IMX412 for camera configuration 11 on SDK 1.1.2
I am trying to get the VOXL2 running SDK 1.1.2 and camera configuration 11 to use the IMX412 instead of the IMX214. I had this functioning in SDK 1.0, however when I try to run the command
voxl-configure-cameras 11 --imx412like I did in SDK 1.0 it tells me that it is and invalid command. I can runvoxl-configure-cameras 11with no issues.When I pull up
voxl-portalin my web browser it does not show the option to view the hires camera. I have the modified thevoxl-camera-server.confto set the resolution of the IMX412 to 1920x1080 and I also tried to change imx214 to imx412 and that yielded the same results.When running
voxl-camera-serverI see a error that say failure to find hires stream at 1920x1080. -
voxl-camera-serverI see a error that say failure to find hires stream at 1920x1080.@Chase-Riley, how are you connecting IMX412 to VOXL 2?
- which camera port on VOXL2
- what flex / adapter are you using
- which part of flex are you connecting IMX412 to (if it is a dual flex)
Does your configuration look like this ? https://docs.modalai.com/voxl2-camera-configs/#c-17-tof-tracking-stereo0v9782-and-hiresimx412 (you can ignore other cameras, mainly asking about imx412 location)
@Alex-Kushleyev I followed the connection diagram for C-11. Which shows a different configuration than the C-17 you sent here. I am connecting the longest part of the dual flex to the hires camera. This configuration worked in SDK 1.0.
@Chase-Riley , C11 uses a different camera (IMX214), so you did this setup and instead of 214 connected imx412? just wanted to confirm : https://docs.modalai.com/voxl2-camera-configs/#c-11-front-stereo-rear-stereo-hires-and-tracking-d0006-sentinel
@Alex-Kushleyev yes. Exactly. My configuration is c11 just with s 412 instead of the 214.
OK, here is a trick..
i connected tracking cam and IMX412 as shown in C11 (IMX412 instead of IMX214).
Then,
voxl-configure-cameras (select 11)Then you see the following:
copying required camera drivers in place /usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_0.bin /usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_1.bin /usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_2.bin /usr/share/modalai/chi-cdk/imx214/com.qti.sensormodule.imx214_3.bin /usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_4.bin /usr/share/modalai/chi-cdk/ov7251-combo/com.qti.sensormodule.ov7251_combo_5.binThis means that the original C11 configuration is expecting IMX214 in slot
3. Now, since we don't have imx214, go too/usr/lib/camera, removecom.qti.sensormodule.imx214_3.binand copy IMX412 sensormodule:cp /usr/share/modalai/chi-cdk/imx412/com.qti.sensormodule.imx412_3.bin /usr/lib/camera/then...
voxl-camera-server -l DEBUG: Attempting to open the hal module DEBUG: SUCCESS: Camera module opened on attempt 0 DEBUG: ----------- Number of cameras: 2 DEBUG: Cam idx: 0, Cam slot: 2, Slave Address: 0x00E2, Sensor Id: 0x7750 DEBUG: Cam idx: 1, Cam slot: 3, Slave Address: 0x0034, Sensor Id: 0x0577Remember, i only have two cameras plugged in.. tracking and imx412
sensor ID
0x0577is for IMX412, also you will see supported resolutions.Then you have to go to
/etc/modalai/voxl-camera-server.confand change the hires camera resolution. IMX412 does not support the same max resolution as IMX412. IMX214 : 4208x3120, IMX412 : 4056x3040. However you can choose a standard resolution4k (3840x2160)or1080p (1920x1080)which are supported by all hires camssave the config and start
voxl-camera-serverin foreground to see the ouput / debug printsvoila!
Then,
sensor ID
@Alex-Kushleyev Awesome! That got it working. Now one last thing on this. How can I flip the image of the imx412? Would it still be a driver that said
flipafter it? -
flipafter it?@Chase-Riley, i think so! You would need to delete the sensormodule for the non flipped one from /usr/lib/camera
A Alex Kushleyev referenced this topic on
