  3. How to connect Microhard pDDL Carrier USB Dongle to Voxl 2mini
voxl-2-mini
3 Posts 2 Posters 835 Views
  • P Offline
    P Offline
    pavansai
    Hi Team,
    We are working with voxl2 mini board, so how to connect Microhard pDDL Carrier USB Dongle to voxl2 mini.
    Thank you
    Regards
    Pavan Sangani
    ModeratorM 1 Reply Last reply
    • P pavansai
      Hi Team,
      Thank you
      Regards
      Pavan Sangani
      @pavansai Hi Pavan, you can use the J3 USB connect to the Microhard Carrier USB Dongle, but you will need to supply 5V independently to the carrier dongle.
      If you want a more integrated solution you should use VOXL 2 with the Microhard Add-on, it will work more gracefully.
      P 1 Reply Last reply
      • ModeratorM Moderator
        P Offline
        P Offline
        pavansai
        Thanks @Moderator, How to connect Microhard UART to VOXL2 mini, which connectors should I use?
