  2. VOXL Accessories
  3. Microhard Modems
  4. RTSP Stream cutting out on Microhard network after ~15 seconds
Scheduled Pinned Locked Moved Microhard Modems
2 Posts 2 Posters 1.1k Views
  • Jeremy FrederickJ Offline
    Jeremy Frederick
    I've been experiencing a strange failure with the Microhard modems, running the RTSP stream through to QGC. After about 15 seconds, roughly once parameters finish downloading, the video stream cuts out and fails to reconnect. From what I can tell, this seems to be an issue with QGC, because VLC media player does not have an issue picking up the stream. Has anyone experienced anything similar? Experienced this with both the 2350 and 2450 modems, utilizing the Microhard USB module. Unlisted video to show the issue (skip to about the 30 second mark to account for the modems connecting).
    https://youtu.be/p27oVZNDlEY
    ModeratorM 1 Reply Last reply
    • Jeremy FrederickJ Jeremy Frederick
      @Jeremy-Frederick Can you try to lower the bitrate or resolution to see if it's a bandwidth issue?
      I understand that, in theory, the rendering software (VLC or QGC) shouldn't matter for your issue. But, it typically helps to see if there is a config that will work reliably and then push it from there.
