  2. VOXL Compute & Autopilot
  3. VOXL 2 IO
  4. VOXL2 IO Board Flashing Firmware
Scheduled Pinned Locked Moved VOXL 2 IO
4 Posts 2 Posters 1.8k Views 1 Watching
  • Aaron PorterA Offline
    Aaron Porter
    wrote on last edited by Aaron Porter
    I am trying to flash the firmware to the VOXL2 IO board but I am getting an issue using OpenOCD. It seems like the version has changed since the documentation was created.
    + FIRMWARE_FILE=/.../Downloads/m0065_firmware.bin
    + sudo openocd -f /usr/share/openocd/scripts/interface/stlink-v2.cfg -f /usr/share/openocd/scripts/target/stm32f1x.cfg -c 'adapter speed 4000' -c init -c 'sleep 100' -c 'reset halt' -c 'sleep 500' -c 'flash write_image erase /.../Downloads/m0065_firmware.bin  0x08001C00' -c 'reset run' -c exit
    Open On-Chip Debugger 0.10.0
    Licensed under GNU GPL v2
    For bug reports, read
    	http://openocd.org/doc/doxygen/bugs.html
    Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
    Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
    adapter speed: 1000 kHz
    adapter_nsrst_delay: 100
    none separate
    invalid command name "adapter"
    I am on a Linux computer and installed OpenOCD using just apt-get install openocd. I have the ST-Link connect like the diagram shows. And the ST-Link is connected to my computer via USB.
    So Honestly I am lost to as to what I am doing wrong?
    Thanks in advance,
    • Aaron
    • Aaron PorterA Aaron Porter
      none separate
      Thanks in advance,
      • Aaron
      @Aaron-Porter , can you please provide a link to the instructions that you are following? Do you have an M0065 boards with Modalai bootloader already installed, or do you have the original M0065 which was using a bootloader from PX4 ?
      Aaron PorterA 1 Reply Last reply
        Aaron Porter
        @Alex-Kushleyev
        I am following this guide: https://docs.modalai.com/voxl2-io-firmware/
        I am trying to install the firmware using STLink
        as for the bootl oader it is a ModalAI bootloader already installed I assume based on the blue LED light flash, so it is not a legacy board
          @Alex-Kushleyev
          @Aaron-Porter , thank you for clarifying. We resolved your issue offline, as this was a pre-release development effort.
          Moving forward, all customers have two options:
          • if you already purchased M0065 without ModalAI bootloader (the board was using old px4io bootloader and firmware), you can request a free replacement that will be sent with our latest bootloader and firmware installed (please request via support email)
          • all the new M0065 shipments will come with ModalAI bootloader and firmware
          With the new bootloader / firmware combination, there is no need for STLink at all. The firmware will be updated via UART directly from VOXL2 or optionally via a USB adapter. The firmware update protocol is very similar to our ESC firmware update protocol, so we will be able to use voxl-esc tools to perform the firmware update.
          We will be updating the docs shortly (https://docs.modalai.com/voxl2-io-firmware/) and will post an update here once it's ready.
