  3. Problem with voxl-camera-server crashing
image-sensor
2 Posts 2 Posters 891 Views
  • Chase RileyC Offline
    Chase Riley
    wrote on last edited by Chase Riley
    I have VOXL2 running SDK 1.0 and voxl-camera-server 1.7.1. I am using camera configuration ID # 11 with a IMX412 camera. After doing voxl-configure-camera 11 --imx412 and then power cycling the VOXL2 voxl-camera-server does not run. It crashes instantly. I have included the results from running voxl-inspect-services and voxl-camera-server -d 0 below. I would include a picture of the camera config however it is in a custom build platform and not easily visible.
    Scanning services...
     Service Name          |  Enabled  |   Running   |  CPU Usage
     docker-autorun        | Disabled  | Not Running |
     docker-daemon         | Disabled  | Not Running |
     modallink-relink      | Disabled  | Not Running |
     voxl-camera-server    |  Enabled  | Not Running |
     voxl-cpu-monitor      |  Enabled  |   Running   |     0.0%
     voxl-dfs-server       | Disabled  | Not Running |
     voxl-feature-tracker  | Disabled  | Not Running |
     voxl-flow-server      | Disabled  | Not Running |
     voxl-imu-server       |  Enabled  |   Running   |     0.0%
     voxl-lepton-server    | Disabled  | Not Running |
     voxl-mavcam-manager   | Disabled  | Not Running |
     voxl-mavlink-server   |  Enabled  |   Running   |     2.7%
     voxl-modem            |  Enabled  |   Running   |     0.2%
     voxl-portal           |  Enabled  |   Running   |     0.1%
     voxl-px4-imu-server   |  Enabled  |   Running   |     1.1%
     voxl-px4              |  Enabled  |   Running   |    37.2%
     voxl-qvio-server      |  Enabled  | Not Running |
     voxl-remote-id        | Disabled  | Not Running |
     voxl-softap           | Disabled  | Not Running |
     voxl-static-ip        | Disabled  | Not Running |
     voxl-streamer         |  Enabled  |   Running   |     0.0%
     voxl-tag-detector     | Disabled  | Not Running |
     voxl-tflite-server    | Disabled  | Not Running |
     voxl-time-sync        | Disabled  | Not Running |
     voxl-uvc-server       | Disabled  | Not Running |
     voxl-vision-hub       |  Enabled  |   Running   |     1.3%
     voxl-wait-for-fs      |  Enabled  |  Completed  |
    voxl-camera-server -d 0 output
    GPS server Connected
    DEBUG:   stereo camera "stereo_front"with cam ids 0 & 1
    DEBUG:   Secondary id found for camera: stereo_front, assuming stereo
    DEBUG:   stereo camera "stereo_rear"with cam ids 5 & 4
    DEBUG:   Secondary id found for camera: stereo_rear, assuming stereo
    configuration for 4 cameras:
    cam #0
        sensor type:         ov7251
        isEnabled:           1
        camId:               2
        camId2:              -1
        fps:                 30
        en_preview:          1
        pre_width:           640
        pre_height:          480
        pre_format:          raw8
        en_small_video:      0
        small_video_width:   -1
        small_video_height:  -1
        en_large_video:      0
        large_video_width:   -1
        large_video_height:  -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        standby_enabled:     0
        decimator:           1
        independent_exposure:0
    cam #1
        sensor type:         imx412
        isEnabled:           1
        camId:               3
        camId2:              -1
        fps:                 30
        en_preview:          0
        pre_width:           640
        pre_height:          480
        pre_format:          nv21
        en_small_video:      1
        small_video_width:   1024
        small_video_height:  768
        en_large_video:      1
        large_video_width:   2048
        large_video_height:  1536
        en_snapshot:         1
        snap_width:          4056
        snap_height:         3040
        ae_mode:             isp
        standby_enabled:     0
        decimator:           1
    cam #2
        sensor type:         ov7251
        isEnabled:           1
        camId:               0
        camId2:              1
        fps:                 30
        en_preview:          1
        pre_width:           640
        pre_height:          480
        pre_format:          raw8
        en_small_video:      0
        en_large_video:      0
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        standby_enabled:     0
        decimator:           1
    cam #3
        sensor type:         ov7251
        isEnabled:           1
        camId:               5
        camId2:              4
        fps:                 30
        en_preview:          1
        pre_width:           640
        pre_height:          480
        pre_format:          raw8
        en_small_video:      0
        en_large_video:      0
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        standby_enabled:     0
        decimator:           1
    DEBUG:   ------ voxl-camera-server: Starting 4 cameras
