              decimator:           1
          cam #2
              sensor type:         ov7251
              isEnabled:           1
              camId:               2
              camId2:              -1
              fps:                 30
              en_rotate:           0
              en_rotate2:          0
              en_preview:          1
              pre_width:           640
              pre_height:          480
              en_raw_preview:      1
              en_small_video:      0
              en_large_video:      0
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             lme_msv
              standby_enabled:     0
              decimator:           1
          ```ead
          Darshit Desai
          wrote on last edited by Darshit Desai
          #24
          @Alex-Kushleyev I found where the code changes were done and technically all arbitrary frame rates should work if we remove the == comparison with a range based comparison, but before changing that is there a reason why it is kept discrete? Can this discrete values be made into multiples of 5?
          if(configInfo.fps != 5 && configInfo.fps != 15 && configInfo.fps != 30 && configInfo.fps != 45 && configInfo.fps != 60) {
                      M_ERROR("Invalid TOF framerate: %d, must be either 5 or 15\n", configInfo.fps);
                      return -1;
          Because the settings selection for long_range or short_range is just a simple if else condition
                        return -1;
            @Darshit-Desai ,
            First set the framerate to one that is currently supported, then run voxl-camera-server -d 0. Then you will see the possible tof modes.
            The tof sensor does not support arbitrary fps
              @Darshit-Desai ,
              Darshit Desai
              @Alex-Kushleyev I got it about the debug command.
              On the topic of arbitrary fps, the sensor supports only 5, 15, 30, 45 and 60 according to the above code snippet. Nothing in the middle not even fps with multiples of 10 or 5. (Like 20, 25, 40, 50, 55)
                #27
                @Darshit-Desai , this check i added quickly just to allow additional rates other than 5 and 15 originally supported.
                Based on the output of the supported use cases (from voxl-camera-server -d 0 | grep usecase), here are all the supported modes:
                Long Range: 5, 10, 15, 20, 30
                Short Range: 15, 30, 45, 60
                Based on this information, you can experiment with the short / long range and desired FPS by modifying the camera server code directly (including logic for checking fps and setting long/short range). In future we will most likely add a param for selecting the range mode.
                Just to clarify, the use case information that lists range mode and fps is printed from the low level TOF driver, but the fps checks that you are referring to are in camera server high level code.
                  Darshit Desai
                  @Alex-Kushleyev So I got it how to check the long range and short range modes, the last commit on the code shows that you only changed the if condition and the LONG_RANGE & SHORT_RANGE settings. For multiple FPS rates can I just edit the code to add something like this,
                          setExposure = 2259763;
                          setGain     = 200;
                          if(configInfo.fps != 5 && configInfo.fps != 15) {
                          if(configInfo.fps != 5 && configInfo.fps != 15 && configInfo.fps != 30 && configInfo.fps != 45 && configInfo.fps != 60 && configInfo.fps != 10 && configInfo.fps != 20) {
                              M_ERROR("Invalid TOF framerate: %d, must be either 5, 10, 15, 20, 30, 45, 60 \n", configInfo.fps);
                              return -1;
                          initializationData.numDataTypes  = 1;
                          initializationData.pListener     = this;
                          initializationData.frameRate     = configInfo.fps;
                          initializationData.range         = RoyaleDistanceRange::LONG_RANGE;
                          //Change the below condition according to testing
                          if (configInfo.fps <= 15) {
                              M_DEBUG("Selecting TOF Long Rage setting\n");
                          else {
                              initializationData.range         = RoyaleDistanceRange::SHORT_RANGE;
                              M_DEBUG("Selecting TOF Short Rage setting\n");
                          #ifdef APQ8096
                              VCU_silent(
                            setGain     = 200;
                                return -1;
                            else {
                            #ifdef APQ8096
                                VCU_silent(
                    @Darshit-Desai , yes, feel free to modify the code as you need for right now for your own testing. Once i have a chance, i will make the mode selection (long / short) and FPS more flexible.
                    I hope this unblocked your work and you can move forward.
