ELRS
I am currently trying to pair beta fpv elrs reciever with version 3.2.1 i was able to flash it using voxl 2, but i am not able to bind it using radio master transmitter.
BETA FPV ELRS RX24T rx on band 2.4GHz.
Both the Tx and Rx have the same software version.
Currently running voxl-suite 1.1.2.
I am also not able to connect ExpressLRS 2.4GHz ELRS with voxl 2 either. Its not getting detected.If this is not possible
Kindly also suggest how i can connect both Voxl 2 IO and and voxl ESC together with the new software version.
I have the latest IO board with the latest firmware and bootloader. -
I have the latest IO board with the latest firmware and bootloader.@Jetson-Nano can you please help by providing the information requested here?
@Moderator
sure- we are using Starling V2 with voxl 2 system image 1.7.1
- Voxl-suite: 1.1.2
- Output of voxl-inspect-services:
We dont have px4 logs as we haven't started with any flight test.
Starling v2 came with 915MHz ELRS from BETAFPV. Ths however was in compatible with our transmitter and it wouldn't bind. Hence, we shifted to BETA FPV ELRS RX24T rx on band 2.4GHz which is compatible with our Transmitter.
We changed the firmware to 3.2.1.3 for both the Rx and Tx [as mentioned on voxl docs]
However, the Rx wasn't recognised with voxl-elrs scan [even though the Rx was in bootloader mode].
Hence, we tried flashing it from voxl which was sucessful. However, now the Rx isnt binding with our Tx yet again.
Throughout all the steps, wiring was cross- checked to ensure that there were no errors there.
I wanted to know how to proceed to connect my 2.4GHz band ELRS with voxl directly.
If this is not possible or if the troubleshooting steps provided are not successful, then I can connect my PX4IO board to voxl 2 for Rx along with voxl-ESC to connect to the motors as the voxl 4 in 1 esc only supports UART comms. -
@Moderator
It wold be really helpful if you could tell me the above details at the earliest. -
@Moderator
It wold be really helpful if you could tell me the above details at the earliest.@Chad-Sweet @Eric-Katzfey @tom
Can you please look into and me us out -
Hi @Jetson-Nano, we only support flashing the 915Mhz BetaFPV Nano Rx via voxl2. You will need to follow the instructions on the ELRS website to flash the 2.4G RX that you have, search on this quickstart page in the receivers section and follow the instructions for your particular rx.
You can download the ELRS configurator which is the tool provided by ELRS for flashing transmitters and receivers.
-Jacob
A Alex Kushleyev referenced this topic on