    Starting Camera: tracking
    DEBUG:   ----------- Number of cameras: 4
    DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x00E2, Sensor Id: 0x7750
    DEBUG:   Cam idx: 1, Cam slot: 1, Slave Address: 0x00E4, Sensor Id: 0x7750
    DEBUG:   Cam idx: 2, Cam slot: 4, Slave Address: 0x00E2, Sensor Id: 0x7750
    DEBUG:   Cam idx: 3, Cam slot: 5, Slave Address: 0x00E4, Sensor Id: 0x7750
    VERBOSE: Successfully found configuration match for camera 2: 640x480
    VERBOSE: Adding preview stream for camera: 2
    DEBUG:   Converted gralloc flags 0x20900 to GBM flags 0x1400000
    VERBOSE: Dumping GBM flags
    DEBUG:   	Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI
    DEBUG:   	Found flag GBM_BO_USAGE_HW_COMPOSER_QTI
    VERBOSE: Opened GBM fd
    VERBOSE: Created GBM device
    DEBUG:   Allocated BO with width=640 height=480 stride=640 aligned_w=800 aligned_h=480 size=385024 flags=0x20900 format=GBM_FORMAT_RAW10
    DEBUG:   Successfully set up pipeline for stream: PREVIEW
    VERBOSE: Entered thread: cam2-request(tid: 4720)
    VERBOSE: Entered thread: cam2-result(tid: 4721)
    DEBUG:   Started Camera: tracking
    Starting Camera: hires
    VERBOSE: added request for preview stream
    VERBOSE: Sending request for frame 0 for camera tracking for 1 streams
    ERROR:   Camera 3 failed to find supported stream config: 1024x768
    ERROR:   Failed to start camera: hires, exiting
    DEBUG:   	Stopping Camera: tracking
    VERBOSE: Received result from HAl3 for frame number 0
    VERBOSE: Received 0 buffers from camera tracking, partial result:1
    VERBOSE: finished sending request for frame 0 for camera tracking
    VERBOSE: returning from SendOneCaptureRequest for frame 1 for camera tracking
    DEBUG:   ------ Last request frame for tracking: 1
    VERBOSE: Leaving tracking request thread
    DEBUG:   ------ Last tracking result frame: 0
    VERBOSE: Leaving tracking result thread
    DEBUG:   Deleting buffers for tracking preview stream
    WARNING: Deleting buffers: 1 of 16 still in use
    DEBUG:   Deleting buffers for tracking small video stream
    DEBUG:   Deleting buffers for tracking large video stream
    DEBUG:   Deleting buffers for tracking snapshot stream
    VERBOSE: Received 1 buffers from camera tracking, partial result:0
    VERBOSE: Received output buffer 0 from camera tracking
    VERBOSE: Buffer arrive before meta frame 0
    DEBUG:   Done closing device for camera tracking
    DEBUG:   Done calling stop for camera tracking
    DEBUG:   	Deleting Camera: tracking
    DEBUG:   	Stopped Camera: tracking
    DEBUG:   	Erasing all managers
    ModeratorM 1 Reply Last reply
    • Chase RileyC Chase Riley
      cam #0
          sensor type:         ov7251
          isEnabled:           1
          camId:               2
          camId2:              -1
          fps:                 30
          en_preview:          1
          pre_width:           640
          pre_height:          480
          pre_format:          raw8
          en_small_video:      0
          en_large_video:      0
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             lme_msv
          standby_enabled:     0
          decimator:           1
      cam #1
          sensor type:         imx412
          isEnabled:           1
          camId:               3
          camId2:              -1
          fps:                 30
          en_preview:          0
          pre_width:           640
          pre_height:          480
          pre_format:          nv21
          en_small_video:      1
          en_large_video:      1
          en_snapshot:         1
          snap_width:          4056
          snap_height:         3040
          ae_mode:             isp
          standby_enabled:     0
          decimator:           1
      cam #2
          sensor type:         ov7251
          isEnabled:           1
          camId:               0
          camId2:              1
          fps:                 30
          en_preview:          1
          pre_width:           640
          pre_height:          480
          pre_format:          raw8
          en_small_video:      0
          en_large_video:      0
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             lme_msv
          standby_enabled:     0
          decimator:           1
      cam #3
          sensor type:         ov7251
          isEnabled:           1
          camId:               5
          camId2:              4
          fps:                 30
          en_preview:          1
          pre_width:           640
          pre_height:          480
          pre_format:          raw8
          en_small_video:      0
          en_large_video:      0
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             lme_msv
          standby_enabled:     0
          decimator:           1
      @Chase-Riley this is most likely a hardware / cabling issue. Often cables are plugged in backwards or not fully seated
